Question about HP LaserJet 4200dtn Printer
Refill ink cart not reding on hp printer when re installed
  • 150 Answers
If you look on the top right side you should see 2 gold squares. Thats the cartridge chip. you can pry it off and switch it with another used cartridge. Thank you Steven, 805-520-3003
Posted on Jul 08, 2010
How to refill ink cartridges
Patsy, every manufacturer has a different design ink cart, and each one takes a different technique to refill them. I find it is much easier to purchase "refillable" carts, they're designed to be refilled. I buy them from:
HP Canon Epson ink refill kit continuous ink supply system cis ink...
Oct 25, 2015 | Office Equipment & Supplies
Printer won't print after re-installing cartridge
Do you get an error message? Some of the newer HP printers are designed to damage the ink cart when it's empty, so you can't refill it. Perhaps?
You may want to try cleaning the contacts on the cart and if that doesn't work, try a new/fresh cart.
Jul 14, 2015 | HP Deskjet 2512 All-in-One Printer
HP Photosmart 2610 all-in-one printer. I've replaced my color and black carts. with refilled ones. My color ink drained all over the bottom of the inside of the printer. I am no longer going to be...
You can use a degreasing spray or methyl alcohol to clean up the residual ink. Use a brush to clean and wipe and BLOW using a hair dryer to fully dry up the residue.
Make sure that there is no dirt at the terminals, clean and set with original cartridges from HP.
Now if there is errors then you must disconnect printer, uninstall then install the driver, connect printer when prompted and print a test page.
Sep 05, 2011 | HP Photosmart 2610 All-In-One InkJet...
Had printer cartridge refilled but when i put it back in the messege says incompatible ink cartridge-black
I would never use refilled ink. This is a lesson. You can still print, yet the cartridge needs a new "chip" they should have given you when they refilled it. You can try: remove the cart. turn off printer, unplug it, then put old cart back in. Do this three or four times and the memory of the printer can only remember three or four resets and then put refilled cart in. Hope this works for you. I was told this for an HP 7130 (similar, yet older version).
Brock
Sep 16, 2010 | HP 8500 Premier All-In-One InkJet Printer
I refilled my tri-color cartridge at Costco and my printer wouldn't print the alignment page. I bought a new cart and it worked fine. Then I re-installed the refilled cart to verify the fix, and it still...
a refilled cartridge IN NO WAY can lead to printer failure
the ink is the last thing on printer and has no effect to mechanical failures.
check here how you can refill your cartridge
http://www.youtube.com/watch?v=II9gpIXs_lE
Jul 02, 2010 | HP PSC 2210 All-In-One InkJet Printer
Problem with hp deskjet 640c printer
i have an hp and find that they (color carts) cannot be refilled- the clever b*st*rds!! they stepped the ink reservoirs so, if you don't insert the re-fill needle 'just right', it bleeds into the others and you end up with a 'muddy' print-out! you need to buy a new hp cart, or shop around for a generic cart (cheaper) google your product & cart #. you may find a source for a cheaper cart.
the black carts. can be re-filled!
good luck!
Oct 08, 2009 | HP DeskJet 882c InkJet Printer
Get refilled ink cart. to work
probably one of your cartridge is no good
check the contacts ..try clean them with
a wet towel
Apr 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Black Ink shows empty even after installing on HP Photosmart 3210
These cartridges are really only ik resovoirs for the printer. It does have an ink flow sensor, though. If the printer does not recognize the ink level, it is possible that you got a cart with a bad chip. I refill these alot, and all you can really do is check the chip on the cart and make sure nothing is on the contacts...otherwise replace. A good step would be to put the old cart in and see what happens...
Mar 10, 2009 | HP Photosmart 3210 All-In-One InkJet...
How to refill kodak 5300 ink cartriges
I found the info about here:
http://printerinkcartridges.printcountry.com/other-printer-brands-printer-ink-cartridges-articles/kodak-inkjet-printers-kodak-ink-cartridges-kodak-com-inkisit-com/how-to-recycle-refill-kodak-printer-ink-cartridges/
However, after filling a black cart and placing it back in the printer it said that I needed to change the Black cart..........
There is a chip on the cart and I have been looking for a solution, but as of yet....nadda
Apr 14, 2008 | Office Equipment & Supplies
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
HP LaserJet 4200dtn Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
