Question about Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher won't power on- no lights. My husband just cleaned out the appliance- could he have knocked something loose?
  • Bosch Master
  • 2,605 Answers
Hello, welcome to Fixya. When you state your "husband just cleaned out the appliance" what do mean exactly. I would suspect a poor line connection at the junction box where the power enters the dishwasher, or a broken wire in the door panel at the point it bends as the door opens & closes is common...based on what you've described. Let me know by posting a reply what you find and what you meant. **Make sure the breaker is OFF before attempting any repairs** I'll try and assist you through a diagnosis and repair if need be. Good luck macmarkus :)
Posted on Jul 07, 2010
    Problem Solver:
  • 17 Answers
First...make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Posted on Oct 18, 2010
My lamona dishwasher starts filling with water as soon as I select a programme and the door won’t close. It looks like the latch is permanently out? What can I do please?
Sounds like something has failed. You didn't say how old the unit is but most household appliances cost more to fix than simply buying a new one.
Occasionally it is something simple like a switch or loose wire but yours sounds like a number of issues.
Unless it's under warranty I suggest buy a new one.
Feb 04, 2018 | Dishwashers
Everything lights up and can choose a program but when I shut the door dishwasher will not start
Hello;
My name is Peter. I am a retired field service appliance technician.
Locate your model number. It is either on the top of the dishwasher door or on the face of the dishwasher after you open the door. Since you did not provide a model number I can only advise in general.
Let's assume that your control board and the touch pad if you have one are fine.
1.) Door Latch Contact Switch - You will get no power if this switch has failed.
2.) Thermal Fuse. - You will get no power if this component has failed. It is normally mounted (Clip on) on the side of your control board assembly.
This component as well as the door latch switch can be Ohm out to check if good or bad.
Caution: If you elect to change the thermal fuse, ground yourself by touching something that is bare metal. Static electricity will knock out a board.
Go into the following website, plug in your model number (Left side), and you will see diagrams and part numbers of what you have.
Water Filters Lawn Garden Appliance Parts
Jun 05, 2015 | Dishwashers
My previously quiet Asko dishwasher now makes a lot of noise during draining cycles
Hello Beverly;
You did not provide a model number so I have to advise in general terms.
It sounds like your drain pump is struggling.
Clean your drain and/or drain filter. Wear gloves you may have broken glass or something sharp in your drain.
You garbage disposal line may be plugged.
Or you drain pump may be going bad (But, I do not really think so).
Dec 22, 2014 | Asko Dishwashers
Hi I have a whirlpool dishwasher, power is present at stub, thermal fuse is fine, but no power ( lights on control board don't light) otherwise. Cannot start machine. I changed out the thermal fuse
Hello Clinton;
If you have power going into your unit, your display board should light up. You need to get to your control board. Turn power off to your unit, push in on the wires to your connectors, inspect the board for burn marks or melted connectors.
Before you touch your control board ground yourself by touching something that is bare steel. Static electricity will knock out a board. Do the same if you replace the board. The part number of the board is on the board. Do not buy locally. You can get some great deals on the internet.
You did not provide a model number so I can not tell you how to access the board.
Go into the following website, type in your model number and you will get diagrams of your unit for disassembly.
Dec 21, 2014 | Whirlpool Dishwashers
No power in dishwasher
Could have blown an internal fuse or a wire got knocked loose
Jun 09, 2012 | LG Dishwashers
My dishwasher ( 66517269400) won't turn on. Circuit is fine. It is getting power. I replaced the fuse. Clean light is flashing 7 times. Manual says "dishwasher has malfunctioned. Call for...
The F7 error code(light flashes 7 times) is a one of these, Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
So what you need to check is if the correct water level is in the tub,to check that start d/w let it fill and once you longer hear water entering,open door and the water should be level or just above the heat element, if not enough water first check water pressure to inlet valve,if pressure is good replace the water inlet valve part # 8531671 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Aug 20, 2011 | Kenmore 24 in. 17269 Built-in Dishwasher
My Maytag dishwasher buttons light up: it won't run.
It sounds like it could be the thermostat. Its about a 20 dollar part on appliance parts pros. If it were me, I'd try the 20 dollar fix first. Search Over 2 1 Million Appliance Parts
Jan 12, 2018 | Dishwashers
Run few seconds then quits flashing 3 green lights
If all 3 are flashing it means there was a power failure. Check your power connection to make sure when the washer is coming on it is not knocking them loose.
Nov 26, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
My dishwasher does not turn on
check socket is ok - plug in something with a light into the same socket as an easy way of checking. otherwise go to where mains terminates on the appliance and check power is actually present - you will need a multi-meter
Jun 19, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
262 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
