Question about Haier Heating & Cooling
Hi, I have a Haier Air Conditioner, 6,000BTU (I believe) and my room is about 150 sq. feet living room with No door. Instead of a door we have a curtain (which is supposed to be cool/heat insulated type). However it has about 30"x15" on the top of the curtain that is only covered by a plastic sheeting that I purchased at a hardware store which they told me would help insulate. I also put that around the window where the AC is located to cover any cracks. The problem is the room is taking very long to cool. I don't know the average time, but I started it today at 9pm (86 degrees the unit read) and it now says 83 degrees at 11:30pm. Any suggestions or advice would be appreciated. Thanks, Chris
    President:
  • 1,561 Answers
If the unit is working properly it should cool the home. Is your filter clean? Look and the evaporator in the inside unit. Is it frosted up? Do you have condensation water in the pan? Go to the outside unit and feel the air coming out of the fan. Is it warm? Now feel the 2 copper pipes coming out of the unit. The problem could also be that you device is low on freon and will need to be refilled.
Take care.
Posted on Jul 07, 2010
How to figure 12x12 sq ft
12 x12 = 144 sq ft
12 x12 x12 = 1728 cubic ft
May 02, 2015 | Heating & Cooling
A build-up of ice on my air conditioner behind the filter which is room size
Check air filter and check the access water drainage pipe for any conjuction
Nov 09, 2012 | Haier Hwf05xcj Window 5000 Btu Air...
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
Not cooling room
Assuming the unit is 'cooling' but not cooling it 'well,' I would think the unit is too small.
NOTE: 2000 Btu for every 100 sq ft of cooling space if the room is well insulated. If not - then 2000 btu for every 66 sq ft.
For example - a 12000 btu AC unit should cool 600 sq feet of cooling space if well insulated.
or
400 sq feet if not well insulated.
hope this has helped.
Aug 05, 2011 | Danby DPAC12031 Air Conditioner
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
HI HOW DO YOU REMOVE THE GRILLE COVER TO CLEAN THE CONDENSER COILS & FINS WE HAVE TWO OLD MECHANICAL 8,000 BTU HAIER UNITS TRYING TO COOL A L SHAPED ROOM OF ABOUT 850 SQ. FEET WITH TWO CEILING FANS FOR...
These a/c under 10,000 btu usually are brutal to get into
Some come apart in halves others just have lots of screws
Good Luck!
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Haier Heating & Cooling
Haier room air conditioner doesn't cool maximally at "Hi AC"
You should have at least 5,500 BTU's for that size room. Clean the filter. Turn it on and let it work for a few hours.
Aug 02, 2009 | Haier hwr10xc6 Air Conditioner
How large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
if this helps please vote me a fix ya
Jul 21, 2008 | Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
