Question about Dell Computers & Internet
I need to add memory module to my Dell desktop computer. I bought a 256MB Memory Module from Dell but it did not come with any instructions.
  • 77 Answers
Ok. which model ram you purchased. For installation of ram there is no instructions. Open cpu and put the ram in empty ram slot. Put in right direction because if you try to put in wrong direction it wont set because that small cutting in ram is help to set proper way. try it otherwise call any technician for help.
Posted on Jul 07, 2010
I have added 256MB memory to my Sony PCV-RX470DS desktop but it still only shows 256MB that was already installed. Do I need to change anything in BIOS or make any kind of hardware change via jumpers or...
You may need to re-seat the memory module.
Shutdown your PC, remove the newly added memory module. and re-plug it back in, this time when you install it make sure you hear a click noise when installing it to ensure its properly installed.
I doubt you need to update the BIOS to support more memory.
Otherwise you may have a dud memory module.
When installing/removing memory ensure you are properly earthed so that you don't zap and kill the memory.
Mar 09, 2011 | Sony VAIO PCV-RX470DS PC Desktop
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
How do i install memory modules in a dell dimension 3000
This is Gabriel here . Please follow these steps to install the memory:
Lay the computer on its side so the system board is on the bottom of the inside of the computer. If necessary, remove a memory module: Press out the securing clip at each end of the memory module connector.
Grasp the module and pull up. If the module is difficult to remove, gently ease the module back and forth to remove it from the connector.
To insert a module, press out the securing clip at each end of the memory module connector.
Align the notch on the bottom of the module with the crossbar in the connector. Insert the module straight down into the connector, ensuring it fits into the vertical guides at each end of the connector.
Press firmly on the ends of the module until it snaps into place. If you insert the module correctly, the securing clips snap into the cutouts at each end of the module.Replace the computer cover.
Sep 26, 2009 | Dell Dimension 3000® Pentium® 4...
My Dell Latitude C840 works only with one memory module
Your motherboard is bad or there might be something in the slot preventing the memory from seating properly.Check if there is something in the slot preventing the memory from seatting properly.good luck
Sep 14, 2009 | Dell Latitude C840 Notebook
My Dell Optiplex GX520 will not boot. There is no video output and the 3 and 4 diagnostic lights remain on.
If 1 & 2 are off ... then you have problems.
Memory modules are detected, but a memory failure has occurred.
  • If you have one memory module installed, reinstall it and restart the computer. (see Memory for instructions on how to remove and install memory modules.)
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, contact Dell (see Contacting Dell).
According to Dell's notes:
Their remedies are:
Jun 17, 2009 | Dell OptiPlex GX520 PC Desktop
Presario won't recognize second 256 RAM
Remove the original module, install just the new one and then start your computer. If it doesn't start, the memory you bought is bad. The system boards used in the Compaqs will auto-detect memory, and there are no jumpers or BIOS settings needed.
Apr 09, 2009 | Compaq Presario 5000 PC Desktop
Memory module
0 MB on-board memory expandable to 512 MB
Two SO-DIMM slots
SO-DIMM sockets accept 8-, 16-, 32-, 64-, 128-, and 256-MB SDRAM modules in any combination.
Use only PC100 memory modules.
so yeah you bought the wrong ram
Mar 09, 2009 | Dell Inspiron E1505 Notebook
Total newbie here - how do I add more memory to my DELL Dimension 2300? I have my cpu open and i am replacing my fan also.
Well your Dell 2300 has a total max. memory of 1 GB from both slot.
If you already have (2) 512MB RAM in the slot then thats the max it can handle.
Dell 2300 only has 2 memory slots. Memory comes in 1- 128MB, 256MB and 512MB PC-133 DIMM modules. So if you want to max it out get (2) 512 MB PC-133 DIMM.
Note:
You must wear a static strap or ground yourself first on the computer chassis before you touch any thing inside your computer
to discharge any static electricity
For further instruction check this out:
http://support.dell.com/support/edocs/systems/dim2300/replace.htm#1101964
Jan 11, 2009 | Dell Dimension 2350 PC Desktop
Dell 700m memory upgrade
No, it's not necessary. Verify the memory is compatible with the computer.
Jun 28, 2008 | Dell Inspiron 700M Notebook
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Computers & Internet Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
