GE 3IGT660 picture shuts off after about 1 hour but still sound
My GE 3IGT660 tv, the picture shuts off and having the tv on for about 1 hr but you can still hear sound. Is it the picture tube?
  • Televison & ... Master
  • 1,689 Answers
I doubt it is the CRT unless it is absolutely verified by doing some tests. More than likely it is a thermo sensitive part that is going out of specs after the set warms up. The location of the part is most likely in the scan amplifier sections or in the power supply section.
You would have to bring the set in for service. An experienced
TV service tech should be able to determine the faulty part(s), and fix it for you.
Jerry G.
Posted on Apr 19, 2008
Old GE 27GT615 TV won't power on
Could be an open internal fuse or power supply failure
Dec 19, 2017 | GE Televison & Video
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
Dryer wont run if load is heavy, belt has cracks.
I just replaced the motor on my Whirlpool which was 12 yrs. old. The motor bearings get bad and let the rotor move off-center and bind. There is a thermal overload in the motor that shuts it off when it gets too hot.
My solution: new motor, the belt is unrelated to the problem.
Apr 25, 2009 | GE DWSR463EG Electric Dryer
Shuts off after about 1 hr and then we have to power off
The TV might be on sleep mode, so it will stay on for an hour, then turn off again. You'll need to turn it off through the menu
Apr 03, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Tv would not come on..sound then came on.. 1 hr later picture
That sounds like a faulty inverter board.
The inverter board is the high voltage board that supplies power to the back light lamps.
The inverter must be tested and eventually replaced.
Mar 09, 2009 | Astar LTV-3201 32 in. LCD Television
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Samsung TXM2796HF Turns off after 45 min to 1 hr
Probably some component in the power supply. Look for a leaking or swollen capacitor. They can change value during operation unlike a diode or transistor that either works or does not work. U might even remove and test all caps in the PS area and replace any one that is questionable regarding its specs.
Aug 30, 2017 | Samsung TXM2796HF 27" TV
Televison & Video Logo
Top Televison & Video Experts
