Question about Compaq Armada E500 Notebook
Memory hi im struggling to get memory into my computer,i know that it is under keyboards,but how do i get under keyboard,regards chris
  • christoff777 Apr 18, 2008
    THANKYOU VERY MUCH FOR YOUR HELP.I WAS TOTALLY BAFFLED,REGARDS CHRIS
    Genius:
  • 1,027 Answers
On the bottom of the unit there should be 1 screw towards the center that is the keyboard screw.
After opening up the display 4 slide tabs should be visible along the top row of keys, slide these towards you.
Gently lift up the keyboard as the ribbon cable is still attached.
Posted on Apr 18, 2008
  • Mark Williams
    Mark Williams Apr 18, 2008
    If this was a "fix" please credit the appropriate tech.
    Also if you need the tech manual let me know and I can Link you to the site.
    Scholar:
  • 144 Answers
You've to see at the back of your notebook, you have to unscrew that say say KB. Incase it is not written then unscrew all the top and middle screw.Some model after unscrew you have to remove the front panel first before removing keyboard or some model remove the front panel and KB screw is underneath it.By saying Front panel, I mean the panel at top where you press power-on button and all.
How do i find the memory slot on my Advent Quantum Q100?
The Advent Quantum Q100 laptop has one Ram memory slot.
The Maximum Total Amount of Ram Memory is 2GB.
It uses SO-DIMM ram memory that is DDR2 at 667 MegaHertz. (667MHz)
Also known as PC2-5300 {SO-DIMM style}
The Ram Memory slot is under the Keyboard.
Past this point I am at a loss to describe how to remove the Keyboard.
1) Either you have to remove the LED cover above the Keyboard, and below the LCD screen to access screws which hold the Keyboard in place, (Computer off, and ALL power removed. AC adapter {Charger}, and Battery),
OR,
2) The LED cover (Power On button, LED's, etc, are in the cover), has to be removed, and there may be one, or two screws coming up from the bottom of the laptop, which hold the Keyboard in place.
Regards,
joecoolvette
Jun 26, 2011 | Advent Computers & Internet
My acer aspire one notebook keyboard totally not working. i tried to bring this problem to technicians since i dont know regarding about computers. they restore system and tried to fixed the ribbon under...
I would contact acer and talk to their tech support, so they can send you a new one. It seems to me that is a default computer, which means it's broken.
May 10, 2011 | Acer Aspire One PC Notebook
Show me where i insert memory in a samsung vm8000 laptop
on this page:
http://www.samsungpc.com/products/vm8000/vm8000_faq/vm8000_faqanswer6.htm
You can download instructions on replacing or adding memory (is a Powerpoint presentation).
If I could be offurther assistance, let me know. If this helps or solves the issue, please rateit and give a testimonial for my response.
Mar 05, 2011 | Computers & Internet
Memory upgrade for laptop - not sure what to unscrew
Most laptops are this way, but yours may be a special case.
Most have two ports one is underneath a removable panel on the bottom of the computer, and the other is under neath the keyboard. To remove, look to see if you can remove the area between the keyboard and screen, if not find a screw or screws on the bottom of the keyboard labeled "k", once those are off the keyboard is loose and is just lifted off.
Always remember to not prey to hard,if it is going to come off it will come off without struggle, and have your battery and power disconnected first, and the computer is off...
Jun 17, 2009 | Fujitsu Siemens Computers & Internet
Is there another memory slot under the keyboard?
how to check the Ram slot location
1) most laptop have two slots at back, so no other slot under the keyboard
2) some laptop has onboard Ram(on the surface of motherboard) ,if you see one slot at back so no any slot under the keyboard
3) if the laptop no any slot at back it should be one or two slot under the keyboard
your laptop no ram slot under the keyboard
hope it help you to improve your idea
May 09, 2009 | Computers & Internet
Memory Upgrade
Here is how to upgrade ram on E-System 3086/Advent 8109 laptop.
Mar 27, 2009 | Toshiba Satellite A85-S107 Notebook
Memory uprgrade
You have to remove the keyboard, under the keyboard to the left is a heat shield (silver metal cover), remove it. Your ram is located there. Just take your time and remember where the screws go.
Jan 22, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
Nov 13, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
