Question about LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T...
The led panel is showing Er 1F. what is wrong and what do I need to do?
    President:
  • 1,561 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
There are many people that have this problem and are searching for answers as to what to do and what could be causing this problem.
Posted on Jul 07, 2010
  • keg1960 Jul 07, 2010
    Do I need to remove the food because it will not continue to cool?
  • Sulaimon Jimoh Olayemi Jul 07, 2010
    It is ER IF and indicates that the ice maker fan is not working. The
    fan is probably frozen. If you can remove the fan duct and housing at
    the back of the freezer you may be able to defrost the ice in the fan
    enclosure. The fan may have frozen because of high humidity or because
    the defrost cycle is not working.
    Yes, remove the food items and carry out the manual defrost on the fan.
    Take care
Had Er and 1f on panel. Pulled drawers out and removed ice from the back of freezer compartment, errors still show. Is there a reset button or did the ice cause a problem with fan motor?
Probably defrost problem. Evaporator, which is behind inside back wall of freezer, will have to be completely thawed. Then a determination will have to be made which of the 3 defrost components are bad. Those components are defrost heater, defrost thermostat, and defrost timer or control Board.
Sep 12, 2017 | Refrigerators
What does Er 1F mean on the ice maker display
LG Refrigerator Error Code Er 1F or Er IF
The ice maker fan is not working properly. Try defrosting the freezer first before trying to replace anything.
Jun 29, 2017 | Refrigerators
LG Ref/Frzr LFX 31925st ERROR CODE ER 1F NEED MEANING AND FIX
A F1 or 1F error code on the refrigerator's display indicates a problem with ice blower fan or ice maker motor.
search LG error 1f and u will find lots of info
Dec 09, 2016 | LG Refrigerators
LG Lfx31945ST . No ice and error ER 1F. About 6 weeks ago frost started to appear on the freezer drawer. Tried unplugging it for 4 hours and turning it back on but still getting error within a few...
probably heating element in freezer is broken.
Remove power and defrost. Remove wall panels in back of freezer to Check heater element behind panels With ohm meter should read 20 ohms or less. You could remove it and bring it to a local repair shop and have them test it and if required order you a new one. If this does not work it may be the control board
Oct 20, 2013 | LG LRBC22544 Bottom Freezer Refrigerator
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ER 1F
It is ER IF and indicates that the ice maker fan is not working. The fan is probably frozen. If you can remove the fan duct and housing at the back of the freezer you may be able to defrost the ice in the fan enclosure. The fan may have frozen because of hight humidity or because the defrost cycle is not working.
Sep 08, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service Manual
"ER IF" show a problem with the ice maker fan motor.
Nov 06, 2008 | LG LFX25960 Bottom Freezer French Door...
LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
22 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
