I have a Powerbook G4. The hard drive is having a problem. Target disk mode is always frozen in the middle of transfer. It took 3 days and it only copied 2 GB of data. Is it any way to recover it? Thanks.
    President:
  • 1,561 Answers
I advice you check the service manual that came with your device, the solution to the prescribe issue should be address in the service manual, using this will be of good guide.
Take care.
Posted on Jul 15, 2010
I want to retrieve data from a Powerbook 3400c via ethernet. I have a Macbook Pro running Snow Leopard and an iMac running OS10.4
I think the 3400c has a Firewire port, which would allow it to startup in "target disk mode" where it would be just like an external hard drive. That is, hold T at startup to get TDM. I have a Pismo with Firewire but I think the color 3400 is older.
With MacBooks and OS10.5 or later (you are at 10.6) you can do this with USB, also. So it might use the MacBook as the external drive of the PowerBook to transfer files in Finder.
Otherwise, you can turn on AppleShare on both and use Ethernet to transfer files slower.
-Ken
Apr 11, 2010 | Apple PowerBook 3400C Mac Notebook
MacBook won't recognize my Lacie Rugged Hard Disk. Disk utility will see it but won't verify it nor will it repair it. says it needs to be reformatted yet it won't even let me initialize it. it is brand...
Is your MacBook as fast as the Lacie Rugged Hard Disk is?
Because solid state drive wasn't available on MacBook Pro at the initial time when it launched. Hard drives on all current Apple laptops are equipped with Sudden Motion Sensor technology. In fact, the Apple laptops that came with Sudden Motion Sensor are: All Intel-based Apple portables such as the MacBook, MacBook Pro, MacBook Air, PowerBook G4 computers starting with PowerBook G4 (12-inch 1.5GHz), PowerBook G4 (15-inch 1.67/1.5GHz), PowerBook G4 (17-inch 1.67GHz), and iBook G4 computers starting with iBook G4 (Mid 2005) have Sudden Motion Sensor technology. You MacBook may not have come with that technology that could be the reason you are unable to connect it.
Sorry mate... too many limitations on
Feb 24, 2010 | LaCie Rugged All-Terrain (301017) Hard...
Another waterlogged 12" PowerBook story
Sounds like you have done all you can. The hard drive should be ok and still work in an external case so you can transfer the data to a new machine. Good luck!
Feb 19, 2010 | Apple PowerBook G4 Mac Notebook
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Powerbook G4 blue screen on start up
Basically some causes of blue screen is the RAM check the RAM remove first maybe it is clogged by the dust. Remove the dust of the memory stick and insert it back to you computer. Usually of you have this problem again you need a recovery disk. Load a windows CD to your CD drive you need to boot and repair the windows.
Regards
nicole
Oct 03, 2009 | Apple PowerBook G4 Mac Notebook
When i stert my g4 imac,s screen was became blue
try these articles:
http://support.apple.com/kb/TS1411 also boot to cd and run disk first aid. If it can repair the you have 3 options 1: try 3rd part utility program such as disk warrior or drive genius. 2: try to back up.. you can use target disk mode and hopefully you hard drive will mount, if you dont know how to do target disk mode do a search. if not drive saver can save data but it's expensive 3: erase and install
Jul 01, 2009 | Apple Computers & Internet
MAC G4 won't boot - Blue screen appears
Hi Sorry to hear you are having troubles,You will need a firewire 400 cableOK, first thing you must do is reboot the eMac in TARGET mode, this means it will be recognized as an external disk. To get the eMac in TARGET mode, you must be sure the eMac is turned OFF and has a functioning keyboard connected.Power on the eMac and very very rapidly press the ( T ) key on the keyboard, be sure the caps lock button is not pressed. If all goes well, you will see the firewire logo appear larger than life on the screen.( If you are unable to get into TARGET mode, it is highly probable that the mother board of the internal hard drive is damaged and preventing the eMac from entering TARGET mode, sorry, that's the end of the line..)Once you enter TARGET mode on the eMac, connect the firewire cable to your G4 PowerBook, you can do this either while it is running or when it is off and then turn it on.
You should see the volume of your eMac internal hard drive appear on the PowerBook desktop...sometimes you need to open Disk Utilities and repair or mount the drive manually.If this all works well, copy the required files directly to your PowerBook...After that, power off both machines, disconnect them and reboot the eMac using a CD or DVD to reformat and reinstall a new system.
Mar 30, 2009 | Apple eMac G4 Desktop
PowerBook G4 only DVD player spins
It really looks like the logicboard is cooked. You are getting power to the DVD, but something is arresting the start process as indicated by the fan starting and stopping. If your hard drive isn't spinning and the fan isn't starting and there is no video, you can either replace the logicboard or get a new computer. You might try reseating the RAM, which could have been knocked lose, but you probably won't get any help from that because at least some of the ram is soldered to the board, so you definitely have some still operating (or able to operate if there was a working board).
Logic boards are about $100-150 on eBay and since you have it open, you might as well swap it out. I think the G4 is still a great computer, so why not do it.
Sep 13, 2008 | Apple PowerBook G4 Mac Notebook
Start up
Try rebooting into safe mode, then emptying your trash and restarting to normal operation. In safe mode, all internet is dissabled, so dont go trying to fire up the bluetooth or wi fi. The systme trashes unneccessary fonts and cache that can complicate the boot up.
If that does not remedy, try getting anothe rmacintosh running 10.3 or higher and a firewire cable. Boot your powerbook into TARGET DISK MODE and from the other mac go to UTILITIES and run permissions on your powerbook ( it should be on the left pane in DISK UTILITIES )
These are a few quick fixes, if they dont remedy the situation, keep me posted and try providing more info, like which version of osx, what you were downloading, and what apps were open when it was last functional.
Keep me posted.
Nov 19, 2007 | Apple PowerBook G4 Mac Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
