Question about Dell Dimension 2400 PC Desktop
New wireless network trying to connect to unsuccessfully
I have a dell dimension 2400 that I am trying to connect to a new wireless network my lan is saying no network connection available and I have a wireless router and modem through quest how do I connect to it? The pc has a wireless network card installed in it.
  • Dana P Jul 08, 2010
    First thing I would do is make sure that the LAN is disabled and enable the wireless connection...is this an existing network or brand new?
  • 41 Answers
Try going to Network and Sharing Center - Manage Network Connections. Click on the connection and enable it.
Also try Network and Sharing Center - Manage Wireless Connections, and moving the wireless connection you'd like to use and move it to the top of the list. Select any operations that will enable or connect to the network.
Posted on Jul 09, 2010
I think i used the wrong disc to install windows on my dell dimension 2400. its stuck on 16-bit mode and the resolution won't change from the 800x600? and i can't connect to the internet, but my...
Hi there, On your laptop that can get on the internet, go to www.dell.com/support and download drivers for your Network Card and your Video Card from that site. Make sure you put in the right model number (dimension 2400). Transfer them to a USB key, and move the USB key to your desktop. Install those drivers and everything work will again. You may need to install additional ones as you see other things not working (like audio). If you need more help, let me know. -Alex
Aug 13, 2011 | Dell Dimension 2400 PC Desktop
Can I hook up my dell dimension 2400 to my laptop to act as extra storage space?
you can the best way is to great a network and make a drive shared with allow changes to be made by network.
hope this helps
Jul 23, 2011 | Dell Dimension 2400 PC Desktop
For my Dell Dimension 2400, I'm trying to use the Network Setup Wizard, but I can't because it says there is no hardware... Do I need a certain driver or program? I have an ethernet cable that is connected...
To connect your computer to the Linksys wireless router using the LAN card in your computer you need to install the LAN card driver. If you want to use a wireless connection with your Dell desktop, you will need to install a wireless card on your Dell plus the wireless card driver.
For the LAN card driver, download the driver from the Dell WEB site.
You can download the device drivers from Dell WEB site,the support download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows of the drivers for your Windows operating system. Click on thislink to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
May 02, 2011 | Dell Dimension 2400 PC Desktop
Hello im troubleshooting a error on a dell dimension 2400, windows xp error when testing or querying the modem the error reads cannot connect or check to see if hardware is powered on or connected...
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Jan 05, 2011 | Dell Dimension 4500 PC Desktop
Dial up connection ok but wireless will not open explorer Dell computer 2000XP Eircom connection
The dial up connection may be corrupt
delete the dial all the existing dial up connections from
internet explorer>Tools>internet options>Connections>
remove existing dial connections in Dial up and virtual private network settings
add a new dial up conection and set it up again
It show be up and running
Feb 11, 2010 | Dell Dimension 2400 PC Desktop
I have a Dell Dimension 2400 and have Ethernet Port problem
I am having the same problem, but my computer is registering that i have a card and it's working. My system is just saying the cord is unplugged. Does anyone have a solution?
May 13, 2009 | Dell Ethernet Card Network Adapter
DESK TOP TO WIRELESS CONNECTION
First make sure you have the correct drivers installed, go to the Belkin website to get the latest drivers for your device.
Next make sure that your router is set to broadcast, and that is in Wireless G mode. You can find that information at the router manufacturers website.
Apr 15, 2009 | Dell Dimension 2400 PC Desktop
Need ethernet driver to install internet on dell dimension 2400
http://drivers.softpedia.com/progDownload/Dell-Dimension-2400-Broadcom-4401-LAN-Driver-Download-40466.html
Mar 18, 2009 | Dell Dimension 2400 PC Desktop
Wireless network
You will need to set the drives on the other networked PCs as "shared" before they will be visible on the network. You can do this by right clicking on the drives (while on the other computers) and going into the "sharing" tab. You must enable sharing and then set a name for the drive or folder you want to share. You can either share the entire drive or a specific folder, I recommend limiting the sharing to a specific folder instead of a whole drive for security purposes.
Happy sharing!
Mar 22, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
199 people viewed this question
Alun Cox
