Question about IBM E74 Monitor
Some time screen flicaring
Some time screen flickering
My aspire 5830t screen flicker at startup
I suspect the backlight or inverter may be faulty. Check on flea bay for replacement prices.
Dec 21, 2013 | Computers & Internet
Hp g6000 screen
Please explain the events that lead up to your screen flickering ... in detail, from the time you turn the laptop on. Does the splash screen flicker?
Sep 07, 2013 | Computers & Internet
My nokia x2-02 screen flickers some times
you need to unplug lcd (screen) from board and plug again, this happen when devicec had a fall down.
Jul 08, 2012 | Cell Phones
My monitor compaq model MV520 is always blinking every time I open my computer, How can I fix it?.
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to answer and solve your problem. Your Compaq MV520 Monitor is always blinking every time you turn on your computer and you want to know how you can fix it? First, we need to troubleshoot the problem. I'm thinking you probably need to refresh the flicker rate on your monitor. The flicker rate is probably set on a low setting, which is causing you screen to blink (flicker). This can be bad for your health as well because it can cause eyestrain and headaches. Your monitor is a CRT (Cathode-Ray Tube) model. These types of monitors can cause a lot of screen flickering. Now that we've troubleshooted the problem, now it's time to solve the problem. There are two ways you can solve this problem. You can either refresh the flicker rate or you can buy an LCD monitor. LCD monitors flicker-free. My suggestion is that you refresh the screen flicker rate. To refresh the flicker rate, go into your System Preferences or Control Panel, click your operating system's appearance and display link and click your screen adjustment link. You may have to click your advanced settings link. Click your monitor tab and from there adjust you screen refresh rate. You may have to adjust your screen resolution before you refresh the screen rate. If you have to do this, make sure the screen resolution you choose supports you monitor's height and width as well as visibility. The higher the resolution, the higher the screen rate. The instructions I'm giving you may sound like this because I'm not sure what your operating system is. I'm not to familiar with Mac Operating Systems, but if you have a Windows Operating System and you need better detailed instructions, just reply back. I hope this decreases your screen flickering and gives you a better viewing experience.
Jul 07, 2011 | Computers & Internet
Acer Laptop Screen Flickers & Jumps
Please connect the laptop to an external monitor. If no flickering on monitor screen, from my previous experience, this is more likely loose connection of video cable connected to the LCD. So talk to Acer support again and require the replacement of LCD.
CompQ
May 11, 2010 | Acer Aspire 6930-6082 Notebook PC
Hi my Toshiba M110 laptop model PSMB0A-0IL00D screen flickers some times. It has gone all black few times as well. Is it cheap to fix? will it crash? Cheers Theo
According to the manual for my Toshiba laptop, the price of the screen is about the third of the price of the laptop. Do the math.
Before looking for a repair shop, investigate first the reason foe the Flicker.
I just remembered: all screens flicker. But if they flicker at 50 Hertz you might notice it. The higher the frequency the less noticeable the flicker is. Check your graphics properties to find out if you screen cannot refresh at a higher rate than the current one (60Hz, 75Hz or higher). But beware! if you force it to flicker at a frequency that it cannot handle, you will damage it.
Hope it helps.
Sep 06, 2009 | Toshiba Satellite A105-S4004 Notebook
My laptop screen flickers is it due to a virus?
run malawarebytes its for free if the problem persistes contact the manufacturer that might be manufacturing defect in liquid inside the display
May 08, 2009 | Microsoft Windows Vista Ultimate Edition
Acer notebook aspire 5102 WLMi screen flickers
Hardware, sound like the cable that attach to LCD panel was losing...
Nov 17, 2008 | Computers & Internet
Compaq presario v2000 monitor is having horizontal purple lines that flicker.
Try reloading the drivers, delete the device in device manager and reboot. It should then pick up the drivers and reload them, if that does not work I would suspect the screen is on its way out (flickering normally means the screen or its connection is bad)
Jan 26, 2008 | HP Compaq Presario V2000 Notebook
IBM E74 Monitor Logo
43 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
