posted by daddio_40 on Apr 18, 2008
i Have compaq pressario 6000 but am running XPpro for a fujitsu siemens.Now my computer thinks its a siemens.it now doesnt recognise it has an ethernet port or audio port.
Best Solution
posted on Apr 26, 2008
Well, they both should work if you go to HP's download and support website and download the appropriate drivers for your associated hardware. Find out what hardware you have by downloading a marvelous freeware program called Belarc advisor. it will list all hardware, software, versions, keys, etc. When you installed the XP frm Siemens, it likely installed drivers compatible with the model it was designed for, rather than your Fujitsu. First, go to control panel, click Hardware and sound, then see what audio device it thinks it has. If it isn't the one your motherboard was designed for, find out what motherboard you have with Belarc, then download the audio device which works with it at the HP website. Whew. Let me know how it goes.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for System Power Supplies
Email this problem
Email this problem
This Problem Also Relates To:
HP (51842191B) Power Supply
HP (5187-1098) ( 5187-1098 ) Power Supply
HP (290483-B21) foriPaq 5400, 5450, H5455, H5450 System Power Supplies
HP (293367-001) (293367001) 180-Watt Power Supply
GE (515PS1) Power Supply
HP Bestec ATX-250-12ZD 250w HP Pavillion Zinfandel Power Supply Part 5187-1098 (ATX25012ZD) Power Supply
HP (0950-3751) (09503751) 185-Watt Power Supply
Can you Help with these System Power Supplies problems?
Dell Dimension 8400 power supply ** FREE **...
Dell Dimesion Serial adator...
My keyboard and speakers... Answer This...
IBM FRU POWER/RESET CARD 73P6310 Power Supply
reset and order of downloads
(1) My iPod nano 8GB is stuck... Answer This...
MGE UPS systems Pulsar power...
the surge protector that stays... Answer This...
MGE ups systems pulsar ES4...
won't turn on .. won't power up... Answer This...
Repair Service
Find System Power Sup. Repairman Near You:
