Install the XP discs and restart the machine. It should boot from the discs. Then follow the onscreen instructions. You will want to reformat your main drive. (C:)
To reformat a hard drive with Windows XP, insert Windows CD and restart your computer.
Your computer should automatically boot from the CD to the Windows Setup Main Menu.(If not, press F2 or DEL and choose first boot device CD or DVD)
At the Welcome to Setup page, press ENTER.
Press F8 to accept the Windows XP Licensing Agreement.
If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
You have now sucessfully reformatted the hard drive with Windows XP.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
To install new version of XP. Insert XP CD into drive,
reboot pc pressing F1 button.. This takes you into BIOS, change your primary
boot device to CDrom, save changes and reboot. Select boot from CD once this
appears and wait for files to be installed. Select the part of the hard drive
you wish to use for your operating system (usually the largest) and select
partition this drive. Delete any previous os, and reformat hard drive. (Be
aware this removes everything saved on your hard drive, so always back up first)
Re boot afterwards and reinstall operating system. Hope this helps
Sure, calm down. You need to get a bootable cd like UBCD. This cd not only boots, but installs a cd driver, allowing full access of CD Drive in a DOS Environment. Check out the UBCD website, download it, and turn the computer on, with the cd in the drive, your computer will boot, so boot the cd, when the options load, hit the key "r", and windows will repair.
Good Luck
Windows XP Professional Edition causes problems for many mp3 players - it actually reformats the player in a way that one or the other computer cannot properly use it. I would reformat your mp3 player and start over froms cratch (or avoid the problem computer).
