Question about Linksys Wireless-G WRT54G Router
I can connect to the internet with the cable but when I disconnect the cable I lose the connection.
    Genius:
  • 1,354 Answers
Hi
just folowe the steps becoz you have not configured your wireless
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
Posted on Jul 07, 2010
Losing internet connectivity
Have you tried changing your wireless broadcast channel? It's possible the other devices are operating on a slightly different frequency as your toughbook, causing connectivity issues on that machine alone. What is your router's manufacturer? I can point you to guides to walk you through that, but they differ from company to company, so we would need that info to get a specific walkthrough. Additionally, are you running any USB 3,0 devices? If the cable's shielding is inadequate on a USB 3.0 bus, it can cause interference with WLANs by raising the noise floor and significantly reducing the range. Wrapping the cable in tin foil is an effective (although a bit southern-engineered) fix, if that is the case.
Dec 10, 2013 | Panasonic Toughbook CF-29 Notebook
How do i connect belkin n300 wireless router to motorola surfboard SB5101 cable modem?
The ISP modem (cable) connects to wireless (yellow port) PC and other devices connect to any port available on wireless. This is the standard setup.
Aug 28, 2012 | Belkin Share N300 Wireless N Router
I can only get wireless internet when plugged directly into my wireless modem. Why do I lose connection when I unplug?
If your wireless card in your computer/laptop has not been configured with your wireless router's settings then it cannot connect to the wireless router. That is why you lose Internet connect when you disconnect the LAN cable.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Nov 03, 2010 | D-Link /Netgear 4 Port 802.11 b Wireless...
I want to connect to a wireless router with my laptopbut dont seem to the wireless drivers.i have tried to connectwith virgin media modem and router .followed all instructions and when i remove ethernet...
Sir, try downloading the wireless driver from your laptop company's website. Or form the drivers cd/dvd they provided you. Then you can connect to any wireless capable modem/router from your laptop.
The ethernet cable provides the internet pulses into your laptop. If you remove it, your internet connection gets disconnected.
Jun 30, 2010 | Advent Netbook
I have a wireless connectivity issue from my laptop. When the power cable is connected, the internet works. When I disconnect the power cord, I am disconnected from the internet. This problem has only...
I would say you need a new battery, if when you disconnect the charger your losing your wireless connection, you need more power to hold the wireless connection or that make sure when you remove your charger press your wireless button near your volume control on laptop to make sure its on, blue, not off red ok
Jun 29, 2009 | Acer Aspire 3680 Laptop
I lose my internet connection when I connect HP Photosmart C4400
I am assuming that you also connect your printer via USB cable. If so, it is possible that there is a conflict of your printer and wireless card in your USB settings.
To check if there are any conflicts, click on "system" in your control panel, select "device manager" , and look for your wireless card, printer and usb ports in the list of devices.
Double click on these devices and then click on the "resources tab at the top. Check to see that the resources are free and that there are no conflicting resources.
Let me know if this helps to resolve your problem.
Regards,
Graemevm
Apr 22, 2009 | Office Equipment & Supplies
Belkin Wireless G Router causes loss of internet connection
Does your router have one LED lamp for each "wired" port?
If so, does unplugging the Ethernet-cable (the one that connects to your desktop PC) cause the lamp to go off?
Does reconnecting that cable cause the lamp to go on?
Also, on your desktop computer, there could be a lamp right beside where the Ethernet-cable connects into your computer.
Again, disconnect the cable, and reconnect the cable, to see if that lamp goes off/on.
Have you tried a different cable?
Do *NOT* connect your desktop computer to the 'WAN' port on the router -- connect it to any of the "LAN" ports.
Dec 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Netgear
There are two things involved in getting disconnected either your comp is getting disconnected or your router.
Instance 1
Computer getting disconnected connect your comp and router with ethernet cable if using wireless. Because at times it's not router but the wireless connectivity that gets loost.
Instance 2
Router getting disconnected...
Reset your router by holding the reset pin at the back of your router for 15 secs and lights will start flashing on router wait for 1 min you'll have router reset to default settings and now check that dsl or internet light on your router is flashing or static if flashing contact your isp issue with the line if static run the disc for router installation again and it'll remain connected after successful installation.
Apr 22, 2008 | NetGear WGR614 Wireless Router
USING LINKYS ROUTER/INTERNET NOT FOUND
Can you be a little more specific. What do you mean by "INTERNET PLUG IN"? Are you referring to the cable connecting your laptop to the router? The router to the modem? Or the modem to the internet (cable or DSL)?
What operating system?
Feb 18, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
87 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
