Cars & Trucks Logo
Posted on Jul 07, 2010
Firing order doesnt match distributor cap or cables
My name is tyger roy, i have a 280zx aswell as a 300zx. I am moderately fluent in the mechanichs of this car because as with all older vehicles the regularly need work done. Usually having little extra money, i become the backyard mechanich so-to-speek. I just finished (nearly) replacing the enginge in my 300zx. Everything went smoothly until i went to hook up the spark pug cables. It is my understanding that the firing order is supposed to be 1-2-3-4-5-6 however my distributor cap and wires (as it rotates counter clockwise) dictate that the firing should be 1-3-5-4-6-2 the spark pug cables seem to be custom lenths to fit this latter order. My Chiltons manual and everyone i have talked to have come across the same contradiction. Im sure that i am overlooking something simple. I have tried the 1-3-5-4-6-2 firing order with out any luck, and my cables dont seem to reach in any comination to achieve 1-6 firing order. Any advise would be appreciated.
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Jul 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
7214
Points
30
Most inline 6 motors use 153624 firing order,,,remember to ck dist,rotation and wire accordingly,,,good luck..
1helpful
I have just replaced my distributor cap and cables from my 1.4 citigolf chicco 2006 model, I did not memorise how was the sequence of cables from plugs to distributor cap. please help.
go google and type in-- firing order for golf 1.4ltr 2006 model -- and there are pages that will show the firing order and the rotation of the distributor
Firing order for 95 Vortech 4.3 L
Firing order: 1-6-5-4-3-2 Distributor rotation: clockwise
25756388-5lp4pmhcvtgpbgu2diawedgi-3-0.jpg 4.3L Engine
Distributorless ignition system
M's cylinders are 1 first left, 2 first right, 3 second left, 4 second right, 5 thrid left, 6 third right... from front to back... Fords are 123 left 456 right... unless its an inline... So if they are all on one side of the disributor they are probably wrong... This is why I love Haynes manuals... They show positions of distributor caps and cylinders for firing order and timing... Pretty much almost everything you need... So the firing order on the distributor should match the way they number the cylinders...
https://www.youtube.com/watch?v=LOR-9JZUUI0
I bought a car BUT before i bought it i made sure the car would turn over ...it did a couple of times but wouldnt start ..... i bought the car ( a 1982 280z ) got it home and now it wont turn over at all...
Here's an online vehicle repair guide for your car, whether its a
(1) 1982 Nissan 280ZX 2.8L FI Turbo 6cyl, or
(2) 1982 Nissan 280ZX 2.8L FI 6cyl
www.autozone.com - its not searchable, but better than nothing.
AutoZone will expect you to register (free) to access their repair database.
Start with some of these - listed in priority order:
Priority Part Cause
1 Battery discharged/faulty
2 Battery Cable corroded/broken/shorted to body or poor connection
3 Soleniod Switch faulty
4 Starter Motor faulty
5 Ignition switch - improperly connected/faulty
6 Distributor Cap - broken/corroded/worn inside
7 Spark Plug - fouled/damaged/broken
8 Fuel Pump - faulty
9 Fuel Injectors - dirty/burned
10 Distributor Cap/Rotor - worn out
11 Fuel Tank - empty
12 Carburetor - worn/damaged/faulty
2helpful
I need to know where the plug wires go.from spark plug to distibuter cap on a 1986 4.1 coupe deville(cad.)
FIRING ORDERS NOTE: To avoid confusion, remove and tag the spark plug wires one at a time, for replacement. If a distributor is not keyed for installation with only one orientation, it could have been removed previously and rewired. The resultant wiring would hold the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes in your book to reflect how your engine is wired. Fig. 1: GM (Cadillac) 250 (4.1L) V8 GM (Cadillac) 273 (4.5L) V8 Engine firing order: 1-8-4-3-6-5-7-2 Distributor rotation: counterclockwise 85872009.gif Fig. 2: GM (Oldsmobile) 307 (5.0L) V8 GM (Oldsmobile) 350 (5.7L) V8 w/EFI Engine firing order: 1-8-4-3-6-5-7-2 Distributor rotation: counterclockwise 85872009.gif Fig. 3: GM (Buick) 252 (4.1L) V6 Engine firing order: 1-6-5-4-3-2 Distributor rotation: clockwise 85872010.gif Fig. 4: GM (Cadillac) 368, 425, 472, 500 V8 Engine firing order: 1-5-6-3-4-2-7-8 Distributor rotation: clockwise 85872011.gif Fig. 5: GM (Cadillac) 429 V8 Engine firing order: 1-8-7-2-6-5-4-3 Distributor rotation: clockwise 85872012.gif prev.gif next.gif
3helpful
Just wondering if you have a breakdown diagram for a 1992 dodge colt 1.5l distributer
I do not have a breakdown diagram for a distributor, but just the firing orders and description of ignition system for the Dodge Colt and related models (based on Chilton manuals) if that's what you're looking for: FIRING ORDERS Fig. 1: 1990 1.8L SOHC Engines Firing order: 1-3-4-2 Rotation: clockwise 84182009.gif
Fig. 2: 1.6L DOHC Engine Firing order: 1-3-4-2 Distributorless Ignition 84182010.gif
Fig. 3: 2.0L Engine Firing order: 1-3-4-2 Rotation: clockwise 84182011.gif
Fig. 4: 1.5L Engine Firing order: 1-3-4-2 Rotation: counterclockwise 84182012.gif
Fig. 5: 1993 1.8L Engine Firing order: 1-3-4-2 Rotation: counterclockwise 84182013.gif
Fig. 6: 2.4L Engine Firing order: 1-3-4-2 Rotation: clockwise 84182014.gif
To avoid confusion, replace spark plug wires one at a time. --- Distributor REMOVAL & INSTALLATION Although the distributor can be removed from the engine no matter which cylinder is about to fire, it is a good idea to have number one cylinder at TDC before distributor removal. 1.5L, 1.8L, 2.4L SOHC Engines
  1. Disconnect the negative battery cable.
  2. Disconnect and tag the spark plug wires from the distributor cap.
  3. Disconnect the distributor harness connector.
    Fig. 1: Ignition system for the 2.0L engine 84183001.gif
    Fig. 2: Ignition system for the 1.5L engine 84183002.gif
    Fig. 3: Ignition system for the 1992-93 1.8L engine 84183003.gif
    Fig. 4: Ignition system for the 2.4L engine 84183004.gif
  4. Loosen the distributor retaining bolt and remove the distributor from the engine. To install:
  5. Rotate the engine until No. 1 cylinder is at TDC on its compression stroke. NOTE: Be careful not to turn it to the No. 4 cylinder TDC on its compression stroke by mistake.
  6. Align the distributor housing and gear mating marks.
    Fig. 5: Ignition system for the 1990 1.8L engine 84183005.gif
    Fig. 6: Distributor installation for the 1990 1.8L engine 84183006.gif
    Fig. 7: Distributor installation for the 1992-93 1.8L engine 84183007.gif
  7. Install the distributor into the engine, while aligning the fine cut (groove or projection) on the distributor flange with the center of the distributor mounting stud.
  8. Install and tighten the distributor retaining bolt.
  9. Reconnect the distributor harness connector.
    Fig. 8: Distributor installation for the 2.4L engine 84183008.gif
    Fig. 9: Distributor installation for the 1.5L engine 84183009.gif
    Fig. 10: Distributor installation for the 2.0L engine 84183010.gif
  10. Install the distributor cap and spark plug wires.
  11. Reconnect the negative battery cable.
7helpful
Firing order for a 1986 gmc s15
FIRING ORDERS
To avoid confusion, ALWAYS replace spark plug wires one at a time.
The most important thing to remember about the removal and installation of a distributor, cap or spark plug cable is that all wires MUST be labelled before they are disconnected. Keep in mind that these figures depict a firing order where the distributor cap terminals are relative to EACH OTHER only and they do not necessarily depict the tower positions in relation to the rest of the engine. This is true because any distributor which has been removed and reinstalled may have been installed with the No. 1 spark plug tower at any position (360 degrees) in relation to the rest of the motor, as long as the rotor aligned to the No. 1 tower when the No. 1 cylinder was at TDC of the compression stroke (valves closed, ready for the plug to fire). As long as the remaining wires were connected in the correct firing order sequence (depending on direction of distributor rotation) the engine will run. DO NOT EVER remove more than one wire from the distributor cap at a time unless you tag ALL wires and towers to assure proper installation.
Fig. 1: 1.9L engine . Firing order: 1-3-4-2 . Distributor rotation: counterclockwise
Fig. 2: 2.0L engine . Firing order: 1-3-4-2 . Distributor rotation: clockwise
Fig. 3: 2.5L engine . Firing order: 1-3-4-2 . Distributor rotation: clockwise
Fig. 4: 2.8L engine . Firing order: 1-2-3-4-5-6 . Distributor rotation: clockwise
Fig. 5: 4.3L engine. Firing order: 1-6-5-4-3-2 . Distributor rotation: clockwise
I hope help you with this (remember rated this help) Good luck.
My 1987 300zx cranks but wont start.
I had the same problem last year mine turned out to be a crank sensor I don't know if that is your problem for sure mine wouldn't send any spark from the coil to the spark plug replaced crank sensor inside distributor and fired right up the dealership called it a cam sensor my book called it a crank sensor either way its in the distributor
I need to install a distrubuter, need to know how to find top dead centre etc.
Distributor Cap grey_line.gif Inspect | Replace The distributor cap should be removed for visual inspection. Check the cap for:
Inspect the distributor cap and rotor. Courtesy of American Honda Motor Co., Inc.
  • Distributor cap locating tab. This tab assures proper location of the cap onto the distributor housing.
  • Distributor cap holddown. The distributor cap must be securely attached to the distributor housing to prevent contamination and to assure its location.
  • Dirt and water in the cap. These contaminants will require additional voltage in order to fire the spark plug. If available voltage is not enough to overcome this resistance then no spark will occur at the spark plug.
  • Center carbon insert. All of the high voltage coming through the coil on its way to the spark plug must pass through this insert. Any additional resistance caused by wear or contamination can cause the engine not to start or to misfire.
  • Tower inserts. The inserts are made from aluminum or bass so it is possible for them to oxidize. Aluminum oxide is an abrasive that can cause excessive damage to the distributor. If the insert is made from brass then the oxidation will appear green in color.
  • Cracks. If any cracks are present on the distributor cap then replacement of the part is required.
  • Carbon tracking. Carbon tracking indicates that the high-voltage of electricity has found a low-resistance conductive path over or through the plastic. The result is a cylinder that fires at the wrong time, or a misfire.
Also check for:
  • Physical or electrical damage is easily recognizable.
  • Electrical damage from high voltage can include corroded or burned metal terminals and carbon tracking inside distributor caps.
Things to look for when inspecting a distributor cap.
  • If the distributor cap has a mild buildup of dirt or corrosion, it should be cleaned. If it cannot be cleaned up, it should be replaced. Small round brushes are available to clean cap terminals.
  • Wipe the cap and with a clean shop towel, but avoid cleaning these components in solvent or blowing them off with compressed air, which may contain moisture. Cleaning these components with solvent or compressed air may result in high-voltage leaks.
  • Check the distributor cap and housing vents. Make sure they are not blocked or clogged. If they are, the internal ignition module will overheat. It is good practice to check these vents whenever a module is replaced.
Replace Distributor cap replacement instructions vary, so always follow the manufacturer's instructions.
General replacement procedures are as follows:
  • For spring-loaded caps, unsnap the clips and remove the cap. When installing the new cap, make sure the clips are snapped back into place.
  • For spring-loaded j-hook caps, push down and turn. It will unlock. Lift up to remove it. Position the new cap in place, then push down and turn to lock.
  • For caps with screws, use a screwdriver to loosen the two screws. Install the new cap and use the screwdriver to tighten the screws. Don't overtighten.
It is a good idea when replacing the distributor cap to remove the cap with the ignition wires attached. After you have installed the new cap, transfer the wires one by one onto the cap in their correct position. This way the firing order is accurate. If, for some reason after you replace the distributor cap, your vehicle does not function normally, check your firing sequence.
The distributor cap is mounted on top of the distributor assembly and an alignment notch in the cap fits over a matching lug on the housing. Therefore the cap can only be installed in one position, which assures the correct firing sequence. There is a tab or notch somewhere on the distributor body that must align somewhere on the distributor body that must align with a corresponding tab or notch in the cap. Once again, do not force something.
The rotor should be inspected and/or replaced when the distributor cap is replaced.
Firing Order Each cylinder of an engine must produce power once in every 720 degrees of crankshaft rotation. Each cylinder must have a power stroke at its own appropriate time during the rotation. To make this possible, the pistons and rods are arranged in a precise fashion. This is called the engine's firing order. The firing order is arranged to reduce rocking and imbalance problems. Because the potential for this rocking is determined by the design and construction of the engine, the firing order varies from engine to engine. Vehicle manufacturers simplify cylinder identification by numbering each cylinder.
Examples of typical firing order.
Regardless of the particular firing order used, the #1 cylinder always starts the firing order, with the rest of the cylinders following in a fixed sequence. The ignition system must be able to monitor the rotation of the crankshaft and the relative position of each piston to determine which piston is on its compression stroke. It must also be able to deliver a high-voltage surge to each cylinder at the proper time during its compression stroke. How the ignition system does these things depends on the design of the system.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
