Question about Whirlpool ACQ122XK Air Conditioner
Compressor not kicking in on 'cool'; or ;dry'
New unit acq122pv. ran GREAT 3 das til today. unit running but compressor not kicking in to cool. help?
  • 1,056 Answers
Have you checked that the controls are not set to fan only? If you have lets go to the next step. All window A/C have thermal switch.. These thermal switch keeps the compressor from overheating. In the event that the compressor is overloading it would trip then click back on as the compressor cools down. Sometimes those switches go bad but the compressor is ok. They are mounted on the compressor themselves and accesable once the A/C unit cover has been opened.
Posted on Jul 07, 2010
My unit just started changes temperatures on me start at 75 and it will change to 86 on its own
Posted on Jul 24, 2011
Not cooling or freezing
Do you hear the compressor kick on, or try to kick on?If not, unplug the unit, remove the "overload relay" from the compressor and give it a shake. If it rattles, it is burnt out and needs to be replaced. Here is the new part.
If the "overload relay" is good, check to see if the "defrost timer" is stuck in the defrost mode. You can take a flat-head screwdriver and turn the timer til it clicks and it should start the compressor.
Keep me posted!
Oct 19, 2012 | Maytag MBB2256G Bottom Freezer...
The freezer stays at 20 degrees, the refrigerator side is at 38 degrees. Replaced the defrost timer yesterday. Shut off then turned back on til the compressor kicked back in.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 06, 2011 | Refrigerators
Hello, My Feder Air conditioner model number A2Q10F2C. The air conditioner has worked great up until today. It has been off since yesterday and turning it on today I can hear electric going into the unit...
Check for a bad start relay/capacitor on compressor. That motor will not start running unless it gets a kick in the behind from those devices.
Sep 05, 2017 | Heating & Cooling
My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
LG AC compressor problem
Compressor may be locking up. Run capacitor may be weak or loose wire. Sounds like major voltage drop off as unit head pressure increases.
Jun 28, 2009 | LG Heat cool Window Air Conditioner
Compressor kicks out and it's new
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Jun 25, 2009 | Ruud UAMB Air Conditioner
AC does not cool. Compressor kicks on and off (Humms when trying to start, electrical smell)
There are a couple possibilities:
1. If this is the first time you've started them for the season, one of the compressors might be seized up from sitting over the winter. In which case, new compressor required.
2. If you've just had the compressor serviced including recharging the system, it's possible that the system is simply overcharged. This will stop the compressor from working and giving you the same symptoms as above. If this is the case, you should have the service people come back with some guages and recover some of the refrigerant and the compressor should be fine.
3. If the unit has been sitting and there is a slow leak then there is not enough pressure in the system to allow it to run. The compressor will shut down if there is not enough pressure, but since you say there is a smell, i really doubt this is the case.
Most likely it's #1 or #2 above. If you haven't had it serviced recently, then yeah, it sounds like you're in need of a new compressor.
Good luck.
Apr 16, 2008 | Dometic Rooftop RV Air Conditioner
Whirlpool ACQ122XK Air Conditioner Logo
349 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
