How to reset e 007 in canon ir2018n and what to be check an replace? please tell what menu to be use.i know to get in use *28* after that i dont know please help thank.
    New Friend:
Does iR2018N canon change paper size?
Posted on Dec 22, 2017
In the Canon printer iR2018N all buttons not working
Posted on Mar 02, 2011
  • Srini Vas Vasu
    Srini Vas Vasu Oct 19, 2013
    chek teflon in fuser unit fuser ok then problem in dc control bord
Canon iR2018N showing system error E007
eoo7 - fixing film in fixing unit does not work or spin, the cause of dry lubricant or fixing film torn, or white sign has been worn.
if dry then put lubricant again, if you tear you should replace it with new one, after that you must clear error. goodluck
pic of fixing film
Feb 22, 2015 | Canon iR2018N
How can i reset my canon printer error code 007
Error code is regarding fixing unite.
1 check Teflon sleeve in fixing , if found damaged than replace,
2 check lower pressure roller and end rubber gear if found damage replace it
3 now start copier press buttons in following sequence
Addi. function *
than 28
again *
than on panel its display " COPIER"
touch it, than again touch on "FUNCTION"
Than Touch on "ERR"
than Touch "OK"
than switch off machine and again start.
machine will ready
Sep 26, 2014 | Canon iR2018N
When powder is wasting on the paper what could be the problem?
The image fixing fuser unit dont work.Check the pressure roller lever and the fusing unit heater lamp and the upper and lower rollers.
May 01, 2013 | Canon iR2018N
Where is the waste toner container in a Canon iR2018N
waste toner conteiner of canon iR2018 is in/within Drum unit
Mar 08, 2013 | Canon iR2018N
How to afaq shamel my passward 007
my login user and password afaq_shamel Stccpe_2009 not working i cannot login my page modem-007 please help me
Jan 06, 2012 | Zyxel U 336S Modem
How do i reset my canon IR2010f copier to facory defaults
Hi steve363,
Please follow the steps below to reset the unit to factory default.
1. Go into service mode. (*28) "Function" - "Clear". To get into service mode you might need to push "Additional Function" key. *AD>28 simultaneously and *AD again.
2. There should be an option under the clear menu for "pwd-clr".
3. Highlight it and then press OK.
4. On reboot the ID screen should have gone.
5. If not under the clear menu, please try MN-CON, that will clear the main controller.
Hope it helps.
Thank you for using FixYa.
Jul 11, 2011 | Canon Office Equipment & Supplies
Please tell me how to find the main meter on the Canon imagerunner 3025
enter the service mode by pressing additional function 28 additional function check print there u can also print the same in system menu in misc p
Jun 06, 2011 | Canon Office Equipment & Supplies
Sir, i have the gat the Canon iR2018N but my Problem is system 007 Problem pz sol the Problem
the problem is regarding fixing film assembly. Either the film is broken or the white spot on the edge of the film is dirty. Try cleaning the white spot using a cloth whipped with water. Too much water content not allowed. Inspect the edges of the film. It may have worn out due to wear and tear. If that is the case try to move the film to the edge on the side where the film is having a white rectangular spot & fix the assembly. May solve the issue for the time being. But ultimately you willhave replace the film unit
Apr 11, 2011 | Canon imageRUNNER 2018 Copier
Error code 007 appears on my canon iR2018
Hello sir; You may go to make a reset procedure as follow; press "additional funtion"(*) key "2" and "8" key in order, then sssw will display, press "OK" key, then select menu item 1 using up/down arrow key, select bit switch 1 using left/right arrow key, then change data from 0 to 1 or from 1 to 0, then press OK, press Stop .
Sep 16, 2009 | Canon Office Equipment & Supplies
279 people viewed this question
k24674
jasbo
jasbo
