Question about Brother Office Equipment & Supplies
I have just bought a MFC 235C and I am having difficulty in putting borderless photo paper in the trat it is not taking it the paper is 10x15cm and i put it to the mark but it dosn't print the machine does not recognise the paper is there, if i put it too far back it tells me there is a paper jam please advise
Solved I had not put the paper in properly, it was my fault.
Thanks
Posted on Apr 19, 2008
My MFC-7360 says NO PAPER, but there is paper.
Most probabply will also say Please put paper in the MP tray ?
Sep 23, 2014 | Brother MFC 7360N - Multifunction fax /...
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Aug 28, 2014 | Brother MFC 7360N - Multifunction fax /...
My name is Tammy Kirk, i was given a intelliFAX-770 and do not have a manual, or printer to download it and print, im trying to figure out how to use it. could i get a manual mailed to me? at 8012 so....
Hi Tammy
I am assuming the fax is operational.
The supplies for your fax are expensive enough.
You could probably buy the original manual somewhere but the cost of it plus the shipping will make it an even more expensive proposition.
You can download a PDF version of it here:
http://www.brother-usa.com/manuals/default.aspx?PGID=2&R3ModelID=PPF770
and read it on your computer without the need of printing it.
The size of the file is way under 1 MB
If you prefer to have a printed version of it, just about any stationery store will do it for a few dollars.
If you have any difficulties downloading the PDF file, please contact me. I'll be more than happy to email it to you. I am in Canada, but the internet is borderless. :)
faxmando@yahoo.com
Mailing you a hard copy is also not out of the question.
It's your decision now.
Best regards.
May 11, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
Brother MFC 8220 has a red ligth with an error message saying check paper reload paper. I put the tray correctly with papers loaded and it keeps. Cannot print, copy or fax anything
mine was doing the same thing. pull the paper tray out and there is a black lever next to the feed drum, it wouldn't move up and down. I took of the cover and slid the lever over to the left so it would move freely and now it is fine.
Mar 12, 2010 | Brother MFC-8220 Fax
I have a fax/scanner/photo/copier Model MFC 210C that says unable to clean. I cannot find the user guide to troubleshoot the problem. Any assistance would be appreciated
do a website search for your brand name, most Manufacturers have manuals for their products, listed on their site. manuals are currently in PDF or Microsoft word format.
Jul 09, 2009 | Brother IntelliFAX 1840C Plain Paper...
My Brother MFC-235C shows print unable 32 read user manual but I dont have a manual
The message "Print Unable 32" or "Machine Error 32" will appear on the LCD display if paper or labels are stuck inside the printer or drum unit.
This will also appear if there is either a mechanical issue or just a problem with a sensor possibly software.
1) The way to resolve this issue is to make sure there is no paper in between the rollers or on top of the print heads (if applicable).
2) If there is no paper the you will need to hard reset the printer which will restore to manufacuter settings and reset software.
Hold down the Menu botton while plugging in the power cable. The display should read "Maintenance." let go of the menu button and then punch in 91. The display should read "Param Init." The unit will beep once. Then type 99. The unit will exit maintenance mode.
This only works for maybe 30% of the time.
3) If this does not work then : Refer to Manufacturer or return the item.
IF PRINTER DOES NOT HAVE A MENU BUTTON:
1)Turn the printer power switch OFF. Check that the front cover is closed.
2)Turn the printer power switch ON while holding down the GO button until the Toner, Drum and Paper LEDS are lit.
3)Release the GO button. All LEDs will be off.
4)Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the READY LED will be lit.
Feb 19, 2009 | Office Equipment & Supplies
Brother MFC-260C How do edit phone numbers set up in short dial
i have misplaced my disc for installinig my brother MFC-235C
MFC-260C. any help with an answer to installing my printer would be much appreciated. thank you, tania
Aug 20, 2008 | Brother Office Equipment & Supplies
RECURRING PAPER JAM - BROTHER MFC 5860 CN
I just bought the 5860 and have this issue right out of the gates. I discovered that the back lid causes the paper jam when using the bottom tray while examing with a flash light during a print job. I dislodged the back plate/lid (same lid you remove to pull paper jam out) out about 10mm and fastened the lid loosely to the back with a piece of tape on each side. The paper from the bottom tray does not slam against the back of the printer any more, thus more freedom of movement and no jams. Just successfully printed an 80 page document. You shouldn't have to do this with a new printer but I got it so cheap with all the rebates that I'm going to keep it and live with this fix. To sum up, the problem is a design flaw where the removable back plate is snapped in too tightly and contacts the bottom tray paper roller (& paper) during a print cycle. To fix you need to clear the path by pulling the back lid out slightly and taping each side with scotch tape to 'suspend'the back plate out about 10mm.a5999d3.jpg
Feb 02, 2008 | Office Equipment & Supplies
46 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
