Question about Soleus Heating & Cooling
Soleus air conditioner sg-wac-25ese error code ep
koolbreezes
  • 540 Answers
SOURCE: The Plug on my Soleus
This mean the compressor is drawing too much amps, caused by the back cois are clogging up and not getting rid of enough heat.Hope you clean it soon before it ruin the compressor. Thank-you-very-much!
Posted on Aug 26, 2008
  • 9 Answers
SOURCE: Soleus KFR-18 Air Conditioner Problem
All of the kfr series have a indoor coil sensor that monitors the tube temperature. In the heating mode it will sense for high temp and cut off the outdoor fan to try to lower the indoor coil temp. The cut off temp is 129f, when the coil cools down the fan will cut in and start developing heat again. If the coil continues to get warmer it will shut off completely. The system is either overcharged or the coils and or filters are dirty. All Soleus units need both lines insulated seperately and not together because the metering device is in the outdoor unit. Have your tech calibrate the charge and make sure you clean your filters every 3 months. Removing the sensor will cause the indoor coil to get too hot and possibley start to melt your housing. For further technical questions pleas call 626-378-1518 for technical questions,,professionals only.
Phil
Soleus Tech Support
Posted on Mar 13, 2009
stamx
  • 9 Answers
SOURCE: leaking soleus air conditioner
must look www.stamx.com.br
Posted on Jul 06, 2009
  • 5 Answers
SOURCE: soleus mac 12-k air conditioner runs for 45
first of all an amp reading needs to be taken to see how many amps the AC is drawing. It may be too much for the breaker. Also see what else may be wired in on the same circuit, there may be additional load on the breaker. If all amp readings are below the rating for the breaker then you may have a faulty breaker, but that's pretty unlikely. The most probable cause is you are overloading the circuit.
Posted on Sep 22, 2009
6ylucy
  • 742 Answers
SOURCE: Error code E2 on Boston innovative products Air conditioner.
find the user manual here:
http://manualfox.com/link/bostoninnovative.htm
Posted on Jun 26, 2010
Why is my soleusair dehumidifier model GL-DEH-50 say F2
Pipe Temperature Sensor Malfunction.
1.
Unplug the dehumidifier.
2.
Check the surrounding area
for possible reasons for sud-
den temperature changes.
3.
Wait 2 hours before plugging
the dehumidifier back in for
normal operation.
4.
If the "Error" is still indicated,
please contact customer
service. Call 1-888-876-538
Soleus Air SG DEH 70EIP 6 Operating Instructions Manual Error Codes...
Jul 31, 2017 | Dehumidifiers
How do i get this to the heat setting ?
Hello there.
If you have the right model of this machine
Press 'mode' switch as per page 9 of user guide here
http://www.soleusair.com/Manuals/2014%20B%20manuals/SG-PAC-12E1%2012E1HP%20manual%2010052012.pdf
Also can do it on the 'remote control' if you have it.
Sep 16, 2014 | Soleus Heating & Cooling
Soleus dual mini split KFMHP18 fault error F1
F1 error code is a communication failure between the outdoor and indoor units. Check all inter-connecting wires. They should be minimum 14g stranded wire. Make sure all electrical connections are tight. These units are manufactured by CHIGO, you may try to contact them.
Aug 10, 2013 | Soleus Ductless Mini Split 18000 Air...
Split ac error code u8 what problem
3 possibility for U8 Error code:
1) Signal receiver faulty
2) PC board fails
3) Indoor blower fan motor faulty
Aug 03, 2013 | Soleus Powered By Gree 8000 Btu Portable...
Refrigerant leaking from a puncture in the copper tubing.
Put in a new piece of tubeing.First cut out hole, swag !a new piece of tubeing on both ends to fit over existing tube after claning and fluxing both ends of all four connecting pieces. Then silver solder all. Refill unit with the correct freon. Ifyournot familuarwith HVAC unitsI would suggest gtting profesonial helpl .
Sep 30, 2012 | Soleus SG-WAC-08ESE-C 8000 BTU Window Air...
I get a E4 errror code.
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen.
Jul 15, 2010 | Soleus LX-140 Portable Air Conditioner
Heating & Cooling Logo
82 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
