Question about Samsung BlackJack II Smartphone
Blackjack II internet stops working....
Hey man thx for the problem solved on the blank start menu, i got another one...
this phone is for an employee of mine, im not sure if all the problems on this phone stem from her just tinkering with it all the time, or if its the phone. i have to reprov Goodlink about once every other month, and now it seems the internet on her phone has stopped. how and where can i go on the phone settings to make sure there is nothing wrong with the phone settings before i make a call to AT&T. when you try to open a webpage, i get an error message something like: remote connection has been reset. if this keeps up im just gonna start doing a hard reset on it every time she brings it in! it makes reprov'ing Goodlink hard cause once the reprov is done, it just hangs durning the download process of the services.
  • 1 more comment
  • dogbyte Apr 20, 2008
    yessir thanks for all the research, i have about 4 employee's with these phones, and i have alot of problems, ill revert the goodlink version back to the older one, and hopefully that will fix the problems. i will also delete the ims connection to make sure it doesnt want to use that on its own. hey man, thanks for all the help.
  • Anonymous Mar 01, 2009
    same thing happening here. but i cant do anything to fix it
  • Anonymous Mar 25, 2014
    I have tried so many times downloading whatsapp but I do not succeed I don't know what seems to be the problem it just says message failed.
    Problem Solver:
  • 13 Answers
Hello again dogbyte!
Fantastic! I'm thrilled to here the first fix went well!
Here's the deal on your most recent question...(Please excuse the long post - I'm intimately connected to this particular issue, so I figured I'd try to share some of the background on it.) Are you using GoodLink version 5.0.x by chance?
Our team has actually submitted bug reports to both GoodLink and AT&T on this issue. The BlackJack II has a connection setting called "AT&T IMS" (supposedly there to offer additional features on the AT&T network sometime soon.) Unfortunately, when GoodLink 5.0 is provisioned on a BlackJack II with this particular GPRS connection setting, internet problems are basically guaranteed.
The BlackJack II will successfully connect to the internet to download, install, and synchronize GoodLink. The first time the device disconnects from data services (i.e. - roams out of data coverage, the device is powered off, the device hits critical battery, etc.), data will not reconnect.
You've got two options:
I. Delete the "AT&T IMS" GPRS Connection Setting
1) Navigate to Start > Settings > More... > Connections > GPRS
2) Use the multi-directional pad to highlight the AT&T IMS connection.
3) Click Menu > Delete
4) Press Yes to confirm the delete.
5) GoodLink and Pocket IE should be able to connect to data services again in 5-10 minutes or less.
Note 1: Solution I needs to be performed again if the device is hard reset. If your user(s) need to hard reset the device upon occasion, you may want to make the instructions above readily available to the user, OR consider option II to prevent confusion (if option II is available).
Note 2: Changing the Access Point Name on this connection from "ims.cingular" to "wap.cingular" can also solve the problem, but it's not always consistent.
I. Provision the BlackJack II with GoodLink 4.9.3.x.
This last stable release for GoodLink 4.9 seems operate without the same data issues. Although Good 4.9.3.x doesn't offer some of the more robust features of Good 5.0 (such the ability to send email attachments from the device or RSS feeds), we've been deploying Good 4.9.3 to BlackJack II users since we discovered this issue a little over two weeks ago, and it's definitely made a postive difference.
Another Potentially Related Issue
You may also notice surprisingly frequent "403 Forbidden" messages in Pocket Internet Explorer on AT&T devices (including the BlackJack II).
All Internet Explorer traffic from an AT&T device goes through AT&T's proxy. AT&T's proxy apparently includes a rule that disconnects a user if they haven't used the web for a specific period of time (I've heard 2 hours, but that may vary). Unfortunately, AT&T and Microsoft haven't figured out a way to simply open that Pocket IE connection back up... at least not easily.
If you're seeing "403 Forbidden" errors, you'll want to do one of the following to close and reopen the data connection:
I. Reboot the phone
(closes and reopens all of the connections)
II. Manually disconnect cellular data
1) Click the Power/Quick List button on the top of the BlackJack II. The "Quick List" should appear
2) Select Wireless Manager
3) Click Menu > Disconnect cellular data
(You should notice the "MEdia Net" indicator under "Phone" change to "On")
4) Click Done to return to the Homescreen.
5) Open Internet Explorer again and navigate to the desired page.
Note: Although the "403" error doesn't necessarilly interfere with GoodLink connectivity, manually disconnecting cellular data will. If you don't open IE an actively open a data connection to reach the web, you'll probably want to open GoodLink and do a quick manual Send/Receive, just to make sure that it re-establishes its connection.
Sorry for the book! I hope one or both of these help.
Have a great weekend,
The MoDev Kid
Posted on Apr 19, 2008
Remote party has ended this connection. Will pop up on my phone when I try to connect to the internet
Posted on Dec 17, 2008
Hey my samsung black will not send or receive pictures. whenever i try to it says "unable to connect, please verify you profile settings" can you help me
make sure you are able to recieve pictures by AT&T service because it requires the internet to download the pic. you can see if you do have it by if you have a E or 3G on the top of your main menu screen, hope this was helpful:)
Nov 05, 2009 | Samsung BlackJack II Smartphone
My blackjack ii just stopped working. I turned it
IT sounds like a software glitch.
the phone will most likely need a hard reset to repair it.
Sadly this will delete all of the personal data on your phone, and reset the phone to its factory defaults.
To perform a manual Hard Reset, press the Up Navigation key and the (Power) key.
Oct 24, 2009 | Samsung BlackJack II Smartphone
Blank screen
go to the service center of Samsung and get the firmware re-installed.
Sep 06, 2009 | Samsung BlackJack II Smartphone
Strange BlackJack II Problem
I would recommend hard reseting it. That should reinstall any standard programs, files, and applications. Good Luck!
Feb 13, 2009 | Samsung BlackJack II Smartphone
Start menu blank
Hi Bhanzy,
Great question. Nothing was deleted, this is actually a software bug in Windows Mobile 6. This error usually occurs when your start menu is switched from "Grid view" to "List view". Give this a try:
1) Remove the battery from your device for about 10 seconds.
2) Reinsert the battery and power the device back on.
3) Click Start
4) Navigate to Settings > Display > Start Menu Style
5) Change this setting from "List" to "Grid", then press Done
6) Click the Home key to return to the homescreen, then click Start to check start menu functionality.
(NOTE: You'll only be able to successfully open the start menu ONCE after rebooting. If you open the start menu, then exit, the start menu will likely revert to a blank gray screen. If this occurs, start back at step 1.)
Let us know how things go!
Thanks,
Jonathan
Nov 04, 2008 | Samsung BlackJack II Smartphone
Blackjack 2 speed
If your phone is going slowly you probably have multiple applications running in the background.
1. go to start ->applications -> task manager
2. there will be a list of applications that are running
3. press "stop" for the applications that you arent using
hope this solves you problem
Oct 26, 2008 | Samsung BlackJack II Smartphone
VIPer6
If someone really solves your problem the click on the fixya label.
Please don't praise him in a new problem area.
It's a humble request please comment there only don't create new problem topic's.
Now close this problem by clicking fixya.
This wastes other's time.
Oct 05, 2008 | Nokia N72 Cellular Phone
Samsung Blackjack II Screen Stays Black
I have a solution. Call at&t. they will send you a new one. I have had my phone for 5 months and it happened to me also. There's a warranty on the phone itself that covers it from the day "you" started using it. I bought mine from a friend. Cool!! It should be here in 5 days free shipping.
Blackjack II Geek.
May 18, 2008 | Samsung Blackjack SGH-I607 Smartphone
Blackjack II blank start screen
Hi dogbyte,
For some reason, certain Windows Mobile (Standard) devices don't like "list" format for the Start Menu.
Give this a try:
1) Remove the battery for 1-2 minutes. (This allows any cached memory to clear)
2) Power the device back up.
3) Before openning ANY other apps, navigate to Start > Settings > Display > Start Menu Style
4) Change this value from "List" to "Grid"
5) Click Done twice, then click the Home key.
6) Give the Start menu another try. (Does this resolve the issue?)
Another forum suggested that Windows Mobile seems to be a little picky about which application appears first on the Start Menu. If you have any custom applications installed, it's possible WinMo's start menu just isn't playing nicely.
Hope this helps!
Apr 10, 2008 | Samsung BlackJack II Smartphone
Samsung BlackJack II Smartphone Logo
1,670 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
