Is it possible to release the detergent drawer? I need to clean it!!
  • Washing Mach... Master
  • 8,220 Answers
It has a latch like a cigarette ash tray. Push down and yank out.
Posted on Jul 07, 2010
I am not able to remove my I desist detergent drawer. I have followed the instructions in the manual and video but it does not come off. I am not able to clean it.
1. Open the detergent drawer.
2. Press the release lever (A) on the inside of the detergent drawer and pull the detergent drawer out at the same time.
Jul 10, 2017 | Washing Machines
Washer detergent drawer will not open...drawer lock or detergent cup?
Something has jammed the drawer closed. You will need to access the top of the dispenser.
Remove the 2 screws holding the top lid in back. Slide the top lid rearward and remove.
Pry open the top of the dispenser top and using a small screwdriver, unsnap the lid snaps.
This will release the drawer and you can clean out any debris that caused it to jam up.
Good luck.
Jul 08, 2011 | LG WM-2277HW Front Load Washer
ElindaddyHow do i get the detergent drawer to drain so i dont spill water all over
Hi from retired Englishman in SW France, 13:05 Friday afternoon.
Remove the detergent drawer completely but you will have to release any catches it has.
As you do not say what make and model the catch will be either a lip at the top rear of the tray which will need depressing, a catch underneath needing releasing or by having to lift it up just before it comes out.
Make absolutely certain that the conditioner/softener area parts are separated so that the tube/pipe normally found in them is easily accessible for thorough cleaning. Often it is this bit which is clogged, stopping the conditioner and water from siphoning out causing the overflow. Clean it regularly!
Good luck,
John C
Feb 11, 2011 | Washing Machines
Soap dispenser will not open.
the detergent dispenser is located behind the door panel. it is actuated by an electrical signal that powers a solenoid. two problems are possible. 1 the solenoid is not getting power or is defective, or 2, the linkage that connects the solenoid to the door release is broken or has come loose.
there are a few screws down each edge of the door ( usually phillips head) . sit in front of the dishwasher with a towel on your lap. remove the screws on each side and let the door panel fall in your lap on the towel. once the panel is off, you will see the back side of the detergent compartment. if the seal around the detergent drawer is leaking, you may find the solenoid electrical connection is corroded. ( unplug the dishwasher or turn off the breaker, as the solenoid is actuated by 110vac). if this is the case you may be able to clean the connnection. close the detergent drawer, and push on the plunger of the solenoid. the drawer door should pop open. if not, look for any binding in the linkage. if all looks well, run the dishwasher with the door panel off. when it gets to the main wash cycle, check the two terminals on the solenoid with a volt meter. if you never get power, it will be a bad control board. if you get power but the solenoid never actuates, you need a detergent drawer assembly. they are fairly inexpensive, and usually the seal fails causing the solenoid to get corroded.
Nov 20, 2010 | Whirlpool DU943PWK - Multiple Color...
My Frigidaire front load washer will not dispense the fabric softner during cycle.
Clean the dispenser drawer if water is introduced into the fabric softener cavity but does not dispense. Pull the dispenser drawer out until it stops and push down the release tab marked "PUSH" and then pull the dispenser out completely.
Lift the dispenser drawer cover and clean the tubes both in the dispenser drawer and the cover.
Turn the drawer over then release the conveyor from the tabs and lift it off. Clean the conveyor and the drawer thoroughly.
Snap the conveyor into the tabs back into position and then reinstall the dispenser cover making sure the tubes are properly seated.
Slide the dispenser drawer back into the drawer opening while pushing down the part marked "PUSH".
Let us know if the fabric softener dispenser still does not dispense while both the detergent and bleach dispensers dispense.
Mar 10, 2010 | Frigidaire ATF6000ES Front Load Washer
How to clean fabric softner dispenser sear 70 series cc3815443
hi friend,
step 1
Pull the dispenser drawer out until it stops.
  • Step 2 Reach into back right corner of the drawer opening and press the lock tab to release the drawer. Pull the drawer fully out of the washer.
  • Step 3 Lift the fabric softener dispenser cup out of the drawer.
  • Step 4 Run the fabric softener dispenser cup under warm water while rubbing it with a soft cloth or sponge.
  • Step 5 Place the cup back in the drawer and slide it back into the washer.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • You can also remove and clean the prewash, detergent and bleach detergent cups by following Steps 1 through 5.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 30, 2009 | Washing Machines
    Can I remove the detergent drawer in a hotpoint hvl241?
    There should be a release tab in the dispenser, push down, pull out
    if NOT
    Remove the screws along the rear top of the washer,lift the top, remove.
    Nov 08, 2009 | Hotpoint Aquarius WF220 Front Load Washer
    Front loader LG washer drawer for detergent is stuck won't open
    Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
    The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
    Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
    Mar 26, 2009 | LG WD-16115FD Front Load Washer
    Hoover Nextra washing machine - water backing up
    If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
    Oct 07, 2007 | Washing Machines
    Leaking water
    Possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine. Also use only detergent for 'front loading machines'.
    Oct 07, 2007 | Hotpoint Ultima WF860 Front Load Washer
    Washing Machines Logo
    15 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
