Question about Pioneer GEX-INNO1 XM Radio Receiver with Home Kit
My Xmp3i radio displays "Powering Up..." and does not boot up.
This follows an attempted firmware update from XMradio.com/xmp3update procedure. disconnected usb cable when told, then radio nor update program did not control the shutdown and reboot. Tried to power down manually by holding switch down. Radio displayed "Please wait....." any way to reload the usb driver?
  • 5 Answers
SOURCE: PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Posted on Feb 20, 2008
LVT7857
  • 116 Answers
SOURCE: 6 dsc changer stock radio 99 ford explorer cddj error
I've had GREAT success by resetting the changer. Try unpluging the changer with the power ON, wait a few, then plug back in. It's not hard to remove. Can I assume that you did NOT misload or install any CD' upside down? If not, then proceed with a reset. Can you eject the magazine? If so, proceed with reset. If you can NOT eject the magazine, then you will need to "open up the can" and do a manual eject with power assist by moving the gears while pushing the eject button. Sounds like a lot, but for me it's easy. Remember patience!!
Larry T
Winona Lae, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
  • 136 Answers
SOURCE: setting clock on pioneer radio
you will need to turn unit off then press function button for a few seconds this will take you to the clock function.
Posted on Sep 05, 2009
SOURCE: Trying to update firmware on
I had the same problem and immediately suspected that, as I had downloaded and expanded the .zip file on a Mac, I was suffering from the industry's usual bovine shortsightedness and that I needed to do it on a PC. I did and it worked. So I think the important part is to un-archive the .zip file on a PC, and find the file inside the resulting folder called
BDP12X_149.MVP
Make sure you have just that file on your USB stick, and no folders, and then the player should recognise it. You'll note that Pioneer's instructions don't mention this file name at all. Useless. Wish I'd bought another brand.
Posted on Dec 29, 2010
The reason it does this is because you are using a Mac's default un-zipping tool. Download Stuffit Expander and it will work no problem. - www.stuffit.com - It took me weeks to work this out. P O S.
Posted on Feb 27, 2011
Testimonial: "Good answer. Another solution (as i found out) was to download and unzip on a PC. Very backward of Pioneer to be un-Mac-friendly."
My hisense 55h7b tv keeps prompting to upgrade firmware, but then displays "not enough space" after attempting to update.
Corrupted firmware. a re-install is necessary. Contact the authorized service center for Hisense. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Feb 12, 2017 | Hisense Televison & Video
I turn on my leg 896 , the video player just say boot on the display. Why?
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 06, 2016 | Televison & Video
The screen on my Kocaso M9200 stays black even though I have it connected to a viable charger. I NEED this to boot!!
Kocaso M9200 User Manual FAQs states ...
"Why won't my device turn on?
Make sure your tablet has been charged for at least four hours prior to use. When plugging in the cable, make sure you are not accidentally plugging it into the headphone jack. Also, the power button is on the side (for tablets) and not the one on the front of the touchscreen. The button on the front is for navigation".
"Should I perform a Firmware Update?
Not necessarily. This is actually intended if obscure issues with the tablet occur. Unless you are having issues with the tablet which a
Factory Data Reset has not resolved, it is not advised that you perform this step. However, if you are sure you wish to attempt this procedure, please visit the following link for available firmware downloads and the instructions on how to perform the update:
http://mymidpad.com/firmware/"
Link for M9200 .. Support Firmware. Please read details and only attempt firmware upgrade as a last resort. Its always best to get it done at a Kocaso service center. Hope this helps.
Feb 09, 2014 | Computers & Internet
Epson stylus workforce firmware problem
You have attempted to update your Epson product using the Epson Driver Update and Download Navigator software but have found that the product is stuck in Recovery Mode. This message is displayed on the product's LCD screen and you will be unable to perform any actions until this issue is resolved.
This error can occur if the firmware update procedure is interrupted, e.g. accidental powering off the product, cables being removed or the installation being cancelled.
SOLUTION:
The first method of resolving this problem is to wait for a few moments and a pop-up should appear on the computer screen, clicking on the link indicated below will direct you to a tool that will correct this issue.
In the event that the pop-up mentioned above does not automatically appear or has been accidentally cancelled, the Firmware Recovery Tool can be accessed manually. Follow the instructions below:
  1. Go to the Epson Support website and select your product using the drop-down lists presented.
  2. Click Drivers & Software.
  3. Firmware Recovery Tool will be listed, click direct download.
  4. Read the license agreement and tick the I have read and accept these license terms box and click proceed to download if you would like to continue.
  5. Once the download is complete, run the file as normal for your operating system and follow the on-screen instructions to complete the firmware update.
May 12, 2013 | Office Equipment & Supplies
XMp3i is stuck on "powering
Bad TSOP flash chip. No way to fix without disassembling, removing the flash chip, and placing a new flash chip on it. Doing so requires a donor radio (with another issue), and will change your XM Radio ID. You'll also need to have a hot air (or IR) rework station for desoldering the old chip, and a soldering iron for placing the new chip on the radio.
I'd say give pioneer a call since it's a design flaw, and a VERY common issue. My best guess is that it's caused by excessive heat & defective chips.
Aug 07, 2011 | Pioneer GEX-INNO1 XM Radio Receiver with...
Problem with the Delphi SKYFi3 XM Radio Receiver UNIT LOCKED UP WILL NOT COME ON OR GO OFF
Common problem with SkyFi3 units. You have to press the Volume UP button and hold it while you press the POWER button; this will 'reboot' your radio, then you can try it again to get it to go off.
You will need to update your firmware on the radio using the baby USB cable and the unit plugged into your computer WITH the battery recharged FIRST. Also, go to the www. xmradio dot com website and download the SkyFi3 FIRMWARE update. Then you need to download the "firmware update" into your SkyFi3. If this doesn't fix your lockup problem, you need to call DELPHI customer support, and they can tell you one more 'master reset' method. After the firmware update, it might take 2 or 3 'restarts'. Again, press and hold the Volume UP and PWR at the same time to reset a 'locked-up' SkyFi3. Regards, John
Oct 01, 2010 | Delphi SKYFi3 XM Radio Receiver
How do I use a new MicroSD? Unit locks up when Checking Media
First of all, suggest using an SD card of 2GB or under. Second, firmware update. Here's the details: This is a common problem with SkyFi3 units. You have to press the Volume UP button and hold it while you press the POWER button; this will 'reboot' your radio, then you can try it again to get it to go off.
Pioneer inno
The problem is caused by a glitch in the firmware that came on your Inno. It can be easily fixed by downloading a free firmware update at http://fwupdt.xmradio.com.
Aug 29, 2008 | Pioneer XM2go Inno Satellite Radio...
Trying to update firmward on Delphi SKYFi3.
when it gets stuck scanning. Press (volume up) and the (mode) button both down for a few seconds. when you release the two buttons this will turn it off and back on in few seconds.
Mar 20, 2008 | Delphi SKYFi3 XM Radio Receiver
Battery life
I know exactly what your talking about, I phoned the company and got the run around, somebody, anybody please help if they can!
Feb 20, 2007 | Pioneer XM2go Inno Satellite Radio...
Pioneer GEX-INNO1 XM Radio Receiver with Home Kit Logo
1,141 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
