Question about GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0
I have a GE Btu 5000 and you can hear water inside of it. How do i fix it?
    President:
  • 2,976 Answers
You're supposed to hear water inside it. That shows that it is removing the humidity from the air. If it is leaking into the room, tile the outermost end down about 1/2" lower than the inside end.
Posted on Jul 07, 2010
I have a small 5000 btu window unit air conditioner made by arctic king does not have a hole for the excess water to drain.
I've repaired a lot of window units because someone has drilled a hole in the pan, to drain water, and hit the coil. Please do not drill any holes in anything! These units utilize condensate water to help reject the heat in the outdoor coil. If water is reaching the outdoor fan, it either does not have the proper "lean" or slope, or it's designed to allow water to reach the fan, and not much you can do. If it is designed to allow water to cool the outdoor coil, and you were to drain that water so that no condensate water cools the outdoor coil, this will allow the unit to operate with an excessive outdoor coil temp, and shorten the life of the compressor, or cause the unit to operate poorly/warm supply air temp. Try to give it just a little more "lean". Hope this helps!
Aug 18, 2017 | Heating & Cooling
Does the westpointe 5000 btu have a drain port? ours has been sounding like an inside waterfall. and hasnt been draining outside like a regular a/c
If there is a drain, it should be pretty evident. Check for water trapped in the bottom. If there is a working drain, there shouldn't be any trapped moisture.
Jul 26, 2017 | Heating & Cooling
Danby DAC10011E 10000 BTU window air conditioner not draining water? does it have some sort of self evaporating technology? I can hear water inside when I turn it on and/or off, but none draining out the...
Hello, some window units do not use a drain tube instead they use the condenser fan blade to scoop the condensate from the bottum of the base pan and splash the condenser coil to keep the condenser cool and also evaporate the condensate. Most of the time you can hear a "swishing sound"
Jun 18, 2012 | Danby Dac10011e 10000 Btu Window Air...
I HAVE A 5000 BTU G E WINDOW UNIT I PURCHASED AT LOWES LAST YEAR, IT DRIPS DOWN OVER MY PATIO IS THERE A WAY TO INSTALL A DRAIN ?
a plastic pan under the unit with some small hose can divert the water elsewhere. use silicone calk to seal the hose in the hole you drilled in the bottom of the pan NEVER DRILL THE PAN OF THE AC UNIT ! use something to catch the water.. if you drill the unit, you take the chance of hitting one if the AC lines !!! there no fix'n that
Jun 06, 2011 | GE AEV05LN Air Conditioner
Juwt bought a GE 18,000 BTU window unit from Walmart. It runs very loud outside and you can hear knocking noise inside. what can I do to fix this problem?
Did you remove all the packing materials that may have been inside the unit, before installing it? That may be the knocking noise you hear.
Apr 04, 2011 | GE AGW18DH Electronic Room Air Conditioner
Our a/c is spraying water out of vents, what would cause this? It's a kenmore, 5000 BTU.
The drain hole is stopped up,remove it from the window,and it`s shell,and clean it out with a water hose,be sure to remove all debris from inside the unit,and take notice around the drain,and the fan unit.Make sure there is a good tilt on the unit tilting out side,not in,so the water will go out the drain.If this was at all helpful,please rate,thank you.
Aug 02, 2010 | Kenmore Heating & Cooling
Ge window unit 5000 btu it on all day feels hot air some times frozen by the condenser
Remove from window and remove the case,and clean it with a water hose,and do not bend the fins on the evaporator ,or condenser coils with the water hose pressure,but make sure the inside,and the coils are clean.The coils need to have all dirt and debris removed .
Jun 10, 2010 | Heating & Cooling
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ice maker work's but no water coming out, when i put the glass for water hear no contact.
i've been having a lot of problems with the GE's water lines freezing inside the door. I installed the "fix" and it lasted 6 mos. if u want to check..leave the door open for a few hours and check it again.you may just have to live with it.sorry
Jun 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0 Logo
81 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
