Question about Anycom HS-890 Wireless Headset
Anycom hs 890 - need entry code for connecting to phone
How do I get a wiring diagram for CTM 850
Hi there is a PDF instruction download type in CTM850 mobility scooter schematic. INCLUDES HS-890 or U can get in touch with www.ctmhomecare.com.they might b able to help .good luck
Mar 04, 2016 | Ctm HS 890 4 Wheel Heavy Duty Power...
Need owners manual for A ctm hs 740 mobility scooter.
go onto ctm homecare website and into rescource centre then dowloads and click on 740, regards, Bill.
Jun 14, 2011 | Ctm HS 890 4 Wheel Heavy Duty Power...
How do you put device in descoverable mode
with the device off hold down the on/off button and keep holding it. The led will start blinking blue (keep holding) and then red (keep holding) and finally flash between blue and red. Now let go of the button - it is in discoverable mode.
Jul 28, 2010 | Anycom HS-890 Wireless Headset
How do i establish the connection between my samsung phone and a headset?
Normally: Hold the main button on the headset until the blue/red lights alternate (Or other colours) and the phone should be able to pair with it.
Apr 12, 2010 | Anycom HS-890 Wireless Headset
Can not figure out how to connect my ANYCOM Milos-9 to my cell phone. no instructions came with product.
Turn off the Anycom headset. After it is off, press and hold the silver power button. You will see a blue light come on but dont let go off the power button, keep holding it till the light turns red. Then the device will be in pairing mode. Turn on the phone and make sure that the phone is visible in the bluetooth settings. Scan for a device in the phone and you should see the Anycom headset. If it asks for a code to enter then the code is either 0000 or 1234 or 9999.
Dec 27, 2009 | Hagenuk Anycom MILOS-9 Bluetooth Headset -...
Instructions
Hi Deborah!
First of all you need to activate the bluetooth on your phone, after that turn on your headset, now get in the bluetooth menu on your phone, select search for bluetooth items, your phone will find your headset and it will ask you if you want to connect to it, select yes.
Many headset have a code, that code is neede to connect to the phone. if your headset have one the code should be in the manual that came with the headset. If your headset dosent have or need a code it will connect to your phone as soon as the settings is done on the phone.
Good luck
Nic
Feb 28, 2009 | AT&T LG CU515 Cell Phone - Black
Anycom HS-890 Wireless Headset Logo
Top Anycom Radio Communications Experts
Michael Vincent Cruz
Ed Nelson
Ed Nelson
ray gallant
Are you an Anycom Radio Communication Expert? Answer questions, earn points and help others
