Question about Microwave Ovens
I need parts number for the two bricks located under element of Turbochef model ngc
  • 10,865 Answers
Go to searspartsdirect.com
put in your model number and you will get their complete and excellent schematic, parts list and parts numbers. J.
Posted on Jul 07, 2010
How to replace heating element on microwave convection oven jvm1790 sk01.
At my Web site here, I have a video showing you how to remove a typical over the range microwave's grille and control panel assembly in about 5 minutes.
Then you can find and refer to the technical sheet for this model found hidden behind the controller or grille or get it online here.
Next, you'll need to take the oven down from its mount. The installation instructions are a must, and if for some reason you don't still have them, you can download them here.
You can buy GE parts and find helpful exploded views and parts lists by entering your full model number here.
On exploded view diagram 5, "Interior Parts (1) Parts" shows the convection parts, including the heating element, here called a "heater sheath" at ref. # 3019. It is part number WB44X10046 and again, you can get it from the Pros here.
If you have other questions, please e-mail me here with your full model number as shown on the tag in or on the oven, and your detailed symptoms.
Dec 27, 2016 | Microwave Ovens
Trying to locate door latch part but Panasonic website not recognizing NN model number.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
Apr 28, 2013 | Microwave Ovens
F3 ERROR SOLUTION
Do you have Turbochef Tornado oven.
If yes then here is your solution.
ONE EASY FIX
Open right side pannel and check physically the transformers and the capacitors and the diods.
If you found burnt or burnt smell then replace that component followed by the replacing of the new fuse.
The fuse is located just under the magnetron cooling fan.(there were 3 fuse you need to replace the last fuse (facing oven from front and the last fuse 20 amps).
If you know to use DMM and clamp meter then reply me back I will give another solution .
thanks
please rate my work
Sep 20, 2011 | Microwave Ovens
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
Sharp Carousel Microwave Convection R-820JS. Oven gets hot but turntable does not rotate causing uneven baking.
If the oven is STILL heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is about $35 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is RMOTDA254WRZZ (listed as item 1-3 under the "Oven and Cabinet" parts section. If your model number does not cross reference to all websites, use the part number from the Sears website as your search criteria.
NOTE: Even though the carousel may not be turning, you can still use the microwave while awaiting parts. You will need to physically rotate whatever you are heating about midway through the cook time to ensure even heating. Early model microwave ovens were not equipped with a rotating carousel and this was the common procedure.
Apr 28, 2011 | Microwave Ovens
Model # UMV1152BAQ,S/N 10406839EN Linkage to
repairclinic.com
The average price for a motor is about $35 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is W10207571 (listed as item 22 in the parts drawing under the "Internal Controls" parts section.
Apr 20, 2011 | Maytag Appliances Over-the-Range Microwave...
We have a MMV5000 BDW and the turntable has stopped turning
repairclinic.com
Apr 05, 2011 | Maytag MMV5156A 1000 Watts Microwave Oven
I need a replacement element (8 inch) for my Kelvinator range (model no. KRS J3L-1)
Hi, W/D here.
Here's the easiest way that I know of to repair your stove:
Remove your element. Most can be removed by lifting the element on the side away from where the leads disappear under the stove top, and then pulling it out of the plug-in socket.
Take the element with you to one of the larger hardware stores, and locate the elements that have your style of terminals. The elements are generic; that's why you needed your old one. I have replaced dozens of elements and have found the generics to be every bit as good as one ordered, and cheaper, too!
Best regards, --W/D--
Jan 31, 2011 | Microwave Ovens
Door drops down 1/8' when open. To close need to
If the model number you have this listed under is correct, there is no adjustment. More than likely the door pivot and/or hinges are worn. They can easily be replaced, however. The part numbers are as follows:
Door Pivot - 8184922
Upper Door Hinge - W10114255
Lower Door Hinge - W10114254
You can find these parts at appliancepartspros.com. Just type in the model number and locate items 6, 8, and 13 under the "Door Parts" heading.
If you have questions about this repair, or have a different model number, please post back and let me know so that I may be able to provide better assistance. I hope this helps you.
Aug 25, 2009 | Whirlpool GH5184XPQ Microwave Oven
What is the part number for the turntable rotating motor or name.
If the model number is correct, go to appliancepartspros.com and use the "Search by Model Numnber" feature. The turntable motor is located as item number 43 (part number AP3205582) under the Interior Parts (1) section. I hope this helps you.
Jun 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
