Question about Dell - PS-5141-2D (PS51412D) Power Supply
240V supplied when 115 selected
I inherited an old Dell, previous owner plgged it into 240V with 115 selected, is there a fix for this or do I need to replace the power supply? It appears that a cap has been blown, could there be more?
  • 149 Answers
These laptops come with international adapters you need not change anything ,just plug it.
Posted on Jul 07, 2010
I have an old air compressor that I have replaced the motor magstart and pressure switch on the motor is a 220 / 240 volt 5 horsepower motor it also has a low pressure oil cutoff switch does anybody have a...
Control: L1-SS-P-O-OL-OL-M-L2 In series, L1 is line 1, SS is start/stop switch, P is pressure switch, O is oil switch, OL is overload contact, M is magnetic coil (solenoid), L2 is line 2.
The voltage of M must be rated for the control voltage, across the line voltage (240V) or of a control transformer voltage, e.g. 240v/24v. A control voltage would be wired across the line, to L1 and L2.
Power: L1-T1-OL-M1, L2-T2-OL-M2. Line one to Line 1 on contactor, T1 on contactor jumpered to OL (overload heater) and out the overload heater terminal M1 to the motor terminal 1. Same for line 2, Line 2 to L2 on contactor, T2 on contactor jumpered to OL (overload heater) and out the heater overload terminal to M2 motor terminal.
The heater overload relays needs to be chosen by the motor full load current, a chart is given with a motor starter on selecting heater size. If no chart is available, go 115% of the motor FLA (full load amps) to select a heater size. E.G. 25 FLA motor at 115% is 28.75a. Sorry, no schematic available now, draw your own from this info. If using 3 phase, add the third line as duplicating one other line1 or line 2
Mar 10, 2015 | Air Tools & Compressors
I want to run this compressor "RITIN RT2012" 2HP 12L (1.5kW) compressor. It's a 110V AC drive unit and I have 240V. Can I run it or do I need to convert the Power supply.
You can't just run it on the 240 Volt supply. Check the motor nameplate. If it says it is rated for 110/220 or 115/230, or 120/240 Volts, then it is capable of running at 240V. This will require a wiring change, and you may need a larger size power cord.
The electrical diagram should be on the motor name plate or under the cover to the electrical terminals on the motor.
May 25, 2011 | Air Tools & Compressors
Used computer needs reset for different owner. i just inherited an old dell laptop and would like to delete all signs of previous owner. i cant do anything though because i dont have the password, they...
If the cmos is password protected, then you must reset the cmos. The best way to remove any signs previous owners is to reformat or do a system restore. You ca do this with the disks that came with the computer, you should put the system restore disk in and be on your way. Just follow the on screen instructions and you should be all set.
Hope this helps
Sep 25, 2009 | Computers & Internet
What does the red switch on the back of my dell dimendion e510 do
Don't! That's for foreign voltages. It should say 115 and 230. The 115 is for 120V systems while the 230 is for 240V systems. The actual voltage you get is usually a little less than ideal, so they design power supplies to accept a lower voltage.
Jul 25, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dayton Fuel Trimmer Shop Heater
flue diameter is 4 inch
Propane Unit Heater, BtuH Input 30000, Full Load Current 2.1 Amps, Gas Inlet 1/2 Inch, Flue Diameter 4 R,V, Motor Power Rating 1/30 HP, Free Air Flow 700 CFM, Height 27 1/2 Inches, Depth 27 5/8 Inches, Width 14 Inches, OC Mounting 8 5/8 Inches, 115 Volts, Energy Saving
Nov 20, 2007 | Dayton (3E379) Heater
Kogi L4AX 14" LCD Monitor.
jim
my supply has the following specs.
LIEN CHANG
BSA-35-115
AC input- 110-240v 1A  47-63Hz
DC output 10-17v  3.5A
Nom. V 12v
Nom current 2.9A
output power 35A max.
With this you can likely find a universal "brick" that covers your needs
Jay
Oct 14, 2007 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Computers & Internet Logo
70 people viewed this question
Alun Cox
