Question about Car Audio & Video
Cd player Frequently, especially when it is HOT, CD playback is choppy. Generally OK for cool conditions. I have used a CD cleaner disc to dust off laser lens. This usually helps for a little while but the problem recurs. I have checked that these CDs play fine on my CD player at home. Toyota Corolla 2004 factory-standard CD/cassette/am/fm player
  • 51 Answers
Well it's not normal that a factory deck goes out that quickly, it could be that you have really dusty conditions. It could be that its going bad and the littlest piece of dust could affect it, I would look at it trying to get it serviced or to get a new deck, if you have any other questions please ask! Thanks!
Posted on Apr 18, 2008
Put cd in, says it’s reading disc, after10 seconds it says Not Playable, then ejects disc
hi Nancy.
this could be dust on the lens that reads the disc.
Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
read up some more at this link.
How to Fix CD Player When It Won Play Techwalla com
Dec 20, 2017 | Audio Players & Recorders
Do I need a dvd cleaner and what kind
Hello
DVD cleaner is a kind of CD, which will have cleaning pads sticked on it. When we insert the disc in any disc player, this cleaning pad will come in contact with the lens of the reading head. As the cleaning CD spins at hing speed inside the disc player, it will wipe out all the dirt and dust, if accumulated on the lens. Thus cleaning of laser pickup lens occurs.
This cleaning disc can be boutght from most of the electronic spare part shops at your town. Even after using this disc, your DVD player does not reads any disc, its laser pickup assembly is faulty, and should be replaced. OK.
Nov 19, 2011 | Televison & Video
I put a dvd in and it says it is loading and then it says no disc found even though it is in the dvd player. I have tried several different dvd's.
Unfortunately , Some DVD players cant read some DVD s and
then it gives either "loading" or " no disc"..reading on the display...
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens anyway .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 26, 2011 | Proscan 32LB30QD 32 in. LCD TV
My Sony DVD player will accept the DVD but fail to load and play the DVD?
Unfortunately , Some DVD players ,especially brand ones cant read some DVD s and
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
Thanks
Jul 25, 2011 | Sony RDR-VX500 DVD Recorder/VCR
DVD 30 turns off when I put a disc in and it reads it.
I understood your problem...Harman Kardon BDP1 BluRay Player generally it cause due to lens problem and data processor it may be creates a problem.
you have one option to use lens cleaner CD which removes dust from the lens it may be helpful to you.
Thank you for giving me opportunity to solve your problem.
please give me your Ratings!!
Jun 20, 2011 | Harman Kardon BDP1 BluRay Player
Replys no disc while operating
- Disc is not burned in the ISO 9660 Joliet format.
- The movie encoded using some incompatible DivX settings. Philips DVD players does not play movies encoded in 720p or 1080p HD format.
- There should be some dust accumulated over the laser pickup. Use a CD lens cleaner.
- Rarely, the transport mechanism could be facing some fault moving the laser head to-fro. This requires opening the box and taking a peek inside.
Mar 04, 2011 | Philips DVD Player with DivX Playback
The unit accepts and ejects a CD but will not play a CD - the radio functions seem to be fine.
DVD/CD players attract as much or more dust as the other electronics in our home. Be sure to dust with a microfiber cloth or electrostatic duster at least weekly, to keep your model running smoothly. The insides of our DVD/CD player can get dirty and dusty too. A great tool is a DVD/CD disc cleaner. This cleaner looks just like a disc with some extra little brushes on its surface. Some DVD/CD cleaner kits even come with supplies to clean and modify scratches on your discs.
Sep 09, 2010 | Sony CDX-4000X CD Player
DVD GO FORWARD BY ITSELF
Do you mean DVD jumps / skips forward in playback?
If yes, please clean optical laser lens in player. It sounds optical lens has thin layer of dust and causing ' tracking error ' in playback.
Put CD Lens Cleaner disc in player and press play to clean optical lens by cleaning disc and if problem still exist, need to clean lens manually with good quality cotton bud.
Hope this will solve your problem.
Thanks.
Sep 08, 2009 | Samsung HT-Q100 System
MY CD PLAYER SKIPPING ON EVERY FOURTH TRACK ANY SOLUTIONS
could be a coincidence make sure your cds are clean, clean the dust and grime off carefully with a very fine material soft cloth, cleaning from the inside to the outside but not in a circular fashion but in line formation from inner to outer ok...
also try using a cd head cleaner cd to clean the laser, the laser could be dirty
Jun 23, 2009 | Teac PD-H303 3-Disc CD Changer
CD tray wont stay closed
Try using a CD cleaner. Generally this sort of problem occurs due to dust accumulating on the lens. The CD cleaner comes along with a solution.just spray on the CD and allow it to play in the CD drive. Sometimes the problem might even be due to a virus. Check whether your anti-virus is up to date.
Nov 30, 2008 | Integra CDC-3.1 CD Player
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
