Question about Garmin Nuvi 660 GPS Receiver
Turns off due to low battery even when plugged in to lighter socket. Have checked fuse and appears ok. Even replacing fuse doesn't help. After ac recharge unit works for only half hour before cutting out.
  • Garmin Master
  • 2,130 Answers
If unit is 2 years older or older, the battery is defective and needs to be replaced. Please see these links:
http://www.sharc.net/gps_battery_repair.htm
http://www.sharc.net/gps_charger_repair.htm
- Jim
Posted on Jul 08, 2010
My cig lighter dose't work in my 1992mitusbishi Galant
possible blown fuse or bad ground check wiring to make sure all wires are pluged in if so replace lighter
Feb 08, 2016 | Cars & Trucks
Garmin says low battery and now will not work in the car. Does this Garmin have a battery inside the unit that I have to replace?
There is a battery in the satnav but it's not user replaceable. It can only be replaced by returning it to Garmin. Before sending it away to replace the battery you could check the following;
  • Have you the satnav connected to the charger?
  • If it's connected to the charger is the cigarette lighter socket working. You can check by plugging in another device to see if it works
  • If the cigarette lighter socket is working and the battery of the satnav is not charging it's possible that the fuse in the plug, that goes into the cigarette lighter socket, is blown.
To change the fuse;
Unscrew the ring that's at the end of the plug and the plug comes apart. Be careful not to lose the silver coloured tip. When the plug comes apart you can take out the fuse and get a replacement at any car accessory shop or a shop that sells garmin satnavs.
If you have to return your satnav to garmin you can find their contact details at http://www.garmin.com/garmin/cms/home/support/supportcontact
May 23, 2011 | Garmin nuvi 255W GPS Receiver
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
Lighter plug wont work no blown fuse
sometimes there is a seperate fuse for just the lighter in the wiring behind the lighter socket you will have to either remove the socket or find the wiring under the dash to see if their is a fuse and replace it if it is worn or even possibly the connections to the socket have worn or become disconnected
Sep 03, 2009 | Mazda Protege Cars & Trucks
Please help me with power in cig lighter
Hi, grab a voltmeter and test volts at car lighter connector, near to car lighter socket, if there is volts in there (uncommon) , then check for short or broken contact on car lighter socket, or replace the first socket connected in line.
If there is no voltage getting to cig lighter, check the two connections at the back of the fuse box, on the cigarette lighter fuse.
If there is volts only on one side, then fuse is gone again, in that case there is a short on wiring, maybe on one of lighters, locate it and fix it.
If there is power on both sides of the fuse, then fix or replace wiring between fuse box and cigarette lighter, one wire is broken.
If there is no power on both sides of lighter fuse, then fix the wiring between fuse box cig. lighter contact and battery, if this is too complicate you can even build a new wiring and solder in place of the old one.
If the lighters have more than one fuse, do the same job for both lighter. Cig. lighters do not use a relay, and there is no additional fuse, the above procedure is enough to fix any possible problem on such a simple device.
If you have no practice with this kind of repair on car electrical system, then better to go to a car electrician or mechanic rather then messing up the car electric system.
Please do not forget to leave us feedback afterward, that is important for us.
Many thanks.
Apr 22, 2009 | 2002 Mitsubishi Montero Sport
Has been working fine..now will not turn on.
It sounds like a dead battery?
When it is plugged into the car, you should see a charging symbol, or it will say charging if the screen is off.
Are you sure it is getting power from the car? Check the fuse for the lighter socket, also the power cord has a fuse in the end that goes into the cigarette lighter socket, if you twist the end of the adapter it should open and expose a fuse.
Check these fuses to be sure.
Hope this helps.
Apr 17, 2009 | Garmin nuvi 200W GPS Receiver
Cigarette lighter won't work
The front lighter is powered by fuse 24 in the interior fuse panel and the console power points are fuse 7 and 9 in the battery junction box under hood.
If you have a 12V test lamp you can check the socket for power and check the wire to the socket.The socket may be bad.
Apr 08, 2009 | 2005 Mercury Mountaineer
Germin Nuivi 660
Hi there. I use one of these in my taxi in South Australia. Great GPS. The problem you are having is usually due to the power supply from your cigarette lighter (12V socket) not opperating properly. Check the fuse in your car and replace if needed. Also the power cord might also have a fuse in the end where you plug it into your car. Hope this helps.
Have a good day and good luck :)
Ben
Mar 24, 2009 | Garmin Nuvi 660 GPS Receiver
Cigerette Lighter won't work 2003 galant
the fuse you are looking for is accy or accessory. I hope this helps. Don't forget to rate my answer, thanks.
Feb 13, 2009 | 2003 Mitsubishi Galant
Garmin Nuvi 660 GPS Receiver Logo
160 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
