Question about Canon PowerShot G6 Digital Camera
Computer will not recognize my Canon Powershot G6 camera anymore. Software & drivers loaded. Camera is not listed as an ''Imaging Device'' or an ''other'' device
    Brigadier General:
  • 11,967 Answers
Time to start using a separate card reader.
Posted on Jul 07, 2010
I have a Canon G6 which I use for tethered shooting connected to a laptop. This has been successful until recently.However, when I now connect the camera I get the 'USB device not recognized'...
Sounds like a recent Windows update has altered settings. Reload the software and drivers for the G6.
PowerShot G6 - Support - Download drivers, software and manuals ...
https://www.canon.co.uk > Consumer Product Support > Consumer Products Support
  1. Cached
Download drivers, software, firmware and manuals for your Canon product and get access to online technical support resources and troubleshooting.
Mar 02, 2018 | Canon PowerShot G6 Digital Camera
Camera is connected to PC but still the PC says it is not detected.
Goto canon.com find your product and check for drivers or the missing disk. The driver for your powershot should be there and downloadable.
Apr 26, 2011 | Canon PowerShot A480 Digital Camera
MacBook Pro won't recognize canon powershot SD400
Hello. You need to probably reinstall the drivers. but first you have to remove the drivers that are all ready installed. first unplug your usb cord. then to remove the drivers allready installed,, on your computer, press start, then when the box open's up, then right click on computer. another box will open up. then left click at the bottom of that box on properties. another box will open up, then click on device manager. after you click on device manager another box will open up with all your devices. look for the previous camera you had installed. it might be under imaging devices. once you locate that, then right click on it. then choose uninstall. Make sure you have your new software loaded in your cd/dvd rom drive. after it is done uninstalling, just restart your computer. at the bottom right of your screen, it should say, found new device, it will ask you from where do you want to load the new drivers for it. click on the drive that contains the software. it then will load your new drivers up. It then should communicate with your camera. Hope this helps. Ron
Sep 08, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
My Canon A540 cannon be connected to my PC
Here are the steps to take.
1. Establish whether or not you have a connection between your camera/computer by going to your start button, control panel, system, hardware tab and device manager. The camera must be powered on and in playback mode (should automatically go to playback mode when connected, camera's screen should go black if there is a connection). Make sure you have a fully or nearly fully charged battery in your camera.
2. Once in device manager, look under Imaging Devices. If your camera is properly connected it should show up as Canon Powershot SD800. If it shows a yellow exclamation point, there is a driver issue, and even if it doesn't show a yellow exclamation point, you may want to update your driver anyway by right clicking and having the system search automatically for driver updates. If download of driver begins, great...once finished, restart camera and your problem may be resolved.
3. If there are any other imaging devices, you may have to temporarily disable them to avoid conflicts.
4. If you have any other imaging software running, exit or close the program in your system tray (down by your clock in the right hand corner of your computer's desktop.
5. Try again to connect.
6. If you are on a desktop, try a rear usb port vs. a front port. You can also try a different port on a laptop. After each change, try restarting camera to establish connection.
7. Go to start/My Computer and look for the icon for your camera...you will be able to download images even without Canon software loaded onto computer so this is not a software issue if you have no hardware connection. If you see the icon, right click on it and choose Get or Import pictures. From there the default Microsoft scanner and camera wizard should launch and you will be able to import your images.
8. If still no connection, try going to Start/Run and type in services.msc here you are looking for 4 services to be running. Check under status of each service and make sure it reads that each of these services are started.
  • Canon Camera Access Library 8 (if Canon software loaded)
  • SSDP discovery service
  • Universal Plug and Play Device Host
  • Windows Image Acquisition
Once all of these services are started on your computer, restart camera once again. If any of the last three services are not on your computer or are not started, connecting will be a problem.
If all of these steps fail, try purchasing an SD card reader from your local electronics store for around $12 and download images from there. Canon also offers lifetime technical support for your Powershot, so give them a call if none of these steps work or if you would like someone to walk you through it.
Best of luck to you!
MrsJGreen
May 29, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot SX100 is : Need to download photos onto computer. Proper connection and did this before. Now, the computer doesn't recognize the connection and a small script on the camera says...
MrsJGreen
May 27, 2008 | Canon Cameras
Windows does not recognize camera
MrsJGreen
May 09, 2008 | Canon PowerShot S2 IS Digital Camera
Connection between camera and computer
What operating system are you using? Is you camera connected via USB? Have you tried using another USB port? Did you make sure to install the software before plugging in your camera?
Generally if you are running Windows 98, you will need to reboot after installing the software to even have a chance of the camera being recognized correctly.
If you are running Windows 2000, XP or Vista, the camera should be recognized and a driver installed or searched for from the CD software you installed before plugging in the camera.
Sometimes if you plug in the camera first without installing the software, the PC finds a new device with no driver. You can see this by going to Control Panel -> System -> Hardware -> Device Manager and you should see and exclamation on a device in the list. You need to remove this item and reboot your PC.
Now install the software first and when the install is done, then plug in your camera. Generally this works out pretty well.
Apr 29, 2008 | Canon PowerShot A80 Digital Camera
Not detected on computer
MrsJGreen
Mar 09, 2008 | Canon PowerShot A460 Digital Camera
Can not download pictures
Your OS may have updated and not provided the driver for the camera. Try any or all of these steps that apply to your situation.
MrsJGreen
Mar 02, 2008 | Canon PowerShot S5 IS Digital Camera
Trouble downloading pictures
I would suspect though that it is actually the camera itself. If it is, then your cheapest option (assuming the camera is out of warranty and would require payment for repair) is to get a separate card reader device to plug into the computer, remove the memory device from the camera and read the files off the card reader.
Mar 18, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot G6 Digital Camera Logo
199 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
