Question about Panasonic TH-50PX75U Plasma HDTV
No HDMI or component video
After a nearby lightning strike, my dads set no longer displays HDMI, component video or standard video signals. It can display the menus, SD card pictures and over-the-air broadcasts via the RF input. Does this sound like something that would be reasonably simple and inexpensive to repair or have repaired?
  • Panasonic Master
  • 11,800 Answers
This means that the A board has died and must be replaced. This is how it looks
http://cgi.ebay.com/PANASONIC-TH-50PX75U-MAIN-BOARD-Model-TNPH0692-/200489223056?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item2eae16c390
Buy it and replace it.
Posted on Jul 08, 2010
How check pcb after lightning strikes??
Over voltages as little as 20% greater than expected (under the right circumstances) can cause components to fail with no outward indication of failure. Other times, these same or greater voltages will obliterate a component and without the benefit of a schematic will make identifying & replacing it impossible.
Nearby lightning strikes often cause multiple components on different PCB to fail at the same time, complicating troubleshooting significantly. Faults can appear on power supply PCBs and in the RF stages along antenna / cable inputs and out to cable boxes DVD players, etc.
These are usually not fixed by DIYers without specialized test equipment and manufacturer's service manuals.
Jan 30, 2015 | Televison & Video
Lightning strike. TV powers on, solid red power LED, No picture on any input
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 22, 2014 | Panasonic (TH-50PZ700U) Television
Toshiba 37AV500U damaged thru HDMI input.
The lightning stroke has been effected to the main digital board to your TV. It will be best to replace the main digital board as card basis, rather than trying to repair it. Before replacing the board, a through checkup should be done. Contact any expereienced service technician for help, as this work is a very skilled one. No body can predict about the damages to a lightning stroke, as there will be trillions of voltage present for every stroke, and even a slightest voltage can damage so many components in a TV like equipment, as it is designed to work for 110 or 220VAC.
Jul 07, 2012 | Toshiba 37AV500U 37 in. LCD TV
I had a nearby lightning strike. Now I get "no
Hi
Just try with component input, and see whether it works fine. If it works fine with component input, the tuner section in your TV has got damaged. Soem Vizio sets will have dual tuner; one for analogue and the other for digital. Lighning stroke will damage the tuners first, than any other components inside a TV, because it has been alway connected to cable. Check the component video. If it also does not work, the mother board of your TV is faulty. Some type of fault will be repairable. If the fault is serious, you have to replace its main board istself. OK.
Jul 08, 2011 | Vizio 42 in. LCD TV
Ps3 hdmi not working after lightning strike
Its possible that the surge may have reset your display settings, please try my guide to see if this sorts your problem out -
http://www.fixya.com/support/r6784945-playstation_3_no_display
Thank you for using FixYa
May 02, 2011 | Sony Playstation 3 (PS3) Console
Remote no longer works
In side of the TV set there is a remote receiver module. In some models of sets, there is no module. They use descrete components on the main circuit board. The fault could be in the remote receiver section. In some models of TV sets there are some remote amplifiation circuits along the way to the uPC controler. There could be a fault along this path.
The service tech would troubleshoot this by verifying the voltage supply to the remote receiver circuits. Then he would shoot an IR remote signal to the receiver, and then follow the data flow from the output of the IR reciever circuits along its signal path to the uPC controler. This way, he should be able to see with the scope where the data signal is failing.
Jerry G.
Oct 01, 2008 | Philips Magnavox 20MS233S 20" TV
Does not power on. Q951 charred
you can look for the model and brand, look for it on the internet and see if you can have the schematic diagram, you're lucky if u can. Lightning will strike first the tuner side, if there is a red blink, the primary side may be okay in switching type regulator, just replacing the charred part may not solve the problem. look for shorted components on the secondary of the power section.
May 15, 2007 | JVC AV-32230 32" TV
Panasonic TH-50PX75U Plasma HDTV Logo
247 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
