Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
I need to fit my mixer with a 3-prong plug. Which wire is the Neutral and which is the Live. The colors are Blue Brown and Green. The machine is 230 Watts 50-60 Hz
  • 1,056 Answers
Green is always the ground. Blue should be hot and brown is the neutral.
Posted on Jul 07, 2010
Three of my hobart mixers are spining wrong what is the problem
These must be 3 phase mixers (electrically there are two choices, single and three phase) Three phase cables typically have 4 wires, black, white, red and green (green is ground of course) To reverse the rotation of your mixers you would have to swap two of the three colors, and it doesn't matter which two of the three you choose, DO NOT SWAP THE GREEN, LEAVE IT ALONE. for example, just change red and black wires where it they connect to the plug. Of course turn off the power, unplug the the mixer, and usually you can take the plug apart and reverse the wires. If your units are hardwired you should call an electrician in to do it, it will only take a couple of minutes. cf652f29-33fe-4eee-8e37-1addfd1bcb1a.jpg aec28350-7e8b-4d45-a617-78e7a23dbf21.jpg
Sep 04, 2013 | Varimixer W20J Stand Mixer
I have the 300 watt hand mixer and the retreactable cord no longer holdes when pluged in. It's been broken for some time. Is there a fix to this problem.
The prongs on the plug have worn, and the plug can be replaced (for less than $2 USD) from any
hardware store, just cut off the old plug, and wire the new plug onto the cord.
Remember to keep the cord's conductors correctly oriented: the conductor on the Bravetti Hand
Mixer that have the uncolored stripes (in the insulation) is the Neutral conductor, the other is the Hot conductor - assuming your abode is wired to standard US 120VAC.
Aug 08, 2011 | Bravetti EP552H Hand Mixer
Bosch universal mixer 800W. How do I change a 110 volt to a 220 volt? Is it possible?
Bosch is not very good about putting manuals or other documentation online for older products, so I'll have to give you generic advice.
Some electric motors have optional voltage connections. If your motor has this feature, there will be a box or removable plate on the motor with 110 Volt and 220 Volt connections inside. You would need to replace the line cord with a 220 Volt cord having the correct plug for the location you plan to use the mixer, and connect the motor "hot" wire to the 220 V connection in the motor junction box instead of the 110 V connection (the neutral wire goes to the same neutral).
If there is no such option available on the motor, you would also have to replace the motor with a 220 Volt version. Check the labeling on the speed control (inside the mixer) to be sure it is rated for 240 VAC, and check the power label by the power cord. If the label gives a single range of input voltages spanning both 110 VAC and 220 VAC (e.g., "Input 97 V- 265 V") then you only need to change the plug. Unless the electrical parts are all rated for 240 VAC or higher, conversion is not safe.
Some products (especially desktop computers) have a recessed switch on the back that lets you select either 115 VAC or 230 VAC input power. If you have this on the mixer, all you have to do is use a small tool to push it to the other position.
An alternative is to get a 230 VAC - 115 VAC transformer or inverter rated for at least 800 Volt-Amps and wire it with a 230 Volt plug on the primary side and a 115 Volt socket on the secondary side; then you can just plug in your unmodified mixer to this. If you cannot find a box like this, you can buy a "control transformer" from an industrial equipment supplier and put it in a suitable metal box. I recommend including a power switch and a 4 Amp dual-element fuse or breaker on the primary side circuit; you don't want somebody burning up the transformer with a 1200 Watt microwave oven or griddle.
Mar 17, 2011 | Bosch MUM6630 Universal Series Stand Mixer
I am getting a lot of distortion feedback when I connect my computer to the mixer but the feedback only starts when the computer is connected to an electrical outlet. I have plugged the computer to a...
Sounds like a ground problem. Try to hook a ground strap or wire from the case of the computers power supply to the ground of the mixer. If it still has noise, try to touch the ground to the bracket of the computers sound card. Most likely, the computer uses a three prong adaptor and the mixer does not. Outlet grounds have voltages which bleed off from motors and other devices, which could cause the 60hz noise. If your mixer has a three prong plug do not plug your computer and mixer in separate outlets with separate grounds or you could fry your system. If you still have problems use a three to two prong adaptor and attach an isolated ground wire on the adaptor for the computer.
Jun 25, 2010 | Gem Sound CDM-150 Mixer
Where does ground wire go
Hi there, If you can give me a little more information, I'd appreciate it. However, I'm going to give it my best shot to see if I can answer what I believe you're looking for. If you're talking about the outlet (receptacle) that you're plugging your appliance into, then the ground (green) wire, or screw on the bottom of the outlet is where you want to connect your third (ground) wire to. If you just have two wires coming off your outlet (receptacle) and can't find the third wire. Then you'd ground or connect a wire to the inside of the box, and then tie with the ground (green) wire coming from the green ground screw on the outlet (receptacle). The problem with house wiring is, a majority of your older houses outlets aren't grounded. If you have a 3-prong outlet, then maybe yours is. But sometimes, people just change these out for convenience purposes. And lastly, if you're talking about the grounded wire in your appliance - look for a green (ground) screw, otherwise you want to connect this to (or around) a metal screw on the inner frame. A majority of your old appliances were never grounded. So bottom line is; your appliance should work with, or without your ground wire. It would be preferable if it was grounded. But for operating purposes, its not. I hope I was able to answer your question for you. If not, feel free to contact me again. Good Luck, Jim
May 21, 2010 | Hobart Food Mixers
Electric current
The three pronged wire contains a green wire which is connected to the metal housing of the mixer. It sounds like either that wire is broken, or disconnected inside the mixer, or the service into which you are plugging the mixer does not have a ground wire connected to a proper ground.
Remove the rear cover and look for a green wire and make sure it is connected to the metal of the frame.
If it is then check the outlet you are using to ensure it is wired correctly.
Apr 11, 2010 | KitchenAid K45SS Classic Stand Mixer
The cord has a short and I need to replace it
Hi, this is a very simple process. I don't know if the cord is a 2 prong or 3 with the ground, but it makes no difference. You should have screws around the perimeter of the mixer that you need to take loose to separate the half's. I am assuming the cord is built into the mixer, if not please correct me. The end of the cord will be connected to the on/off control, may it be a trigger type or slide or what ever it has. You will have either a black wire which is hot, connected to the switch so the switch can break the connection to turn the mixer on and off. The other wire may be white which is neutral connected to another wire in the mixer, you will see this. If it has a ground, 3 prong, it will be green and will show you where it connects. If it is just 2 prongs, the 2 wires may both be black and in this case you can connect them to either wire they are showing you. I don't believe the connections are soldered, they may be screw connections or wire nut connector's. If it would be easier for you, take the mixer with you to your hardware store such as Home Depot as they have many different cords to choose from, and you will get help in the electrical section to make sure you have all you need. Just take your time and put the wires back in the same way as the old cord was wired. If the cord is a detachable cord, take it with you and match it with one that has the same connections and 120 volts. You do not have to buy a Black and Decker cord to do this. There are many cords that will do the job just as good if not better. Keep me posted if you need my help.
Sincerely,
Shastalaker7
Feb 12, 2010 | Black & Decker Ergo EHM90 Hand Mixer
Electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Jul 24, 2009 | Hobart H600 Stand Mixer
Hobart 600 wiring connection
The ground wire attaches to the ground lug under the top.
Mar 16, 2009 | Hobart H600 Stand Mixer
Need to replace a cord on a 30 quat hobart mixer and need to know where positive negative and ground go
I need to know if the mixer is 1 or 3 phase.Look at the plug---does it have 3 or 4 prongs?
Nov 30, 2008 | Hobart D300 Stand Mixer
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
67 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
