Question about Kitchen Ranges
I have a Brown propane gas range and over in my park model camping trailer. I t is an older model. The problem is the oven will not light. The pilot is lit and when when the oven control knob is turned, the second pilot lights. The safety valve however does not activate to turn on the burner. I have replaced the gas valve A new temperature sensor was included with the replacement valve. Both were identical to the units which they replaced. My thinking is that for some reason the second pilot is not hot enough to activate the temperature sensor and the burner. The flame on the burner seams weak and it is yellow/orange in color . I seam to remember it being more blue. Can anyone shed some light on this?
  • 1 more comment
  • scott_jahnke Jul 07, 2010
    I am trying to find out how close to the pilot the thermocouple needs to be located and what color the pilot flame should be when the thermostat is on (Orange or Blue)?. It is currently Orange. Also, is there a way to test the safty valve when removed form the oven?
    Jul 07, 2010
    - My model has 2 separate pilots on 2 separate gas lines. The small pilot is always lit. The 2nd lights when the thermostat is turned on however it seams weak what color should it be? How close is it supposed to be to the Thermocouple? When I installed the new one, we installed it in the same location as the old one which used to work until this year.
  • scott_jahnke Jul 08, 2010
    Very informative, Thank you
    President:
  • 1,561 Answers
On a pilot ignition oven, there is a pilot which is an actual gas flame (although very small) in the oven. What happens in this system is that the pilot stays lit all the time and when the oven thermostat is turned on, the pilot flame extends (gets bigger) to envelope the thermocouple bulb of the oven safety valve. The thermostat controls gas flow to both the pilot and to the oven safety valve. Once the oven safety valve's thermocouple senses appropriate heat, the safety valve opens to allow gas flow to the oven burner where the pilot flame ignites the gas. The main oven burner should usually light in less than 1-1½ minutes after the pilot flame has extended to envelope the safety valve's thermocouple.
On a pilot ignition system the pilot flame must be lit for the oven burner to receive gas. If the pilot will not stay lit, there may be a problem in the oven thermostat (which supplies gas flow to the pilot) or the gas tubing leading to it and/or the pilot itself may be plugged with cobwebs, grease, etc.
I have a Brown propane - alertbubble.gif Note: On some recent (2004+) Americana, GE, Magic Chef and probably other pilot ignition range models, the oven thermostat knob needs to be pushed in and held before the pilot can be re-lit if it has gone out. The oven control knob may have to continue to be held in for up to a minute after the pilot has been re-lit. If the pilot IS lit but the oven burner is not lighting, the pilot flame will need to be inspected as the thermostat is turned on. If the pilot is not extending when the thermostat is tuned to ON, the oven thermostat may be defective. If the pilot is extending but the oven gas valve is not opening, that oven safety valve may be defective or its sensor bulb may be out of position on the pilot or just dirty causing it to not sense the proper temperature of the pilot flame. A dirty pilot can also cause a reduced size pilot flame so the oven safety valve can not sense the proper temperature to open.
Take care.
Posted on Jul 07, 2010
  • Sulaimon Jimoh Olayemi Jul 07, 2010
    What happens in this style
    ignition system is that the thermostat or electronic control switches
    power to the oven ignitor and gas valve circuit which are connected in
    series (one after the other). As power flows through the ignitor it
    heats and draws current (measured in amperage). Once the oven ignitor
    draws a specific amount of current the oven valve opens to allow gas to
    flow to the oven burner where the glowing hot ignitor (glow bar) ignites
    it. Power must continually flow through the ignitor and oven gas valve
    for gas to be released into the oven burner to create a flame. Once the
    set temperature is achieved the control stops all power to the ignition
    circuit which causes the ignitor to dim and the oven gas valve to close,
    stopping any burner flame. Cycling on and off continues to maintain the
    specific temperature the control is set for.
    On models utilizing a 'dual'
    gas valve, both the bake and broil gas and ignition systems
    should be considered totally independent of each other. Even each side
    of the dual gas valve should be looked at as two separate 'single' gas
    valves. Just because one side of a dual gas valve might work does NOT
    mean the other side of the valve should work too.
    As long at the ignitor is being
    powered, the control system (hydraulic thermostat or electronic
    control) is doing its job. The ignitor, while glowing, may not be
    allowing the proper amount of current to flow through it to the oven gas
    valve for it to open. Proper testing (see the link at the bottom of the
    page) requires an ammeter to check the current flow through the
    ignition circuit to the oven bake/broil valve.
    Weak oven ignitors can
    glow but not achieve an adequate resistance to allow the correct current
    to flow to the gas valve for it to open. They can also glow but not be
    quite hot enough to ignite the gas immediately.
    If the ignitor ages and gets
    'weak', it is possible for it to glow and generate some warmth in the
    oven but the oven burner never actually come on to get the oven up to
    proper temperature. It is also possible for the oven burner to light and
    heat once but never cycle back on again afterward. The heat generated
    by the ignitor may keep the oven warm for a while until it is noticed
    that the oven isn't heating 'right' any longer.
    Power must flow from the
    control system to the ignitor and through the oven valve. If there is
    any break in that circuit, the ignitor will not glow and thus the gas
    valve not open. The ignitor not glowing could be caused by the ignitor
    or the gas valve being open (infinite resistance - no continuity). If
    both have continuity (ie. at least some resistance) and the ignitor is
    still not glowing, a problem in the control system or the rest of the
    electrical circuit would need to be investigated.
    An ignitor and oven
    valve having continuity does not necessarily that they are good, just
    that they're not electrically open, which is only one way that they
    might fail. If either has NO continuity at all (ie. infinite resistance)
    they are likely defective and need to be replaced.
    Take care.
  • 2,272 Answers
FLAME IS ORANGE/yellow
Possible causes:
Dust particles in main line
Range not set for proper gas.
Solutions:Allow burner to operate for a few minutes until flame turns blue.
OVEN OR BROILER DOES NOT HEAT. (PILOT IGNITION MODELS)
Possible causes:Pilot light not lit.
OVEN DIAL WILL NOT TURN WHEN FULLY PUSHED IN. (PILOT IGNITION MODELS)
This is a normal safety feature of lighting oven pilot.
This knob requires a “Partial Push to Turn”.
OVEN PILOT DOES NOT STAY LIT.
Possible causes:Safety thermocouple not sensing pilot light.
Solutions:
Adjust flame size of pilot light.
Adjust thermocouple tip location over the pilot flame.
OVEN WILL NOT MAINTAIN LOW TEMPERATURE. (PILOT IGNITION MODELS)
Possible causes:Minimum set screw on thermostat is improperly set.
Solutions:
Adjust minimum set screw.
OVEN BURNER GOES OUT OR WILL NOT RELIGHT WHILE HOT. (PILOT IGNITION MODELS)
Possible causes:
Pilot light is too far away from burner.
Solutions:
Adjust pilot location closer to oven burner.
OVEN BURNER FLAME IS YELLOW.
Possible causes:Range is not set for proper gas.
MY TOP PILOT KEEPS GOING OUT.
Proper top pilot setting is 1/8” high. If your pilot is adjusted higher, you will experience sooting under the main top area and pilot outage.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Verify that the burners are positioned properly on the orifice hoods and the burners are sitting flat on the burner support with tabs engaged in slots. Use a small gauge wire or needle to open ports. Replace the safety valve
    The safety valve is new, I just replaced it. The stove works fine. I am not sure how the secondary pilot should be positioned to activate thermocouple. Did you read the previous correspondence. please do?
Pilot not staying lit and keeps clicking on internal oven
What is the complete model number of your unit?
Dec 09, 2012 | Kitchen Ranges
How do light an old Tappan gas range?
If it has a pilot light: themobilian_411.jpga little gas comes out all the time on these. Just use a lighter. Warning for propane model have plenty of ventilation before attempting to light it. Propane is twice as heavy as air and nat gas is lighter than air. propane puddles and lingers while nat gas dissipates. If yours has a glow bar no need to light it:
Dec 11, 2010 | Tappan Ovens
Have a 1986 Fleetwood Park Model with a Magic Chef gas oven that will not light. The pilot is lit but the oven burner will not come on. Uses propane gas...it worked last year.
Propane is a "dirty" gas. That can sometimes result in a particle of debris getting lodged in a pilot orifice, causing a low pilot flame. Inspect the burning pilot, look to see that the pilot flame encompasses the thermocouple so that the thermocouple may get hot enough to open the gas valve. If the pilot is too low, sometimes tapping on the pilot assembly with some handy tool will dislodge any restricting particles from the pilot orifice and restore flame size. Make sure that the pilot or thermocouple have not been struck by some object and knocked out of place. If the flame and thermocouple seem OK, you may have a bad thermocouple. Before replacing the thermocouple, loosen and re-tighten it's connecting nut at the valve (follow the thermocouple "wire" to find the valve) , if the connection is poor, sometimes that will restore good contact.
Also to note: the pilot will be at minimum when the control valve is "off", the pilot flame size should at least double when the control valve is turned on. Be careful, that is gas you are working with.
Feb 03, 2010 | Magic Chef Kitchen Ranges
How do you start the oven on a Hardwick propane range?
The bottom part of the stove in the front has a drawer you pull out which has a broiler tray located there. You should be able to fold the door down and use a flash light to look inside . You will find a pilot light set-up there.
The stove I have has the pilot gas on all the time, so as soon as you turn on the gas to the range, the pilot gas is open to atmosphere.
I just light a match and reach in to where the gas piping can be seen and the pilot flame will light.
There is only a small amount of gas coming from the pilot orifice, so there isn't any danger lighting it when the gas is first turned on at the tank.
In fact you may have to wait a few minutes for it to light at first because the propane line maybe full of air. I usually light the top burners of the stove first and by that time the pilot gas for the oven is ok to light.
Jan 05, 2010 | Kitchen Ranges
I have inherited my grandfather's tappan gas range. It is in pristine condition, but my local propane company will not hook it up because there is not an oven safety shut off switch. How can I get it up to...
All it needs is a 'flame sensor'. It's small device that will 'prove' that there is a pilot light. Most older units had a thermocouple in the pilot flame that does the same thing. Any Heating and A/C company can help you with this.
Aug 08, 2009 | Kitchen Ranges
Magic Chef Range in camp trailer, pilot light in the oven works however, the burner will not light when turned on. No gas flows. Propane furnace works ok and the propane bottle is full. The surface burners...
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
or
May be the ignitor, replaced mine and it fixed it. A gas company guy told me that is common in Magic Chef ranges.
Thanks for contacting Fixya
Jun 14, 2009 | Tappan MGF500PBW Gas Kitchen Range
Problems with Brown Stove Works TM110-3 Gas Kitchen Range
http://www.brownstoveworksinc.com/pdf/gas_manual.pdf
there you go, the complete manual to operate your stove. look on page 16 to read about the pilot in the oven and how to proceed.
May 20, 2009 | Brown Stove Works TM110-3 Gas Kitchen...
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
I have an older model brown stove and cannot light the oven pilot
The oven pilot is accessible through the broiler door, (you're pretty much laying on the floor to light it) or through the oven bu removing the oven bottom panel. To remove the oven bottom, place fingers in holes near the door, and apply pressure to slide the bottom toward the rear, and lift when the front (by your fingers) comes free. Remove completely and set aside. You should now see a flame spreader (V-shaped metal pan) retained by one or two winged screws. Removing the screws allows removal of the spreader. This exposes the burner, complete with pilot. There is two tubing lines to the pilot assembly, one about 1/4 inch dia. and one much smaller. the one at the end of the 1/4 inch tube is the pilot. The piece at the end of the really thin tube is the thermocouple. You have to heat the thermocouple to get the gas to come on to the pilot. A match just won't do it as you need to apply a flame to the thermocouple for about 30 seconds or so. Heat the thermocouple until the pilot will self-sustain. When the pilot stays on on it's own, put it all back together. If you elect to just go through the broiler, again heat the thermocouple until the pilot will self-sustian.
Apr 08, 2009 | Tappan TGF657 Gas Kitchen Range
Kitchen Ranges Logo
364 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
