Question about GE JVM1790 Convection / Microwave Oven
How to change light bulb?
GE Profile model #JE1590
SOURCE: bulb replacement
I realize this is late but for other's here it is:
If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb.
Posted on Sep 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: JE1590 light bulb replacement
On this model you need to remove the outer cover.
The bulb mount will be located on the right side next to the side wall of the cooking cavity.
It's above the damper door assembly as shown in the attached drawing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
The bulb should be available at local grocery stores, hardware stores, and places like Wal-Mart and Lowe's.
Posted on Sep 27, 2008
  • 197 Answers
SOURCE: change light bulb in microwave GE Profile
Please do not attempt to repair your m/wave, taking the cover off to find the lamp unit is very dangerous, their is still electrical charge in the unit even when its turned off, plesae take it to an approved engineer.
Posted on Oct 04, 2009
SOURCE: One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Posted on Jun 28, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: looking manual on how to
See pages 35 & 36 of the owner's manual here.
If your lights are struck on, you'll need circuit board repair. Details are here.
Posted on Aug 21, 2010
How do i change lightbulb?
You will need to remove the outer cover to access it.
The bulb is located in the air cooling duct on the right side of the oven.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE JE1590 Convection / Microwave Oven
Need to replace lamp in GE Profile microwave model JE1590SH02
PMG!!! I called GE and was told that changing the light bulb is not a consumer replaceable part!!! Are you kidding me!! She told me I had to have a GE tech come out. Makes you want to buy GE appliacnces, right!
Mar 01, 2010 | GE Microwave Ovens
How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Jan 13, 2010 | GE JE1590 Convection / Microwave Oven
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JE1590
A special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Some folks just use a hammer to tap and loosen the screw, then a small flathead screwdriver can be used to remove the screw, as shown in the photo.
Another creative solution is to use a hacksaw or a Dremel tool to carefully cut a slot in the head so a flatblade will fit it.
Sep 25, 2008 | GE JE1590 Convection / Microwave Oven
Lamp bulb is out
You must remove the outside cover of the microwave to change the bulb.
The light cover inside the microwave should not be removed. It is held in place with contact cement.
For disassembly help see:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The bulb should be available at most grocery stores, home centers, hardware stores, and places like Wal-Mart.
Sep 24, 2008 | GE JE1590 Convection / Microwave Oven
Sep 22, 2008 | GE JE1590 Convection / Microwave Oven
Ge spacemaker
Here is info from another person having that problem on fixya.
I had to go down to an appliance parts shop in PHX to get the lamp after I had taken the microwave out of the corner cabinet and disassembled it. Found the light bulb toward the right front top corner after taking the frame all apart. It was a pain but it's done !! BTW, I'm a female licensed electrician and GE told me over the phone that I would have to call a service tech to come replace the lamp (about $200). I searched the websites for the part number to get the lamp (it wasn't printed on the lampbase), searched for local appliance part stores and found the part number (WB36X10131) to pick it up. The "cavity" lamp cost me $8.65 then the cost of the gas (about 40 miles) to get it but my micro was back up and running before Thanksgiving dinner --just in time to make Lean Cuisine !!! HAHA Thanks for your reply Guru !! Have a great weekend !! Julie
Mar 04, 2008 | GE JE1590 Convection / Microwave Oven
GE Profile JE1590--light bulb
The type of screw attaching the casing is called a Torx Tamper Proof screw. You need a Torx Tamper Proof Screwdriver to remove the screws. These screws and screwdrivers come in various sizes. I think the size you need is T20H.
Nov 19, 2007 | GE JE1590 Convection / Microwave Oven
GE JVM1790 Convection / Microwave Oven Logo
117 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
