Question about Thermador 30", 36", 42", 48", 54" Wall Hoods, PH
My customer has a Thermador H26HQS range hood. When the fan motor became noisy, he obtained an identical replacement for the motor, which I installed. After installing it I noticed that the speed control didn't work. (I did not check at the time whether it worked with the old motor.) I thought that maybe the speed control was faulty, so I ordered a new one and installed it, but that didn't fix the problem. We then tested the old motor with the new speed control, and there was no speed control with that arrangement either! I checked the 10 MFD motor capacitor with my capacitor tester, and it tested O.K. Furthermore, with the capacitor out of the circuit neither the old nor the new motor will self start, so that tells me the capacitor is functioning at least to that extent. This is all very puzzling. Any idea what can be keeping the speed control switch from controlling the speed of the motor?
  • Dave Brast Jul 08, 2010
    My customer has a Thermador H26HQS range hood. When the fan motor became noisy, he obtained an identical replacement for the motor, which I installed. The new motor is quieter, but after installing it I noticed that the speed control didn't work. I thought that maybe the speed control was faulty, so I ordered a new one and installed it, but that didn't fix the problem. We then tested the old motor with the new speed control, and there was no speed control with that arrangement either!
    The motor speed control switch is Thermador part number 19-11-915-01 (which crosses over to Bosch 414430) and it's operated by a knob. You turn the knob and it clicks on, and then you rotate clockwise for slower speed - when it's working. Right now the only thing that happens is that it turns the motor on at high speed. Further clockwise rotation does not change the speed.
    Keep in mind that neither the old nor the new speed control switch will control the speed of the new motor, and the old switch will not control the speed of either the old nor the new motor. The only combination we don't know about is the old switch with the old motor.
  • 3,083 Answers
Wow, this is a situation, for sure. If the motor has a 3 wire system, the ground could be connected to the middle winding, and then both speeds would be the same. I would really check the wiring to the motor, as well as the switch. That's all I can think of, unless there is a crazy short, somehow.
Posted on Jul 08, 2010
  • Dave Brast Aug 17, 2010
    I found out what the problem was. When I replaced the blower motor, I couldn't be sure which blower wheel went on which end of the shaft, so I made a guess based on the shape of the vanes. I guessed wrong. If you switch the blower wheels, then there's not enough drag on the motor and that prevents the speed control from having any effect.
    What told me that this was the problem was looking at the blower wheel on the forced-air furnace at my house. I observed the configuration of the vanes on it and then turned it on to see which way it rotates. When I did that, it was obvious that I had the blower wheels on my customer's range hood reversed. Live and learn.
    Thought you'd like to know.
  • 11,800 Answers
The speed module is very simple: a triac with some extra components to modulate it, it's build exactly the same as the one from a vacuum. That speed module is controlled from the touch screen - are you sure the touch screen is operational? That's relatively easy to test - just put a potentiometer where the control signal goes and see if moving the potentiometer changes the speed.
Posted on Jul 07, 2010
    Good try, but this range hood (Thermador model H36HQS) has no touch screen. The motor speed control switch is Thermador part number 19-11-915-01 (which crosses over to Bosch 414430) and it's operated by a knob. You turn it and it clicks on, and then you rotate clockwise for slower speed - when it's working. Right now the only thing that happens is that it turns the motor on at high speed. Further clockwise rotation does not change the speed.
    Any idea what could be going on?
  • Azrael SRL Jul 08, 2010
    So which model is it:  H26HQS or  H36HQS , because i never heard of a Thermidor model called like that and i can't find it in their site.
    Never mind, it has a mechanical switch to control the module - have you checked the switch ? By rotating it you should be able to measure a change in the resistance (in kiloohms) that is controlling the module. Just put an AVO meter to its plots and check that - most likely the switch is internally shorted and should be replaced.
How to change the switch on a thermador UCV36
Thermador Appliances ' Customer Support, Service, Repair ...
www.thermador.com/support
ThermadorThermador customer support is your appliance resource for FAQs, use & care videos, product registration, warranty information, service, repair and more.
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=63
ThermadorWe recommend that a Thermador authorized servicer change the seal ... refrigeration appliances, especially when the cooling function is switching on or off.
How do you install the up/down switch in a Thermador ...
www.shopyourway.com > Manage My Life > Questions
Get shopping advice from experts, friends and the community! I have a Thermadordowndraft vent model number RDDS30VRS that I need to replace switch part ...
Vent snorkel stuck in up position, fan works fine - Applian
Dec 21, 2015 | Thermador Kitchen Ranges
Capacitor
If the fan spins freely you are correct.
Aug 24, 2014 | Thermador Kitchen Ranges
How do i fix a noisy range hood?
IT THE NOISE COMING FROM THE FAN RUNNING? IF IT IS YOU NEED TO CHECK THE SCREW THAT ;ATTACHES THE FAN BLADES TO THE SHAFT. IT COULD BE LOOSE. ALSO CHECK THE SHAFT TO SEE IF IT IS WORN AND MOVES FROM SIDE TO SIDE. IF IT DOES YOU WILL NEED TO REPLACE THE MOTOR.
May 23, 2014 | Baumatic Kitchen Ranges
Noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Dec 11, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Thermador Downdraft blower Fan Not Working
could have serveral problems / if under counter or in back of range . the last two i had the control buttons w wire harness needed replacement /another required the pc board in connevtion box ( under counter in right cornor. also look for poor connections in the power box .
Dec 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Suddenly became very noisy, unit has only been
Sounds like fan has become faulty - suggest contact manufacturer directly
Aug 07, 2009 | Broan-NuTone Intermediate Whispaire ...
Nutone WA6500 range hood fan motor noisy
We have the same product, 18 months in use and the very noisy motor has finally seized up. I contacted the manufacturer and was advised that I need a new motor, motor mounting bracket and fan rotor. The agent was not able to quote me a price for the parts but stated that even though my 1-year warranty had expired, if I faxed them a copy of the original sales reciept they could possibly send me the parts for free under the original warranty agreement. I've done as they asked but haven't received a reply as yet. After reading about all the problems with this product I'm tempted to dump the whole unit and try to find another manufacturer that has a reliable and QUIET range hood.
Dec 16, 2007 | Broan-NuTone Intermediate Whispaire ...
Thermador 30", 36", 42", 48", 54" Wall Hoods, PH Logo
557 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
