The boiler does not fire when hot water is selected although the red light is on. However the boiler fires ok when central heating is switched on and this does then heat the water. Is the problem in the programmer
    President:
  • 1,515 Answers
Hi. and you are correct, if the boiler fires when the controller is set for central heating to come on, but does not fire when calling for hot water, the controller is either faulty, or not programmed properly. This is what tells the boiler to do on command, so, this is all that it could be.If you no anything about this controller as far as how it is set up, is it a programmable one, voltage on it, does it have wiring terminals on it that are labeled and can you get to them? If you can, and the wires are labeled, you can jumper them out to see if you can bypass the circuitry and get it to fire up on a call for hot water. This is the way to test it, very easy. You have to look at the wiring schematics to find the wires that are 1-hot and 2- hot water control. Jump across the 2 wires and if it fires, the controller is faulty. Careful if this is a high voltage controller as 120/208/230 volt. Check this out first. It can still be done, you just have to be careful not to ground yourself out. It maybe 24 volts. If it is higher voltage, you can kill power and get a insulated lead/jumper wire with clips on each end. Clip them to the terminals you want to jump out and turn on power. This way you are not touching anything. Please let me know the outcome on this and please when rating me as being helpful to you, be kind. I thank you. I will be here if you have more questions or need my help.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Jul 07, 2010
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
Boiler ok for hot water but no heating
What boiler do you have and is the controller a radio controlled thermostsat
Dec 14, 2014 | Water Water Heaters
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Gas Boiler will supply /fire up to supply Central heating When Room thermastat turned up and switched to Heating and Hot water. When on Hot water Only will not fire up even though thermostat on hot water...
most likly or a shorted wire unhook the wire from the boiler see if it stops then if it's still is on it's in the boiler if off try unhooking it at the t-stat on the heater this should narrow it down for you dan
Jul 19, 2008 | Heating & Cooling
Heating & Cooling Logo
149 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
