Question about Cell Phones
GIVING ME MESSAGE "NO LINE" ON ONE OF THE TWO HANDSETS
  • 3,230 Answers
Well first of all tell us the brand and the model number of your phone. may be you need to change the battery of your second headset. Post comments for further help or information.........
Good Luck!!
Thanks
Posted on Jul 07, 2010
  • architects56 Jul 07, 2010
    PRESIDIAN 600 CORDLESS 2 HANDSET PHONE.I SWITCHED THE BATTERY WITH THE ONE THAT IS WORKJING. THE ONE THATWORKS STILL WORKED BUT THE OTHER STILL SAID "NO LINE"
How do I change the message on my answering machine?
Which Uniden phone do you have? for some models, you access the Answering System menu from the base; on others, you need to be holding the handset. The generic steps are below.
On the appropriate part of the unit, make sure that the phone system is in standby (no active calls on any handset). Then press Menu. Use the arrow keys to find the line for Answering System. Press OK. Navigate to a line about Greeting and press OK. You should see (and select a line) for Recording message. You'll be prompted to ensure that you want to record a new message. If you are using the handset, hold the unit about 6" away from your head. After confirming that you wish to record a new message, speak your new message clearly. When you are done, press End. The unit will cut off the recording if your message was too long. Make sure to save the message. Then go back up in the Menu system and look for a line for "Play back Greeting". If the message isn't clear, start over.
I hope this helps. Please add a comment with the model number of the phone for specifics for your manual. Some DECT phone manuals are available here: http://www.uniden.com.au/australia/cs_operating_manuals_phones.asp .
Nov 21, 2015 | Uniden DECT 6.0 Cordless Phone
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
Handset no line
Sound like that line ain't active or handset is bad..
Jun 05, 2012 | Lands Phones
Motorola L404 DECT 6.0 Cordless 4 Handset Phone & Answering System . Was working fine, and then one day just stopped. When we pick up any handset the error message reads "no line."...
I had the same message. After a length investigation, I found it was the phone line and not the phone. After having the phone line fixed, the phone worked fined.
Nov 02, 2011 | Motorola Lands Phones
Handset out of range
I'll give it a shot. Have you tried re-regestering the handset? Press and hold down the "end" key (on most models it looks like a red handset) while holding that key down, press and hold the # key, after a few seconds the unit should beep and show:
(SYSTEM RESET)
Deregister HS
BaseUnavailible
Useing the four-way key select "Base unavailable" and press the menu key The LCD display should then show :
"Which Base?"
Base #1
Select base one and then the display will show
"Base Unavailible
Yes
No
Select "Yes."
Your handset is now unregistered. To re-Register the phone to the base do the following. If the base unit has a charging cradle, just set the handset in it and it should register on its own, if you have a cordeed base, or the unit will not register when you set it in the cradle on the base go to menu and select register handset, then press and hold the # key on the handset for 2 - 3 seconds, it should beep and then start the registration process. If you have 6 handsets registered to your base, you will need to de-register teh non-working unit from the bases memrey before you will be able to re-register the handset.
Jun 14, 2010 | Uniden DECT 6.0 Cordless Phone ID
Error message -using handset (no handset on the machine. mfd - 1515
If this appear for the first time see the follow, if this started to appear after a time of usage you will need to call a Ricoh technician, sorry but i cannot gain some help in this type of problems.
see do you use a cord with two wires or four for Ricoh when using some telephone centrals like a Panasonic it's better to use a two wired cord for the line, if this still do not help, you will need to call the telephone central technician to set the line for the Ricoh fax.
Nov 17, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Line in Use Message on Screen- GE 28213 Series DECT 6.0
to get a line you have to have the handsets in the stands or you have to use the end button to close the call
the phone stands are the battery charger and need the handsets need to there all the time-- unless answering a call --the operation is
all the handsets are in the stands being charged
a phone call comes in by lifting a handset to answer, the call is connected automatically without pressing the talk button
on finishing the call you press end but if you do not replace the handset in the stand but leave it say on the table , when you get another call you have to press the talk button to be connected as it was not picked up from the charger stand and so will not connect automatically when one handset is talking , all the other handsets can listen in and if one call is not ended , there is a line in use sound and no line
it is all in the owners manual and if you didn't get the manual , go google and down load it from the manufacturers web page as a pdf version for printing
Mar 07, 2017 | Uniden Cordless Phone
"searching" message
the handset is defective, the receiver has failed, no signal triggers the message.
Feb 11, 2009 | Uniden Cordless Phone
GE DECT 6.0 Model 28111EE2 is not working, registration failed message
I had the same problem, and restoring to default settings did not seem to work either. I just opened the back, unplugged the battery, plugged it back in, and now it works again.
Aug 26, 2008 | Uniden Cordless Phone
OUT OF SERVICE MESSAGE
Hi J,
Apparently that one from Ebay looks nice but has issues (not uncommon). If you took it out of the box, charged it fully and its has garbled audio, then the handset or the base is defective, or both, but at least at this point you can get a handset to "communicate" with the base and the "in/use light turns on, when you try to access a line,correct? . If you get the "out of service" message when trying to "move" the "ebay" handset to the other base, it sounds as if the base station and handsets are "coded" and were married together at the factory and one handset won't interchange with anothers base. However, try this before you go the repair service route, or roll the dice with another fine product off EBay :). Unplug and power down both bases, the one from Ebay and your old one. Take the Ebay handset and set it in the charging cradle of your old base. Power up and wait three minutes. Plug dial tone in and give it a try. If it still says "no service" , and won't light the "in/use" light when you try to use it then it won't work with your base, or/and your old handset you lost is somewhere near and is still communicating with its base. Now if you lost your handset weeks ago, then the odds that it is still alive are pretty slim. But I have heard handsets in the warehouse beep for days til their battery dies. You can google cordess telephone repair for service. Good Luck. CG
Feb 14, 2008 | AT&T 2256 Cordless Phone
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
