Question about Maxent MX-RS215 DVD Recorder
Front panel controls do not function. Remote still controls the recorder normally with good results.
  • 472 Answers
I am not familiar with the recoder, but check it hasn't been put into a child lock mode.
Failing that, do a hard reset unplugging the unit for 10minutes.
Posted on Apr 18, 2008
I have a magnavox dvd/vhs recorder/player and need the RCA Universal controller code number
You have this backwards. Your RCA universal remote has a "code search" feature that lets you try to find a code that will control some or all functions of your Magnavox DVD/VHS recorder. If a thorough search does not produce a result, you may have to try another remote.
Aug 29, 2014 | Televison & Video
You have somehow configured the remote to control another DVD recorder, this is useful if you have multiple recorders you want to control with a seperate remote for each one.
To set it back to Remote DVD 1, hold the enter button in the centre of the remote along with the number 1 for 5 seconds.
Hopefully now it will control your recorder properly.
Oct 24, 2007 | Panasonic DMR-E55 DVD Recorder
Lost remote control how to i move the arrows ithout control
Normally the CHANNEL UP / DOWN and the VOLUME UP / DOWN buttons on the front of the TV set itself will function like the arrow keys on the remote when you are navigating the TV's ONSCREEN MENU.
Otherwise, you can always go out and buy a universal replacement remote control and program it for use with your TV.
I hope that helps, good luck and take care.
Aug 13, 2011 | Televison & Video
Need 3 digit code for controlling sony rdr-gx7 dvd recorder with my time warner cable remote.
This is a common problem for the Sony RDR-GX7 dvd recorder.
It seems to occur with various remotes (DirectTV, Bell ExpressVu or in your case, the time warner cable remote).
In most cases, the problem can be solved by using a different remote frequency from the system menu as follows:
Insert a dvd and make sure it is not playing (stopped).
Enter the System Menu then / Setup / Options / Command Mode (this can be done from the access panel on the front of the unit). There are 3 possible values, (DVD1, 2 or 3), try changing it.
Then enter one of the suggested codes for your Warner remote (in my case, for Bell ExpressVu I selected the DVD1 command mode
and I used 883 as the 3-digit code. The up and down arrows are not functional with this code but I bypass this problem by entering the menu item number. Good luck!
Feb 14, 2010 | Sony RDR-GX7 DVD Recorder
I have a new ESTR 200 that has been in a closet for a couple of years. Very little seems to function well. The presets will not hold if I turn the system off or if I turn to another function. Record...
I assume we're talking about the Element ESTR200...
A turntable will not work with this receiver unless the TT is already preamplified. No Phono Preamp in this unit.
From the manual...
Store a station
1. Press the FM/AM button on the front panel (or
the AM/FM button on the remote).
2. Select the station you want to store in memory
by the methods described above.
3. Press the MEMORY button on the remote
While "MEMORY" is glittering, press number
buttons on the remote for the station.
If the Memory indicator on the display turns off before you preset the station selection, Press Memory again.
Manual preset
1. Select the band wave by pressing FM/AM
2. Turn to a radio station(see "Manual tuning" on
page 8 in details).
3. Select a group (A- D) of preset stations. This
group will be displayed on the front panel.
For example: "A".
4. Press MEMORY on the remote control.
"MEMORY"will appear on the display.
5. While the word "MEM" appears, input your desired preset number (1-8 ) by using the numeric keys on the remote control to store the radio station. For example this number is "1", the station is stored as "A1".
A new setting can cover the former one.
This memory is kept before next reset.
Retrieving preset stations
1. Press FM/AM button on the front panel or the
remote control to select tuner mode.
2. Press A/B/C/D button on the front panel or the
remote control to select the group of preset stations that you require.
3. Press the numeric keys on the remote control to select the number of preset station that you require. Station selected is displayed on the front panel.
4. By the same way, you can select other stored
The remote control does not operate the unit.
-Another function is selected on the remote.
Press the correct function button.
-No batteries installed. Install the batteries before
using the remote.
Be sure "+" and "-" marks of each battery match the symbol on the inside of the remote battery compartment.
-The batteries are exhausted. Replace all batteries.
-The remote is not pointed at the remote control sensor on the main unit or there is an obstacle between the remote and the main unit.
-The remote control is too far away from the main
unit, move closer.
Dec 05, 2009 | Audio Players & Recorders
Entire front panel does not work, but responds to control.
have you pulled the plug from the wall for a few minutes?
also, some vcrs will eject the tape when the RECORD button is pressed on the remote, and a tape is inside that has the record tab REMOVED!
good luck
Feb 07, 2009 | RCA VR622HF VHS VCR
Normally this is a good indication of a stuck button on the set. With the set off, try working each of the control buttons. You should be able to feel teh button engage. If one feels like it does not work, that is the likely culprit and it should be replaced.
Let me know your results.
Sep 07, 2008 | Televison & Video
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Remote no longer controlls recorder
Remote can be used to control more than 1 recorder, on the remote press enter and 1 simultaneously, this should switch the remote to control dvd 1.
Oct 23, 2007 | Panasonic DMR-E55 DVD Recorder
Maxent MX-RS215 DVD Recorder Logo
106 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
