Question about Canon Office Equipment & Supplies
My Canon Pixus 50i printer keeps flashing green/orange despite me having replaced a cartridge, replaced paper, switched power on and off, rebooting, holding down the power button on re-switching it on, etc.
I have something to ask you, Can you tell me where I can get drivers for the printer Pixus 50i.
Posted on Apr 10, 2009
Flashing green orange lights
The Canon service info is:
B200/P10 - Orange and green light blinking 10 times Description: A service error has occurred. Resolution: 1. Turn off the printer. 2. Disconnect the power cable. 3. Open the printer cover. 4. Check for any orange protective tape or white polystyrene and remove if necessary. 5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary. 6. Close the cover. 7. Reconnect and turn on. If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
The error code is usually given for a foreign object present in the print head carriage path, so check at both ends for a crumpled up wedge of paper. If nothing is found, it is most likely that your print head has an over-heating problem and is dying
Dec 10, 2017 | Canon PIXMA iP4600 Color InkJet Photo...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Service Error 5C00 - iP90v Pixma Canon Printer
    Clean it out underneath the printhead & cleaning mechanism first (paper towel), then do the fix routine.
    1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
    3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
    4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
    5) Press the Power button. The LED lights in green, and the
    selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
    6) Power off then back on and test.
    also there are TWO distinct steps to resetting the TWO ink counters in aan iP90. Enjoy.
    3-3. Adjustment / Settings
    (1) Service mode
    The basic operations are the same as those of the i70 / PIXUS 50i.
    In this section, destination settings, how to reset the waste ink counter, and EEPROM information
    printing, which differ from those of the i70 / PIXUS 50i, are detailed.
    1) Turn off a printer. While pressing the Resume/Cancel button, press the Power button.
    The LED lights green to indicate that functions are selectable.
    button.)
    3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the
    alternately lights in either orange or green, starting with orange.)
    4) When the LED lights green, press the Resume/Cancel button as many times as you need, to
    select the preferred function. (See the table below.) Each time the Resume/Cancel button is
    pressed, the LED alternately lights in either orange or green, starting with orange.
    (The color red indicates the changes from the i70 / PIXUS 50i.)
    Time(s) LED Function Remarks
    0 times Green Power off When the print head is not installed, the carriage
    returns and locks in the home position.
    1 time Orange Service test print
    2 times Green EEPROM information print
    3 times Orange EEPROM initialization
    4 times Green Waste ink counter resetting Proceed to step 5) below. Once executing step 5), then, move on to step 6) to select the waste ink counter to be reset. (Different from the i70 /
    PIXUS 50i.)
    5 times Orange Destination settings Proceed to step 5) below. Once executing step 5), then, move on to step 7) to select a
    destination. (Different from the i70 / PIXUS 50i.)
    10 times Green Return to the menu selection
    5) After the function (menu) is selected, press the Power button. The LED lights green, and the
    selected function will be performed. (When the operation completes, the printer returns to the
    6) Press the Resume/Cancel button the specified number of time(s), then press the Power button.
    Time(s) LED Waste ink counter to be reset
    0 time Green Main waste ink counter
    1 times Orange Platen waste ink counter
    2 times Green Main waste ink counter and platen waste ink counter (at the
    same time)
    Note: When the waste ink counter is reset, print the EEPROM information as shown below,
    and confirm that the value of the counter is 0 %.
    8
    7) Press the Resume/Cancel button the specified number of time(s) according to the destination
    listed in the table below, then press the Power button.
    Time(s) LED Destination
    1 time Orange Japan: PIXUS iP90
    2 times Green Other than Japan (A4): PIXMA iP90
    3 times Orange Other than Japan (LTR): PIXMA iP90 (LTR)
    Note: After the specific destination is set, print the EEPROM information as shown below, and
    confirm the model name.
    Print sample:
    1:iPXXXX 2:V1.02 3:IF(USB=1) 4:D=004.9 PD=000.0 5:ST=2005/09/27-18:30
    6:ER(ER0=1000 ER1=5100) 7:LPT=2005/09/028-09:09 8:PC(M=002 R=000 T=001 D=009 C=009)
    9:CLT(BK=2005/09/27-18:30 Cl=2005/09/27-18:30) 10:CH=00002 11:CT(BK=040 CL=013)
    12:IS(BK=1 C=0 M=1 Y=1) 13:IC(BK=00000 C=00000 M=00000 Y=00000)
    14:Power(SON=00009 SOFF=00009)
    15:REG=0 16:UR(A(BKoe)=+01 B(Coe)=-01 C(Moe)=+01 D(SCoe)=-01 E(SMoe)=+01 F(BKbi)=+01
    G(CLbi)=+01 H(BK-CL)=+01 I(SCLbi)=+01 J(C-SC)=+01 K(M-SM)=+01)
    17:WP=0024 18:CDIN(LG=001 PB=000) 19:MSD(015)
    20: PAGE(All=00083 PP=00035 HR+MP=00003 PR+SP+SG=00003 GP=00000 PC=00000 ENV=00000)
    21:CDPAGE=00003 IRPAGE=00003 BTPAGE=00003 PBPAGE=00000 22:BAT PAGE=00000
    23:EDGE=00083 24:L=00000 25:HEAD Temp=30.0 26:Env Temp=30.0 27:FF(3F 3F 3F)
    HDEEPROM
    1:V0001 2:SN=0000-3D6B 3:LN(00000 00000 000001 000003 00001 00000 00000) 4:ID=00
    5:IL=(BK=000 C=+01 M=000 Y=+01 C2=+01 M2=000 Y2=+01)
    Printed items:
    1. Model name 2. ROM version 3. Connected I/F (USB1) 4. Main waste ink amount, Platen waste ink amount
    5. Installation date 6. Operator call/service call error record 7. Last printing time 8. Purging count
    (manual/deep/timer/dot count/print head installation and removal/ink tank installation and removal)
    9. Cleaning time 10. Print head installation and removal (change print head) count 11. Ink tank installation and
    removal (change ink tanks) count (Bk/CL) 12. Ink status (Bk/C/M/Y) 13. Total ink consumption 14. Power-on
    count (soft power on/soft power off/hard power on) 15. Print head alignment implementation 16. User print head
    alignment values (Bkoe/Coe/Moe/SCoe/SMoe/BKbi/CLbi/BK-CL/SCLbi/C-SC/M-SM) 17. Number of times of wiping
    18. Number of times of camera port connection and removal (Legacy, PB) 19. Number of the maximum printing
    intermission in days 20. Number of print pages (total/plain paper/high resolution paper + Matte Photo Paper/Photo
    Paper Pro + Photo Paper Plus Glossy + Photo Paper Plus Semi-gloss/Glossy Photo Paper/Card/Envelope) 21.
    Number of Camera Direct Print pages (total), number of IRDA print pages (total), number of Bluetooth print pages
    (total), and number of Print Beam print pages (total) 22. Number of print pages using battery (total) 23. Number of
    borderless print pages 24. Number of print page (L/4” x 6”) 25. Print head temperature 26. Inside temperature
    27. Line inspection information
    HDEEPROM
    1. Version
    2. Serial number
    3. Lot number
    4. Print head ID
    5. Ink ejection level (Bk/C/M/Y)
    Jul 23, 2009 | Office Equipment & Supplies
    Canon iP1800 printer,flashing orange light under the green 'on'
    First off, How many times does it flash organge before it goes to green?
    two: out of paper
    three: paper jam
    four: Ink has run out
    Five: FINE cartridge cannot be found
    Seven: FINE Cart. not installed in correct position
    Eight: Ink absorber almost full
    Count how many times it flashes. Then get back to me
    Feb 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
    Problem on a canon 3100
    The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
    Two orange flashes: Out of paper, paper jam, or paper feed error
    If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
    Three orange flashes: Paper jam
    If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
    Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
    Replace the empty BJ tank and press the Resume button to continue printing.
    Five orange flashes: BJ cartridge is not installed properly
    Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
    Six orange flashes: BJ cartridge (printhead) is not installed
    Seven orange flashes: BJ cartridge (printhead) is defective
    Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
    Eight orange flashes: Waste ink absorber almost full
    The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
    The POWER light flashes orange and green alternately: Service error
    A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
    Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Canon Pixma Mp150 keeps having E2 flash
    Clear the EEPROM:
    How to clear Error Code Canon printers MP150 MP160
    CANNON Printers MP150/MP160 ERROR CODE
    E2-2 No paper (ASF)
    E3-3 Paper jam
    E4 No ink
    E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
    or the ink cartridges are not installed properly
    E8 Waste ink absorber full, or platen waste ink absorber full
    E9 The connected digital camera / video camera does not support Camera
    Direct Printing
    E14 The Ink cartridges whose destination are wrong
    E15 Ink cartridge is not installed E16 - Ink remaining is unknown
    E16 -E19 Failed to scan head alignment sheet
    E22 Carriage error
    E23 Paper feed error
    E24 Purge unit error
    E25 ASF(cam) sensor error
    E26 Internal temperature rise error
    E27 Waste ink absorber full or platen waste ink absorber full
    E28 Ink cartridge temperature rise error -
    E29 EEPROM error
    E33 Paper feed position error
    E35 15 USB Host VBUD overcurrent error - USB
    E37 17 Abnormal motor driver error
    E40 20 Other hardware error
    E42 22 Scanner error
    1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
    the Stop/ Reset button.
    2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
    service mode. (Waiting for menu selection)
    4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
    function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
    orange and green, starting with orange.)
    The number of the Reset
    button pressing
    0 time Green Power off
    1 time Orange Service pattern print
    2 times Green EEPROM print
    3 times Orange EEPROM reset
    4 times Green Waste ink counter reset See waste ink counter reset
    procedures below.
    5 times Orange Destination setting See Destination setting
    procedures below.
    6 times Green Print head deep cleaning
    11 times Orange Button / LCD checking
    12 or more times Returns to a menu selection
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Dec 20, 2008 | Canon PIXMA MP150 All-In-One InkJet...
    Canon MP 160 flashing 2E
    Found this on our site:
    E2-2 No paper (ASF)
    E3-3 Paper jam
    E4 No ink
    Direct Printing
    E22 Carriage error
    E29 EEPROM error
    try this method
    service mode. (Waiting formenu selection)
    button pressing
    procedures below.
    procedures below.
    Thanks, Joe
    Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Printer ripair
    The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
    Feb 20, 2007 | Canon BJC 3000 InkJet Printer
    562 people viewed this question
    old marine
    old marine
