Question about JVC KD-G310 CD Player
Can't set the clock on a jvc KD-g310 car stereo
  • tami lynn May 01, 2008
    i just followed the solution and managed to get it to work, but here is anouther helpful hint... on my stereo the DEMO was OFF i needed to first hold down the select button until it said DEMO OFF and then i needed to use the fwd/rwd button to select DEMO ON. after i did this i turned the stereo off and then onn again. once i did this i held the select button down and CLOCK H showed on the screen, i followed the directions from there and it worked.
  • 51 Answers
Well if you just can't like it wont let you, then you need to sent it in, but to set the clock you need to:
1. Hold the Select button, the big round one, down.
2. Select "Clock H" for hour or "Clock M" for minutes. By using the Fwd and Rwd Buttons.
3. The round toggle turn up and down to change the numbers.
4. Press the center to enter that time.
If you have any other questions, please let me know. Thanks!
Posted on Apr 18, 2008
How to set clock on jvc k d g310
Check the page 8 for JVC KD-G310 CD Player user manual.
Hope this helps.
Jun 29, 2011 | JVC KD-G310 CD Player
My JVC KD-G310 won't switch to EXT IN after plugging in a KS-U58 cable (j-link to 3.5mm connector) into the external component port. How do I get this set right?
did you ever figure this out? i just replaced a broken KS-U58 cable on my JVC KD-G310 and now i can't get it to switch to EXT. everything else on my stereo (CD, radio) works fine.
Jun 10, 2011 | JVC KD-G310 CD Player
How do set the clock on a jvc kd-g310
Hello... sorry you are having a problem with this unit. Here is the procedure to fix your problem. Press and hold the SEL button in the middle of your volume dial. Select "Clock-H" and "Clock-M" with the seek buttons in the bottom right corner. Use the volume knob to set hour and minute. Hit SEL button to exit the menu when you finish. I hope this helped!
20 year car audio/video installer
Bay manager
Mar 14, 2011 | JVC KD-G310 CD Player
KD-G310 How do I set the clock?
  • 1. Press and hold (S) SEL Button
  • 2. Canceling the display demonstrations Select "DEMO," then "DEMO OFF" Setting the clock
  • Select "CLOCK H" (hour), then adjust the hour.
  • Select "CLOCK M" (minute), then adjust the minute.
  • 3. Press and hold (S) SEL Button to finish
Nov 16, 2010 | JVC KD-G420 CD Player
How do you set the clock on jvc kd g 310 cd player
Press and hold the SEL button in the middle of your volume dial. Select Clock-H and Clock-M with the seek buttons in the bottom right corner. Use dial to set hour and minute. Hit SEL button to finish procedure.
Feb 24, 2010 | JVC KD-G310 CD Player
How to set time on JVC KD-G310 car player?
Press and hold SEL until menu appears
Using the scan button (FWD/REV), select Clock H
Using the volume knob, set the value
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
Jan 15, 2010 | JVC KD-G310 CD Player
JVC KD-G310 stopped working after battery change
have you pulled the deck and checked the built in fuse beside where wiring harness plugs in
Oct 19, 2009 | JVC KD-G310 CD Player
How do I set the time on my JVC KD-G310
Push in the select button and hold it for 3 seconds. scroll through the list using your next button for the radio on the bottom right hand corner. once it says Clock H you can turn the volume knob to set the hour. hit the next button again and it should say Clock M for minute and use the knob again.
Oct 19, 2008 | JVC KD-G310 CD Player
Clock
Press and hold the 'select' button until a menu displays. Use track forward to cycle through the menu and the volume knob to cycle through options of each menu. You will find 'Clock H' and 'Clock M'...set accordingly.
Apr 13, 2008 | JVC KD-G310 CD Player
Car clock setting
For the JVC KD-G200 look here for instructions on how to set the clock...
http://www.fixya.com/support/p187738-jvc_kd_g200_cd_player/manual-17158/page-9
Nov 25, 2007 | JVC KD-G200 CD Player
JVC KD-G310 CD Player Logo
183 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
