Question about Jetway P4MVMP Motherboard
Just reinstall my pc and no sound/multimedia driver for xp. Where can I get for P4MVMP motherboard?
    Brigadier General:
  • 4,044 Answers
You'll have to search the Motherboard Manufacturer website for the driver downloads and download the driver package for your motherboard.
Posted on Jul 07, 2010
What should i do to get my sound device and controller?
Hi riteshscorpi,
Since you have a multimedia audio controller or Sound Card installed to your motherboard, reboot your PC and enter the CMOS/BIOS setup and disable the Onboard Audio.
Save your new settings.
The PC should immediately detect your Sound Card and ask for driver.
Install the Sound Card driver completely and reboot your PC.
Finally, configure the Audio properties to your desired adjustments.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 30, 2011 | MSI 945GZM3-L (7267-020(945GZM3-L))...
P4MVMP audio driver
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 30, 2011 | Jetway P4MVMP Motherboard
I need audio driver?
here's what you need http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+845+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D845GVSR
Sep 24, 2010 | Jetway P4MVMP Motherboard
I reinstal XP and know all drivers are missing. I don't have sound.
download the drivers at via's website, or the soundcard manufacturers website
Aug 05, 2010 | VIA EPIA-MII 1000 C3 Nehemiah 1.2 GHz...
I reinstalled my window due to viruses.i ran setup in motherboard cd.even then there is a question mark before pci device icon. due to it there is no sound in my pc.my motherboard cd reads mercury...
The yellow question mark is telling you that there is a problem with the device, namely your sound card. It is probably needing the drivers for the card. If you have the disk for the sound card, use it and install the drivers or go to the web site for the card and download and install drivers from there. This will solve your problem. Good luck
Jul 16, 2010 | Computers & Internet
Video n audio driver for my motherboard..
hello: if you download for free from this site http://www.gtopala.com/ the system information for windows , thad gives you a lot of information from your pc and software it are for free no regestration need (freeware)
Nov 01, 2009 | Jetway P4MVMP Motherboard
Multimedia controller
hi try to remove all drivers in program files and in device manager then try to install all drivers again
Sep 01, 2008 | EliteGroup P4VMM2 Motherboard
No sound device
? mark means no sound driver install or errors in Device Manager. u can check ur mother board cd room or can search ur audio driver in web or below may be ur answer
Question: Where do I locate motherboard sound drivers?
Answer: Users who have motherboards with on-board audio (often with VIA, Realtek, or C-Media chipsets) may have issues with their audio or AC'97 errors in Device Manager. Often this is caused because the operating system has been reinstalled and the motherboard chipset drivers are not installed. To resolve this issue try following the below steps.
Let Windows redetect drivers
If you have not recently reinstalled Microsoft Windows it's possible that your audio drivers are simply corrupt. Open Device Manager and remove all devices under "Sound, video and game controllers" and any "Other devices". Once removed reboot the computer and let Microsoft Windows re-detect the audio drivers.
Motherboard chipset drivers
Reinstalling the motherboard chipset drivers will usually resolve this issue. If your computer came with a Motherboard CD, install the chipset drivers from the CD and the sound drivers if also available on the CD.
If you do not have a motherboard CD, obtain the motherboard chipset drivers from the motherboard manufacturer.
Sound card drivers
If after installing the motherboard chipset drivers you continue to have issues install the sound drivers. We suggest you download the sound drivers from the computer manufacturer or motherboard manufacturer.
A listing of motherboard manufacturers and their drivers can be found on our motherboard chipset drivers page.
Aug 30, 2008 | Microsoft Windows XP Home Edition
Jetway P4MVMP Motherboard Logo
80 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
