Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Horizontal Lines in Picture, Picture Possibly Dimmer
About 1 month ago, my wife told me our upstairs TV (Mitsubishi WD-52725) had the picture dimming and horizontal lines running across the screen. I was out of the country at the time and didn't check into it right away when I returned home. Now the horizontal lines are much more pronounced. So much so, the picture is almost worthless but I can't comment on if the picture is really dimmer or not.
What do you think the problem is? How much does this kind of repair cost?
Thanks.
  • Mitsubishi Master
  • 8,617 Answers
The dimming is usually caused by the mirror needing polishing. The lines floating across the screen is usually caused by failed caps on the FMT board you can get the V26 FMT repair kit from
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-fmt-pwb-repair-kit/cName/repair-kits
Posted on Jul 07, 2010
WD-52725 Picture Quality Problem
sounds like a possible issue with the Optical light engine itself.
Nov 28, 2012 | Mitsubishi WD-52725 52". Rear Projection...
Posted a short while ago but have more information Mitsubishi DLP WD 52725 - sound no picture - blinks 3 short times and 1 long time
have you checked the lamp? with those models they will power up and if the lamp is bad you can hear audio until the tv shuts off. the lamp is located in the front behind the speaker grill assembly. if the "status" light is blinking then you are having a fan failure if the "lamp" light is on then check the lamp like i listed above.
Jan 06, 2011 | Mitsubishi WD-52725 52". Rear Projection...
No display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Sep 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Green diagonal lines across picture on Mitsubishi WD-52725 TV
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Jul 22, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubitshi wd 52725
Good Day;
From you said you should call a Factory Authorized Service Center, toooo many problems with TV for non-tech person.
Good Luck, big IRISH.
Sep 13, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Red lines, green lines, now static!
Uneven colors with multicolored lines in the center of the picture and/or flashing, C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002)
Nov 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Blue lines
DB-IF IN FACT THE PIX IS GOOD ON OTHER INPUTS THEN YOU MAY HAVE A BAD FORMAT PCB.IF THE LINES ARE ALSO ON ALL OTHER INPUTS YOU PROBABLY HAVE A DETERIORATING POWER PC BD. PROBABLE COST OF REPAIR 350.00- 700.00.JOE TV
Oct 11, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
761 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
