Question about Singer 7442 Mechanical Sewing Machine
My singer 7146 sewing machine bobbin holder is not moving, what shall i do?
fwadley
  • 482 Answers
SOURCE: Singer 9015 sewing machine - bobbin loading
bobbin goes under the door of the needal, the thead come out from the right to the left, thead goes in the first edge and up and out of the left, you need the needal to be treaded, turn the round right know till the needal goes in and out , pull the tread up and out together.
Posted on Nov 26, 2007
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Posted on Sep 29, 2008
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
SOURCE: singer futura model 900 sewing machine
Recently had same problem. Underneath the bobbin area on the bottom of the machine is a small white plastic piece that resembles a fan. Singer calls this the bobbin cam actuator. It is usually cracked along the sleeve that fits over the metal pin, bar? This is the mechanism that lifts the bobbin when it is wound. When its broken it can't lift the bobbin to be wound properly.
Posted on Sep 12, 2009
Maggie_B
  • 3 Answers
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Posted on Oct 31, 2009
The hand wheel does not move. removed the needle, still not working
sounds like you have thread bunched up in the bobbin case. take out the entire bobbin plus the bobbin holder and clean it. it is worth a try....
May 20, 2016 | Singer 4411 Heavy Duty Sewing Machine
How do I place a bobbin holder into a singer sewing machine 5805c
Marjorie, the first thing you should do is download your user's manual. It is a free download at the Singer Sewing Machine website, and it's pictured on page 74.
Dec 19, 2014 | Singer Sewing Machines
Simplicity sewing machine SL 9240 was giving to me and when I try to sew the needle keeping hitting the bobbin holderr.
On the right side you have two knobs to make adjustments. The lower knob will move the needle left or right so it won't hit the bobbin holder.
May 31, 2014 | Singer 7442 Mechanical Sewing Machine
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
Singer inspiration thread wraps around bobbin seat while sewing
it sounds like you need a new bobbin case. and it would be a good idea to have the machine serviced
Mar 30, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Bottom thread too loose; tried rethreading top thread, cleaning bobbin case, refilling bobbin, changing needle, adjusting top tension
Check for correct bottom thread tension.
It's provided by a flat spring on the bobbin holder.
When the bobbin is correctly installed, pulling on the thread
should meet with slight resistance, and the bobbin should spin without
trying to jump out of the bobbin holder.
Dec 18, 2010 | SINGER 7470 Sewing Machine
When i'm sewing the bobbin holder jumps out of place the needle then lodges it's self in casing and locks machine up,i have replaced the casing/holder and it did the same thing again
It sounds like the wrong size bobbin, try calling Singer is your bobbin is right because they should be able to answer why it is acting so strange. Good luck
Oct 05, 2010 | Singer Quantum XL-5000 Computerized Sewing...
Singer/merritt 2430 bobbin fill
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
Jun 18, 2009 | Janome 6019QC Mechanical Sewing Machine
I removed the positiong plate
I removed the posiotioning Plate(A). Singer Inspiration 4205. How can I get it back in?
Sep 23, 2008 | Singer Inspiration 4210 Mechanical Sewing...
Singer 7442 Mechanical Sewing Machine Logo
386 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
