Question about Pentair 460732 MasterTemp Heater 250BTU ()
Pool heater is not working properly
The spa light is on and we don't have a spa. the heater light for the pool will not come on. When you press the off button the spa light stays on. the heater actually works, heats the pool but we have no control other than shutting off the gas valve.
Pool service put a new mother board in about 6 weeks ago and heater worked for about 4 weeks.
  • 760 Answers
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Posted on Jul 08, 2010
The standby light is on. Why does nothing work?
Standby is actually "off". You need to press status until "Pool" or "Spa" is selected than adjust your temperature
May 27, 2015 | Hayward H-series Electronic Gas Pool...
How do i get my spa out of sleep mode
It would help to know what spa you have, but the most common controls out there are manufactured by Balboa Instruments. If your top-side controls only have four buttons try pressing "temp" or "set" button followed by "light" button. Once there, pressing the "light" button usually cycles through the programming. On some models the "temp" button must be pressed to confirm the selection.
http://www.balboawatergroup.com/Topside-Spa-Panels
Sep 14, 2014 | Pool & Spa
Sta-rite Pool heater boot probem
bad temp sensor heater isn't reading to go on
May 14, 2012 | Sta Rite 333 Btu Natural Gas Heater...
I have a mastertemp pentair heater. No error codes. Pool heater works fine-- spa heater button will not light or operate. Any sugestions?
Since I don't know exactly what model you have I can only suggest you call the Pentair technical support at 800-693-0971 andthey should be able to help you figure this issue out.
I hope this helps.
Sep 11, 2011 | Pentair Mastertemp Pool & Spa Heater Dual...
Colorlogic Pool Light flashes like strobe
These swimming pool lights have a power-cycled feature. THis means that you can power down the light and then power back up in 10 seconds and the light pattern will change. It sounds like your light is not cycling properly. Power it down for a full 60 seconds. This will reset the power cycle. Then try turning it on and off in 10 second intervals. If it doesn't reset, you bulb may only be partially functioning and it may need to be replaces.
Jul 06, 2009 | Hayward 12v LED Color Logic Pool Light...
Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
May 30, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pentair 460732 MasterTemp Heater 250BTU  () Logo
364 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
