OK..I have a SSI Cineplex 1500 Home Theater System.I've connected all wires to speakers,I have a 2 wire connection going from Home Theater input,going to output on satellite output. When I hit Tone test I hear I guess the test tone, then I also hear the TV, but when I cut off test tone I lose all sound going to my Home Theater,all I hear then is the TV speakers...Can You Help?
  • moonrunner63 Jul 07, 2010
    If the rca wires I have already are not suffient how is it that while test tone is on I hear test tone and sound from the system?
    Thanks for help.
    Guru:
  • 468 Answers
I am not an expert in Theater Systems but it seems to be like a connection issues. I advise you to unplug all the cables and replug it and try to play the statelite TV. Also, I have found a toll free number for SSI technical support. You can visit call or visit the below mentioned links:
http://www.ssihtp.com/1500/1500.pdf
Toll Free Technical Support (800) 845-4774
Technical Fax Support (626) 305-0201
E-Mail Support info@ssihtp.com
http://www.ssihtp.com/Supports.htm
Posted on Jul 07, 2010
    President:
  • 1,561 Answers
First things first, READ the Instruction Manual, I know most of you guys out there hate reading the instruction manuals but every system is different, so I'll try to generalize this article for an average system you can find at a retail store today.
Make sure you have the right cables to connect your TV to your Home Theater System, now days the best connection is called "HDMI" (High-Definition Multimedia Interface) this cable uses a digital signal to transfer both video and audio while giving you the best quality possible. But please make sure your Home Theater System has the "HDMI" as an input option. If it does not, you might have to resort to a analog connection such as "Component Cables" which will provide you with a High-Definition connection but with analog quality.Now if you are using a current TV and a current Home Theater System and your system is able to use the "HDMI" cable, connection to said devices will be pretty easy, just hook one end of the "HDMI" cable to the "HDMI" input on the back of the TV, and the other end of the "HDMI" to the "HDMI" output on the back of the Home Theater System. Turn your devices on and make sure your input/outputs are configured for "HDMI" usage and vola! You should now be able to see and hear everything your heart desires!Organization is key, after you have checked your connections and everything is working the way you want it to, utilize the cable/wire loom to organize your cables and use the zip ties to secure them in place, not too tight though, if you want to change things around in the future it's easier to cut the zip ties if you have enough room between the cable and the zip tie.
Take care.
Need help with SSI Cineplex 1500 Home Theater hook up..have all speakerwires hooked up,have 2 wire rca cable hooked up to input on system,going to output on satellite reciever, whaen I hit test tone I hear...
Hi, Hiss soundare from RCA cables.You need to reconnect again,but using a different cable for connection.
And also sometimes home theater acts that way during test mode, Check the manual and you will see how to set the home theater to see the mode that will allow all speakers to work. It's a normal thing when connecting a newly bought home theater.It the settings.Use the manual.
Take care.
Jul 07, 2010 | Audio Players & Recorders
Have ssi ceneplex 1500...need help in connecting to tv..connected all wires..no sound..can you help?
Hi
You probably have your rca in the wrong output u have to put the rca yellow red and white coming out of the tv on an output not an input and put the other end in the entertainment in an input and where u plug it in it should say aux or aux 2 or video1.
Please check the bellow link for further help…
http://www.ssihtp.com/Cineplex%20220/C220.pdf
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 07, 2010 | Ssi Cineplex 220 System
Soundproblems on my Home Theater System
http://downloadcenter.samsung.com/content/UM/200702/20070207171859140_XQ100TXQ100_GB.pdf
Suggest you go back and check all connections with speakers that wires are connected with input properly I have given you web address for manual usually find wires are not bared back enough for connection test each one individually with a tester to make sure there are no broken wires.
Mar 05, 2010 | Samsung HT-XQ100 Theater System
5.1 Dolby system does not work with the T.V.
Solution: connected the rear right and left wires to the Front , left and right wires......................and everything works the way I anticipated without any technical problems....... the woofer works on a separate circuit, so I continue to receive the "low" frequency..
Oct 01, 2009 | Memorex MiHT5005 Theater System
Does this system have traditional speaker wire connections
Yes.
Connect the appropriate wire(s) from the DVD-958 speaker connection(s) on the back of the unit to the wall connection(s). You should match the impediance of the speaker to the unit.
Feb 24, 2009 | Coby DVD-958 Theater System
Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Jan 28, 2009 | Philips HTS-3565 Theater System
No sound from my home theater system when switching it on
On the front of amp,there usually is 2 buttons for speakers A & B,make sure both are depressed
Jul 11, 2008 | Durabrand STS92 System
Remote control
You can get a new remote @SSI.com
Oct 23, 2007 | Ssi Cineplex 220 System
Open Questions:
136 people viewed this question
 Grubhead
Grubhead
