Question about X2Gen MG19MY 19" LCD Monitor
X2gen monitor Did a new power supply fix your monitor? Mine is doing the same thing.
  • 180 Answers
If you confirm that PSU is the problem chang a new ones.
Posted on Apr 21, 2008
Monitor is clicking and won't come on
This indicates a Power Supply or similar problem, it is NOT a thing that can be easily fixed at home.
I suggest that you go to a reputable service centr/man and get a firm "Quote" for repair.
Jan 19, 2010 | X2Gen MW22U Monitor
My X2gen MW22U gets dim on the left side of the screen. Can this be fixed?
jim5944, It depends on how old the unit is and if you would think it was a cost effective fix for the unit. You will be the deciding factor in the fate of the MW22U. To change the "cold-cathode-fluorescent-lamps" the unit will need to be stripped down to be able to cut loose the ends of the
lamps from the silicone sealer used to mount them to the lcd panel. Before installing new lamps they should be BENCH TESTED to prove that the new ARE NOT doing what the OLD ONES were doing! If new act same as old then the power supply/inverter supply may also need REFURBISHMENT!!! FYI check out www.lcdparts.net , www.ccl-la.com and other places like YOUTUBE for video clips of "LCD monitor disassembly", "LCD monitor repair" for additional info. If this info was of some help, please rate on FIXYA. 12fixlouie nrt of windy city. BYE for now.
Nov 13, 2009 | X2Gen MW22U Monitor
X2gen 19 inch monitor wont power on
Had the same problem with mine. First you need a volt meter (radio shack about $15). check the push in connector and make sure it has coming from it.
Place you meter on DCV for DC voltage, Then place one lead in the end of the plug in the hole. (will not fit all the way so will need to hold it there, Put the other lead on the shiny part of the plug. If you get a reading of 12 volts +/- 1 volt your good. Depending on which lead is were you may get a minus reading this is fine as if you switch your leads around it will go positive. you must have the cord plugged into the wall to do this test. You will not get shocked or anything as 12v is not enough to hurt you.
If you have the 12 volts the problem is in the monitor on the male plug or on the board. this takes more to fix and must take the back off the monitor and fix the connection or replace. I did this to mine and it is working right now.
Apr 10, 2009 | X2Gen MG19MY 19" LCD Monitor
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
X2GEN MW19U MONITOR (THE SAME PROBLEM -SCREEN BLANK & CLICKING)
BEING A COMPUTER EXPERT (IT TOOK ME 6 MONTHS) TO REALIZE "DEFAULT" MEANT GOOD NOT LIKE BACK IN THE DAY!
STARTING FROM THERE, I NEVER EVEN THOUGHT OF WHAT MADE A MONITOR LET ME GAMES ON POGO & CHECK THE GIRLS OUT. I LOOKED UP "X2GEN" AND HAD NO PROBLEM FINDING OUT THEY DON'T LIVE THERE ANYMORE.
THEN I LUCKED ON YOUR SITE AND THOUGHT MAYBE (THE FUSE) SO MY LITTLE SCREW DRIVER REMOVED SCREWS AND LIKE MAGIC, X2GEN WAS UNPLUGGED AND THE COMPONENTS WERE SEPARATED FROM EACH OTHER.
NOT REALLY HARD TO BELIEVE I STILL HAVE NO IDEA IF THERE IS A FUSE IN THE THING..
BACK TO YOU GUYS AND FINISHED READING YOUR THOUGHTFUL SOLUTIONS.
I DO KNOW WHAT THE POWER SUPPLY IS ---"back to known stuff" --AND THOUGHT WHY SEARCH FOR A NEW ONE FROM THE POOR FOLKS THAT WENT BELLY UP MAKING THEM IN THE FIRST PLACE??? "NOW THAT'S DEFAULT"
THERE IS A FISH TANK POWER UNIT THAT HAS THE SAME NUMBERS - IF THAT DON'T WORK--DUMPSTER & WILL GET A MONITOR FROM SOMEONE THAT STILL HAS A JOB--GOT TO KEEP'EM WORKING.
I WAS VERY HAPPY TO FIND YOUR SITE AND ALL THE FOLKS THAT TOOK THE TIME TO WRITE HELP--THANK-YOU FOR REAL rg
Jan 27, 2009 | X2Gen MG19MY 19" LCD Monitor
X2gen MW19R picture only stays on for one to fifteen seconds...
Dear Chris,
Visually check the component :
Try checking on the power board , may be ESR of capacitor is faulty and power resistor shorted and burnt.
Apr 11, 2008 | X2Gen MG19MY 19" LCD Monitor
Need new power cord for x2gen monitor
You should be able to go to any local store like BestBuy and pick up a power cable. The monitor uses the same power cable as a Desktop PC.
Here is a picture: http://www.cablestogo.com/product.asp?cat%5Fid=914&sku=03129
Mar 14, 2008 | X2Gen MG19MY 19" LCD Monitor
X2gen monitor
Hey I've read about your problem cus I had same thing weird lines flying on the screen from one to the other side or crossed and I've found the solution ,there is not enough power strength coming to the monitor power supply because you have to many thong plugged to the same splitter ,just unplug the monitor power supply from this splitter and connect it to another power outlet ,not the same ,another and it should fix the problem at least it fixed my so good luck ,and sorry for my spelling cus I'm Polish ,but I'm trying!
Jan 24, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
62 people viewed this question
Top X2Gen Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
