Question about Grundig YB 300PE AM/FM/SW Radio
Static on every station, no matter where i plug it or how i rotate the antennae. this just started in the last few months
  • Grundig Master
  • 17,130 Answers
Possible that you have a EMI interferance in your circuit or power which carries into the set..Use the set in the battery mode and swtich off all the mains in your house. if this solves, then check on by one the connected appliances which might produce this static. You could also take the set to another location to see if this reduces off . in this case you will have to check if there is a lurking interferance from the power source. I suppose you might not get this faultt with the FM but MW and SW is bound to pick up the static unless the signal is powerful. Please also try to check your external cords, if possible change the location of the antennae. Further any fault on the radio IFT/filters could be considered. Hope my advice helps you . Good day
Posted on Jul 07, 2010
Limited radio stations
Check the connection from the radio to the antenna.May not be plugged in.
Jun 01, 2017 | 2011 Kia Sorento
Ive retuned, re-set, unpluggest and plugged back in and i recieve no channeks still, been like this for months
What is your TV source? The Polaroid LCD-2000 only has a NTSC (analog) tuner. Most OTA stations switched to ATSC signals a few years ago and a converter box is required to watch the TV. (A few low power TV stations still broadcast in NTSC but you need to be fairly close to the transmitter to receive the channel.) If you have cable, check if they have migrated to digital cable (QAM for unencrypted channels). If that is the case, you'll need a cable box.
With a digital-to-analog OTA converter box, you can still lose station reception due to the signal strength cliff. Depending on your area, you may need an external antenna or to check the direction of the antenna. I know I have to rotate the outdoor antenna every so often. It shifts in high wind. Even if the antenna only moves 5 degrees, we will lose the signal for half of the stations.
I hope this helps.
Aug 10, 2015 | Polaroid LCD 2000 LCD2000 TV flat screen...
Fm radio static solutions
yes if there's no antenna the cable should be stretch out towards outdoor and try to put the radio somewhere best static is out; other thing can be that the radio station is too far!
Jan 22, 2015 | Bose Wave Radio
Radio static truck ground shield wire
There are a few things you can try. AM stations use a lower frequency than FM and that is why it picks up static.
You can unplug the small plug-in at the Alternator and then start the car. The charging system will be inoperative and you will trace the problem to the charging system. This does not mean it is only the Alternator, it could be a bad wire coming from a good Alternator.
Sometimes a Bench check of the Alternator will reveal this type of problem and sometimes it does not.
You also could just need a new Antenna. Unplugging the old unit and wire and using a new replacement for the antenna wire could solve the problem. This could be tested before needing to route the wire through the body. Just remove the radio, or unplug the installed antenna lead and temporarily plug-in a new antenna.
Hope this helps.
Jun 08, 2013 | 2011 Ford Edge
I can receive FM stations properly. I cannot receive AM stations at all. Only a static sound. I disconnected the AM antenna leads and used an Ohm Meter. The meter read full continuity when I touched...
you may be in an area where am stations don't come in,, am uses straight lines of frequency where FM uses a modulated signal, which travels much farther, I bought a antenna signal booster from radio shack for a few dollars , and was able to get the stations, some pretty static filled though, but the more local ones came in ok, another thing to check is that the unit is plugged into a grounded receptacle ,
Sep 10, 2011 | RCA RTD217 Theater System
I own a bose radio/cd (top load) with pedestal. Last night one lightning strike affected power in my home before I could get things disconnected. Now with everything reconnected, my radio FM and AM is very...
The tuner section may have been toasted by the power surge that affected your home. See if there is another option for an antenna connection and try that. If not, then it does not appear you have much choice.
U might want to contact Bose for an authorized factory repair station in your area.
Apr 01, 2017 | Bose Wave Radio
Radio effected by brakes?
If this happens when the car is still you have voltage interference between brake light voltage & antenna. If this happens from motion check all wire connections, loose antenna wire, to antenna.
Oct 21, 2008 | 2004 Cadillac CTS
FM Radio doesn't work
it may be that the fm detector has failed or possibly a tank(tunning coil)
Aug 31, 2008 | RCA RS2664 Shelf System
Radio does not work
If the unit is only a few months old, returnit for warranty repair or exchange. A power fail should not effect it. Try unplugging it for a few hours to force a system reset. If that fails to resolve the problem, have it serviced under warranty.
Dan
Jun 03, 2008 | Audio Players & Recorders
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
Grundig YB 300PE AM/FM/SW Radio Logo
194 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
