Question about Toshiba IK64DNA IR Day/Night Camera
I have two ir security cameras. When it gets dark enough to require the ir to kick in, it does and then tries to go back to "day" (color) mode. It then recognizes that there is not enough light and the ir's kick in..... over and over all night long. Sometimes it will stay on for 30 sec other times it happens every few seconds. Any suggestions? A power issue?
    Sniper:
  • 54 Answers
You don't mention if both cameras are malfunctioning. If so, yes it is a power problem. Each camera needs additional amperage when it switches from day to night mode. The power source is probably fine during daytime hours but can't supply the demand when the ir's kick in at night. If your power is being supplied by plug in transformers then purchase a new one with the same voltage rating (most are 24VAC) but a higher Volt/Amp rating (amperage or current). If one transformer supplies both units then purchase another identical transformer and power each camera separately. If using a power supply (transformer and power supply board) you are most likely running your cameras at 24VDC. Again, purchase another power supply with the same volltage but a larger continuous amp output. Hope this helps. Let me know if I can be of further assistance.
Posted on Jul 07, 2010
My swann 8-camera system, each night goes into the "no video Mode" each night and comes back on in the daylight.
It's going into ir sound like you are not supplying enough power to the cameras or you might have a timer on you system
Oct 11, 2016 | SWANN H264 8 Channel Dvr W500 Gb Hard...
IR light doesn't work on security camera.
nitevision is in monochrome.. but if the irs dont work in that camera need to either get an ir light for that unit or replace that specific camera..the ir board is burnt out..or disconnected..I have several systems in use at different locations and I do installs for residential locations..I get some of my units off ebay..
Jan 20, 2014 | Zmodo Surveillance CM-S38901SV 540TVL High...
What is the difference between a simple day/night IR cameras and day/night IR cameras with IR Light?
The IR lights light up your subject with light that they can't see but the camera can in order to get higher quality recordings
Oct 16, 2013 | i-rocks IR-3230 Webcam
Why is my Lorex mini color weatherproof security camera only working in black and white d not showing color ?
Make sure it is not in a really shaded area. If the camera does not see enough light, it will stay in black and white mode. If that is not the issue, you might want to contact Lorex directly with the Camera model number.
Dec 25, 2012 | Lorex Corp SG6184S Weatherproof Mini Color...
The camera still works but when its dark in the room nothing shows on the monitor. If we turn the light on it works. It seems like the night vision feature is broken. I covered what looked like the light...
  1. It should go to automatic night vision. If this feature is not working then the answer to will a flashlight work the answer is not very well. The light will have to be on the child and a flashlight does not have much light behind it. Perhaps if you put a small lamp on a dresser that shines on the area the child is, this may work enough to keep an eye on him/her. A flashlight not so much. Hope this helps.
Regards, Tony
May 25, 2011 | Summer Infant Day Night Handheld Color...
Taking a picture, everything that is white is pink and dark pics
Oops, it looks like you have a couple of annoying problems with your Kodak camera.
Is your camera still in warranty by where you bought it (30 days) or the manufacturer (1 year)?
Jul 10, 2010 | Kodak EasyShare CX7525 Digital Camera
Manual
Well you can please follow the below link for the manual -
http://lorexstore.lorextechnology.com/pdfs/SY14Q5184CUQ-A-english.pdf.R1.pdf
Please post the model number of your security monitor if the above manual is not for your system.
Thanks for using FixYa!!
Good Luck!!
Apr 01, 2010 | Lorex Weatherproof Color Day/Night Camera...
I have a problem with my security camera being washedout/yellow/very bright during the day but perfect at night. if i go to the EC mode, i can get it good for the day, but it's dark at night. this just...
If you have a back lite compinsation turn it off.
if your camera dosen't have an auto iris, make sure that the EI (electronic iris shutter is turned on. let me know
Nov 28, 2009 | Panasonic Wired Network Video Camera
CAMERA GOES TO BLACK & WHITE A HOUR AFTER RESETTING POWER ON IT A
The SSC-CD73V and SSC-CD73VT cameras
offer a “Day/Night” function to provide
optimized sensitivity in both day and night
shooting scenarios. As the scene illumination
reduces and the acquired image darkens, the
infrared cut filter is automatically removed and
the camera switches to B/W mode, requiring
only a minimum illumination of 0.2 lx.
Incorporating an optimized lens for the
“Day/Night” function, the camera can produce a
clear and crisp image under normal illumination
or when used with near IR illuminators. In
addition, “Day/Night” modes can be
automatically switched, or manually initiated on
demand through an external control signal.
Apr 21, 2009 | Sony SSC-CD73V Color Mini Fixed Dome...
Does the W1 have infrared abilities?
The Sonys with Nightshot are best at IR, IMHO. The W1 does not have this feature. I imagine it could take IR pics in Manual mode, but the exposures would have to be so long that picture quality would suffer to an unacceptable degree, IMO. The V1 has nightshot, and the price on them has come way down since the V3 was introduced. If you want to get into IR, I suggest a V1.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Toshiba IK64DNA IR Day/Night Camera Logo
269 people viewed this question
Top Toshiba Home Security Experts
Lawrence Oravetz
Are you a Toshiba Home Security Expert? Answer questions, earn points and help others
