Question about HP LaserJet P3005d Printer
My printer model is HP Laserjet P3005dn, No paper inside the printer, checked by removing the toner and checked by opening the rear cover. Showing message as 13.20.00 jam inside rear bin, clear jam and then press ok
  • steven Jul 08, 2010
    Get a flash light a look very close in the back for a tag of paper.
    Thank you, Steven 805-520-3003
    Problem Solver:
  • 5 Answers
There are many sensors that are throughout the machine. Try checking all of the flags and see if they are stuck or loose. If you can locate one that is either try to reseat. If not you could have a bad sensor and needs to be replaced. A certified technician can help with that.
Posted on Jul 09, 2010
HP color laserjet 2840 printer. no printing on the left side of the paper.
Hi
No print on the left side indicates that the toner powder on the left side is almost empty. Try to remove the toner cartridge and shake it well if the toner are new.
If still the same, you need to replace new toner cartridge to get better print out.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 19, 2011 | HP LaserJet 2840 Printer
4300n hp printer displays a 13.20.00 jam inside rear door.I cleaned everything& I couldnt find any jammed paper so what might be the problem
just carefully check for small pieces of paper inside ot printer,
Look for "lasy" sensor flags etc.
Also remove toner cartridge and check inside for paper.
May 13, 2011 | HP LaserJet 4300n Printer
13.20.00 jam in top cover
Press the "down arrow" to get step by step info.
Open the top cover, remove the toner cartridge.
Remove any paper inside.
Lift the metal flap and remove any paper.
Make sure that the paper size matches the tray settings and the dial on the tray.
Reinstall the toner and close the top cover.
Apr 04, 2011 | HP LaserJet 5200tn Printer
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    Paper Jam 13.20 on HP 4015
    13.20 PAPER JAM CHECK REAR DOOR
    Media stopped in the paper path during power on or when the top door was closed.
    Action:
    1. Open top cover and remove toner cartridge. Remove all media in the paper path, and then re-install toner then open and close the top cover.
    2. Open read door and pinch blue latches on fuser and pull it out. Inspect the sensor flag for correct movement and any paper obstructions in the fuser rollers. Re-install fuser and Confirm rear door closure.
    3. Remove tray 2 and confirm paper is not jammed in the pickup area. Confirm paper size adjusters in the tray are correctly set for paper being used. (Do not set back paper stop to ANY)
    4. Replace any defective sensors or flags
    Hope this helps. Please keep us updated and remember to rate this answer.
    TF
    May 24, 2010 | HP LaserJet P4015N Printer
    Clearing path in hp 4350n printer
    open the top cover and remove the toner cartridge check for paper, if there is no paper then open the rear door and check there.
    Dec 18, 2009 | HP LaserJet 4350 Printer
    HP LASERJET 4L has a paperjam
    1. Open front cover, remove toner cartridge and remove paper
    2 Open back door , remove paper
    Oct 22, 2009 | HP LaserJet 4L Printer
    How can I find a paper when it jams in this printer I can't find it
    open the front cover and remove the toner cartridge and check for any paper inside the printer. or open the back door and see whether any paper jam inside the fuser unit.
    Sep 25, 2009 | HP LaserJet 1320n Printer
    When I change to legal size, the paper tray can't
    You might have to remove it or lift from the back, you shouldn't use the drawer to force it open.
    Aug 03, 2009 | HP LaserJet P3005dn Printer
    Printer is not printing anything
    Turn off the Printer, remove the paper tray in front, remove the toner and cover the toner with paper so light doesn't rain down on it! Take a flashlight and look inside to see if there is anything loose paper in the rollers or stuck inside. also look in the toner area too. Remove the rear cover also to inspect for objects. If all looks good then, unplug any cables going to the PC side. Wait 30 seconds. Then insert the paper tray first, the add paper to it. Insert back the toner Plugin back the power and then cables. Also Reboot the PC connected to it.
    Now once the PC is back up and running turn on the printer. If you never done so update the drivers for the until form www.hp.com.
    Jul 31, 2008 | HP LaserJet 1000 Printer
    HP LaserJet P3005d Printer Logo
    578 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
