Question about Apple MacBook Air
Hi, I have a Mac Book Air and it seems to be heating up very high lately. ALsmost to the point where I can't even put my hand on the bottom near the fan. Is this normal?? Doesn't seem so. I'm only using Internet. No other programs open. Please help. Thanks, Chris
  • cmassenz Jul 20, 2010
    That was not very helpful. I have done searches online, asked other owners of Macbooks etc etc and thought I might be able to get a more specific answer from you. Given me advice to consult a handbook is useless. Thank you anyhow.
    -Chris
    President:
  • 1,561 Answers
I advice you check the service manual that came with your device, the solution to the prescribe issue should be address in the service manual, using this will be of good guide.
Take care.
Posted on Jul 14, 2010
Heating and air
My first thought was low coolant, but with the added point about the ac I'm leaning toward a blend door problem under the dash.
Feb 27, 2014 | 2007 Suzuki Grand Vitara
2000 jeep grand cherokee, only blow out a little air even when the blower on hi,,you have to put your hand next to the vent to feel the air
you may have had something fall down into the defrost vent and it has worked its way down and is blocking the air flow thats trying to come out the vents,near the blower motor.also does it sound like the blower motor is spinning on high speed or at a lower speed,you could have a slow turning blower motor.
Jul 20, 2011 | 2000 Jeep Grand Cherokee
My mac book pro model late 2007 15,4" not starting up
Try to reset the PRAM and SMC follow the Process in Apple webpage.If still the issue persist try removing the Ram and check with a good one if you have any.this should solve the isue.If still the issue arise then it can be a logic board problem
Feb 28, 2010 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
My GPU temp is too high, when is on high
Hi
It sounds like one of a few problems
1) Ensure that when you put your laptop down the air vent (the place where the hot air comes out from the laptop is not blocked),
2) If the above does not cure the issue then it would seem the heat sink itself is faulty and wil need to be replaced
I would recommend that you book it into a reputable PC repair shop if number 1 fails
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | Gateway P-6860FX Notebook
I recently bought a second hand grand voyager and occaisionally when the car is started a little symbol on the dash comes on and stays on. when it stays on and i come to the end of my journey, the car...
It means that the pre heat is in operation.It is a system that burns diesel to create heat to warm up engine quicker so that warm air comes into car sooner.The smoke is the exhaust gasses from the system and normally the whistleing and smoke stops when engine reaches running temperature or on short journeys approx 1 minute after engine is turned off
During summer when no heat is required and air con is on cooling it should not light even when starting from cold
hope this helps
May 18, 2009 | 2004 Chrysler Voyager
Worcester bosch greenstar 25Si?30Si pressure gauge showing high
a couple of things , is your filling loop disconected ? , and are all your radiators blead from air, have you got a high point where the air can get stuck in system say pipes going into roof etc you may need to fit a air release valve in line at highest point to remove the air from system , your boiler should be around 1.5 bar running preasure average setting . if you are constanly filling with water you could be exceeding the pressure valve limet which releases pressure from system this could be faulty ?
Feb 02, 2009 | Water Heaters
Mac book air trouble to get on
try putting they installition disk that came with your mac. then retore it.
Jan 16, 2009 | Apple MacBook Air
Hi, I have a 1991 Suzuki JLX Vitara with the Front Right hub is locked into 4WD and I can seem to unlock it and the gearbox of late feels notchy, sometimes difficult to change into gear
Try hammering the front right hub with a wood or a rubber hammer while slowly reversing the vehicle, and keep on unlocking the hub while doing this.
spray it with lubrication first
yes, you need to change the gear oil in your gear box
Have your clutch re adjusted, it may be worn out , that's why you are having a hard time changing gears or have it bleed to keep the air out if you are using hydraulic.
If you dont hear any noise in your gear box while driving, its nothing serious, worst thing could be replacing your clutch lining and pressure plate.
Oct 07, 2008 | 2000 Suzuki Vitara
Right Hand door swings open too fast
On the bottom of the door there is a part called a door closure kit.It operates like a cam. There are high and low points on the part that aid in the opening and closing of the doors. Do-it yourselfer project.
Nov 10, 2007 | Maytag MFD2560HES Bottom Freezer French...
Apple MacBook Air Logo
46 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
