Question about Maytag Neptune MAH5500B Front Load Washer
Washing machine keeps beeping when i try to start it and it goes from the minutes on the screen to do to FL ?? ive tried turning it of and restarting it ?
  • Maytag Master
  • 3,051 Answers
Hello there: FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. You may want to have the water level sensor replaced cause this will cause this condition if it is faulty ok
Hope this is very helpful for you
Best regards mike
Posted on Jul 07, 2010
My whirlpool duet washer is giving an error code of FL
What error code is it displaying and what is the brand model number and serial number? All units are a little different....I want to provide accurate answers....Help me help you....
Waiting to hear from you,
Eric and Ann Campion
P.S. Please keep in mind we help pay our staff with earnings from parts sales. Help us keep this valuable service free and order your parts from us. Visit our website for additional help at http://www.affordableappliance.com or for Parts Order Only, Call 1-570-622-6441
May 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine keeps beeping then all lights and screen start flashing.
i would guess that you have a faulty main board, the quickest and surest way to determine the problem and that is to replace it with a second hand board out of an known old machine which has faulty seals.
Dec 11, 2011 | Fisher and Paykel Washing Machines
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Elite top load washer will not begin wash cycle and keeps flashing "FL" and beeping twice every few seconds. Tried unplugging it to see if the electronics would re-boot. How can i correct this...
Hi
Thanks for using FixYa. Error LF or FL means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool cabrio washing machine
FL error code generally means 'flood condition' which is telling you the machine is overfilling with water with water.
Try pressing STOP/CANCEL to clear the display.
If the condition persists the water fill valve or sensor may be faulty and may need replacement.
May 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool calypso top load washer GVW9959k stuck on FL
FL=FLOOD CONDITION
I bet I know what the root cause of the problem is. TOO MUCH DETERGENT. Why do I yell that? OK here is what happens. Suds make the computer monitor work overtime to wash the clothes. The the computer measures the amount of water being used. The computer is also trying to correct the suds problem by adding water during hissy-cycles. (I call em hissy cyles.) Solution: Clean the soap dispencer use HE soap and use the right amount which is:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Calypso Service Manual
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
LID WON'T LATCH ERROR CODE FL
With that code FL “ Failed to lock” I would start looking at the lid latch mechanism. See this link from another site for lid latch problem.
http://fixitnow.com/wp/2006/09/06/maytag-neptune-fav6800aww-top-load-washer-op-code/
If you want to try to repair or get a better understanding of how to diagnose and repair this machine take a look at the service repair manual.
http://www.servicematters.com/maytag_library/docs/16022808.pdf
I hope this will help with your decision to try a repair or replacement.
Good luck with your issue.
Jan 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
138 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
