Question about Logitech 350 (980374-0914) Headset
Logitech 350 Headset Casing
I read your post about open circuit wiring on the Logitech 350 headset. I think I'm experiencing this same problem. Do you have any idea where I might locate some instruction on how to crack the case without damaging the unit?
  • ace_logan Jan 17, 2009
    I also have this issue. For me the wires are getting worn at the headset entry point between the earpiece and head-bar, just inside the ball joint. I opened it up -exactly as described here- but found that it's going to be difficult to splice a replacement wire in that section, since there is little to no room. Without having to pull out, rerun and re-solder all the wire from within the head-bar and opposite earpiece, what are my other options? I'm not sure how difficult a task that would be. I'll give splicing a shot, first. Then, if unsuccessful, rewiring and soldering (though I'll have to get some solder). Either way, I also plan to add some extra heat-shrink around the wires that run through the ball joint, to prevent future wear.
  • Anonymous Mar 23, 2009
    Solution 1 was great ! thank you for the photos ! I just fixed my headsets !
    mariusmuscalu.com
Had the same problem, no headphone speakers would work.
First use a flat head screwdriver and insert in between leather padding
and plastic case and pry apart. Best to start at one area, insert a wedge
and pry further along. It will take a bit of force before it pops apart.
Take out 4 small philips screws
I found that the wire had broke right at the entry grommet. I pulled the
wire through and wiggled it and the speakers went on and off.
In my case I felt it was best to redo all the wiring. I first took these pictures
to have a map and pulled through an extra 4" of wire through and cut/desoldered
the wires.
Here are the original wiring connectLogitech 350 Headset Casing - 4017e98.jpg speaker
4017e98.jpg and what must be the common.Logitech 350 Headset Casing - ff9bb87.jpgthe wire that was broken
inside.
I re-soldered all the connections and separated them as best I could with
electrical tape (no shrink). Put everything back together and so far
seems to work fine.
Posted on Dec 23, 2008
    Brigadier General:
  • 6,966 Answers
Most headsets are plastic and therefore easily damaged so I would suggest you do it nice and slow. Often they are designed to simply snap together to form the shell covering of the actual speakers. You would need to remove the rubber covering. Once done, please inspect and determine where the halves are pressed together. Often there would be 3 or 4 areas where the latch/snap locks are. You would need something to pry them apart such as a nail pusher. If you are lucky, the snaps would be visible if the design uses a slot where the snaps lock in place.
Next would be to use a DVM (or a continuity tester) to check the speakers and the wires. The speaker should read something like 4~8 ohms while the wires theoretically should be zero. However since the wires are relatively small, it is possible to have some reading other than zero. This would still be OK, its the no reading (deflection) that would indicate where the open circuit is.
Since this is a USB design, there would be some electronics inside as well. If only one side is the issue then your problem could be after the electronics going to the small speakers; if both are not working, then it is possible that the electronics is in question and/or even the wires leading to the PC.
This is more of a challenge and an interesting DIY but from a tech point of view, it is often easier for the user to simply replace if and when convenient. Other consideration should include availability of replacement components if and when determined which is/are defective. Might it not be to your advantage to simply replace the entire headset?
Whatever route you choose, I wish you luck.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Kind regards and thank you for using FixYa.
Posted on Apr 18, 2008
Logitech headset usb wiring diagram?
Is this what you are looking for?
Jul 10, 2012 | Logitech USB HEADSET H390
My left cup has stopped working in my sennheiser pc 350 headset and I would like to know how to get it working again.
when one of the cups stop working it is a loose wire and you have to identify the wire cut and restore the connectivity ..Usually the cut is near the entry in the headset ..or in side on the mini-speaker ..
You will have to open them up and see where the wire is interrupted
Dec 31, 2010 | Sennheiser Pc 350 Headset Premium Gaming...
Logitech headset problems
the problem is with cable(wire)...the insulation got failed nd got short circuited....if warranty period is there u can get it replaced with a new one...
Apr 05, 2010 | Logitech Premium Headset
When I speak it's all static
Get another headset,,,,its ur mic....I should noe,,,i play cs a lot,,,,,I usually go through some headsets,,haha
Jun 14, 2009 | Logitech Stereo 350 Headset
Logitech USB Headset
its basic (USB Audio)
browse for the drivers.. or select driver to install
do it from device manager if you dont get a pop up
Apr 16, 2008 | Logitech ClearChat Stereo Headset Headset
Logitech Headset with micro phone
I got this from another page here:
I figured out how to remove the headphone clip without causing cosmetic damage to the headphone casing. Unfortunately for me, this was after I had scratched up the casing already. Anyway, to avoid the cosmetic damage, use some kind of plastic tool, like a plastic spoon. After pulling off the headphone cushion, you will see the aforementioned 4 slots. Carefully slip the handle end of the spoon underneath one of the slots(not through them), and apply gentle pressure toward the center of the speaker. Do this for each of the 4 slots, and the tabs should easily come loose. Hope that helps.As for figuring out how to get the headphone to work, I'm waiting for that solution myself. The right headphone is out, but the left one works, none of the wires are loose, so the damage must be from my nephew being careless with the headset cable, and probably tugging on it once too often. Don't let your 15 year olds use your headsets, if they tend to be clumsy :)
Mar 21, 2008 | Logitech (980590-0403)
Left headphone does not work properly
Based on your post/description, it would seem that the cable of your head phone developed an open circuit somewhere. I would assume it is pretty near the headset itself. On most occasion, it is at the very entry point where the cable goes into the headset.
Normal repair would involve opening the side casing where the cable enters the headset, cutting the cable about 3 inches from entry point, strip exposing the three or 4 wires and reconnecting inside the stripped ends. Effectively what you have done is trim the cable a bit shorter eliminating hopefully the intermittent section.
Hope this be of help/idea, Post back how things turned out or should you need additional information.
Good l;uck and kind regards.
Oct 27, 2007 | Logitech 350 (980374-0914) Headset
Loose Wire
just open it again u will be all set
Oct 11, 2007 | Logitech Premium Headset
Logitech 350 (980374-0914) Headset Logo
1,727 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
